Old 12-06-2011, 12:39 AM   #1
damiiaaannn
damiiaaannn's Avatar
Drives: Range Rover Supercharged, TSX
Shorties CEL?
Will shortie headers make the CEL come on without a tune? Don't turn this into a shorties bashing thread. I live in CA, and my dad already said no to LT, and a tune. But, if they don't cause a CEL, i'll probably get some.
Soon to be the owner of a 2012 SS
damiiaaannn is offline   Reply With Quote
Old 12-06-2011, 12:44 AM   #2
camslambam
Drives: 2010 SS, 06 SRT10 Ram
http://www.camaro5.com/forums/showthread.php?t=185845
Just wait imo.
camslambam is offline   Reply With Quote
Old 12-06-2011, 12:46 AM   #3
damiiaaannn
Originally Posted by camslambam View Post
I know they are legal, but I was curious if they'd cause a CEL.
Old 12-06-2011, 12:49 AM   #4
ss/rs-matt
Drives: 2015 ZL1
My shorties alone did not cause a cel. When I added the Jba high flow cats I did get a cel.
ss/rs-matt is offline   Reply With Quote
Old 12-06-2011, 03:45 AM   #5
mikeSS
mikeSS's Avatar
Drives: 2015 c7
they shouldnt cause a CEL, but are pretty much not worth the money. maybe if you had more exhaust mod you could add little.
Old 12-06-2011, 07:45 AM   #6
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Depends what you want them for.
OP, shorties will not cause a CEL. If you're just going for aesthetics, shorties are fine. If you want more power you're better off investing the money in HF cats. Not sure this if this is an issue as well in CA, but as stated above, JBAs have been known to cause CELs, SOLOs do not. It's all about keeping the rear O2 sensors out of the flow. SOLO provides extenders for this, not sure about JBA.
Old 12-18-2011, 06:08 PM   #7
damiiaaannn
Any others that dont cause a CEL?
Old 12-18-2011, 07:20 PM   #8
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I ran BBK stainless shorties on my LS3 for 5K miles with no CEL. The ARH and BBK shorties look very similar in design.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
flht99b is offline   Reply With Quote
Old 12-18-2011, 07:32 PM   #9
battlekat
battlekat's Avatar
Drives: the red dragon
Ed M.
+1
bbk shorties with no CEL.
battlekat is offline   Reply With Quote
Old 12-18-2011, 08:01 PM   #10
20camaro12
20camaro12's Avatar
Drives: 2012 45th anniv. Convertible SS LS3
Jba shorties no CEL over 1k miles on em. Not to mention incunjuction with the cai and tb we added 36rwhp. Shorties are worth it if u put more air into the engine. Don't believe the bandwagoneers. I saw it on the dyno and with a tune only made 2more hp, 4peak hp but had some knock retard.
20camaro12 is offline   Reply With Quote
Old 12-18-2011, 10:08 PM   #11
damiiaaannn
Thanks. How much louder does it get?
Old 12-18-2011, 10:15 PM   #12
ss/rs-matt
Drives: 2015 ZL1
+1. My DT shortys definitely made a difference in performance and sound. When I added the Jba mids it got even better. Everyone on here is an expert. My advice, listen to the ones who have ACTUALLY tried the products. :-)
Old 12-18-2011, 10:31 PM   #13
VanquisherSS
Hasbin of Stock Bottom HP
Drives: CTS-V Coupe, 04 TT Viper
Shorties + High flow cats is a good combo. You'll notice the performance increase without the need for a tune. If you decide to get a tune later on you'll still make good power.
I made 420/425 RWHP/RWTQ with CAI, Shorties, HF Cats, Exhaust, TB
VanquisherSS is offline   Reply With Quote
Old 12-18-2011, 11:43 PM   #14
damiiaaannn
This might be a stupid question, but I dont know the answer. So say I get shorty headers and a cat-back exhaust. How do I connect the exhaust to the headers? Do I need another catalytic convertor? or extra pipes?
Oil change caused CEL? usafboy Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 11 11-23-2011 08:07 PM
One possible solution to CEL P0430 w/ JBA midpipes Goliath Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 01-10-2011 08:55 PM
Doug Thorley Shorties and the dreaded CEL Merritt Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 25 09-11-2010 05:56 PM
CEL with Doug Thorley Shorties?? Merritt Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 17 07-15-2010 01:35 AM
v6 CEL, shorties, IAT relocate, Flowmasters mrray13 Tuning / Diagnostics -- engine and transmission 12 01-13-2010 05:17 PM
