![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro LS Join Date: Sep 2008
Question about hooking up a ******** amp
Looking to get this package from ******** (only I'd get mine vinyl wrapped):
It includes 2 12" subs and the amp and the amp specs state: •RMS Power at 4 ohms: 475 watts x 1 chan. •RMS Power at 2 ohms: 750 watts x 1 chan. •RMS Power at 1 ohms: 1000 watts x 1 chan What does all this mean? I'm completely confused, could someone explain this to me. How would I hook this up when I eventually do get this package? |
650HP soon to come
Drives: 2017 Chevy Camaro ZL1 Join Date: Jul 2011
it depends on what the specs are on the subs.
ohms are the resistance in an electrical circuit on a 4 ohm circuit, the amp puts out a constant 475 watts of power on a 2 ohm circuit, the amp puts out a constant 750 watts of power on a 1 ohm circuit, the amp puts out a constant 1000 watts of power use this subwoofer wiring diagrams to assist in how to wire up your subs to your amp Since you're in NJ, if you need help when you do the install, reach out to me.
2017 Camaro ZL1
Hyper Blue Metallic A10, PDR, NAV, Premium floor mats |
Meant to put this in the original message but this is the link to the setup I want to get:
http://********.com/Chevrolet-GMC-Su...e-clone-1.html Says the subs are 4ohms. Went to your site and am completely lost, based off the link I sent, which setup under the 2 subwoofer section should I look at? Is each sub a different channel? Would I be able to run both subs at 1000w if the amp is rated for 1000w? |
650HP soon to come
ohhh ok. You're getting a full package together.
this is how i suggest running the set up:
2017 Camaro ZL1
Got it, thanks a lot for the help, I really appreciate it! This is a lot easier visualizing things for me than just explaining it. Thanks again.
#6 |
How'd you know the subs I am getting in the package are DVC? I was looking for it in the description but it didnt say anything.
#7 |
650HP soon to come
it says (2) 12" Kicker CVR Dual 4ohm Subs
2017 Camaro ZL1
#8 |
Jesus I'm an idiot. CVR and DVC are the same? Also how can I bridge this when the amp is only 1 channel to begin with? Don't I need more than 1 channel in order to bridge it?
#9 |
Your not bridgeing the amp, it is already only one channel. Your wiring the 4 ohm voice coils of each sub in series, which turnes the sub into an 8 ohm sub, then your wiring the subs to the amp in a parallel configuration which reduces the load the amp sees to 4 ohms. Perfect for what you want to do, and nice and safe for the amp. So each sub will see half of the 475 watts.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
#10 |
Ahhhh I see, that makes sense now. I've never installed subs or an amp before so I apologize for all these dumb questions haha. Thanks for the help guys!
#11 |
No dumb questions my friend. We all have to start somewhere.
#12 |
650HP soon to come
CVR is the model of the kicker speaker
dual 4 ohm is dual voice coil set up you don't need to bridge an already mono amp. Here is how I set up my system: 1) Start at the amp 2) Run a 12 gauge wire from the amp to two separate distribution blocks, one for positive (red) and the other for negative (black) 3) Run 14 gauge wires from the distribution blocks to the connectors on the speaker box ![]() Here is the distribution block setup I run, notice 1 wire into each block, 2 wires out ![]() How everyone runs their wires is personal preference but I found this allowed me a clean set up in my colorado:
2017 Camaro ZL1
#13 |
Got ya thanks! Do they sell these distribution blocks at any car audio place?
#14 |
650HP soon to come
yes
2017 Camaro ZL1
| ******** question | cb2011rs | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 2 | 12-08-2011 09:18 AM |
| FS ******** sub and amp stealth box | UNDsioux | Audio / Visual / Electronics/ Gauges / Nav | 1 | 10-21-2011 01:42 PM |
| ******** amp replacement harness | DanCamm | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 9 | 06-09-2011 04:04 PM |
| FS TX: ******** Camaro Passenger Side Amp Rack | xxlbeerz | Audio / Visual / Electronics/ Gauges / Nav | 2 | 04-05-2011 04:11 PM |
| Question about matching component speakers with AMP? | norty717 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 2 | 04-19-2010 10:39 PM |
