Old 01-19-2012, 08:43 PM   #1
STEALTH_MODE
I have a V6, so what?
STEALTH_MODE's Avatar
Drives: Top Secret
Wheel lock removal
Anyone know of a place in Miami, FL that can remove a wheel luck lug nut from my wheels.
My car was broken into a while back ago and i had my wheel lock keys in there which they took. I was able to duplicate the key for the lugs that i mostly had on but there is 1 lock on each wheel that i don't have the key to nor the key number to replace it.
The wheel locks are from gorilla and are these
STEALTH_MODE is offline   Reply With Quote
Old 01-19-2012, 08:59 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Two options:
1) call Gorilla and explain the situation and they can make you another key
2) whatever size socket is about right for the lugs + hammer
Click to view my build thread
Old 01-19-2012, 09:02 PM   #3
simonmcnasty
The Juggernaught
simonmcnasty's Avatar
Drives: 2010 IBM 2SS/RS
Two options:
2) whatever size SOCKET is about right for the lugs + hammer
2010 IBM 2SS RS / LG G6X3 Cam / 1 7/8" Kooks headers / Hi-Flo Cats / ADM Cold air / Magnaflow 3" exhaust / UD Pulley / Sam Miller Tune / SAE 481RWHP 441RWTQ / Eibach Pro-kit / Eibach front and rear sway bars / Elite Catch Can / DRL Harness and AAC Plasma bulbs
simonmcnasty is offline   Reply With Quote
Old 01-19-2012, 09:02 PM   #4
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Air Chisle at your local mechanic shop...
Old 01-19-2012, 09:03 PM   #5
hoz55
hoz55's Avatar
Drives: 55, 68, 79, 87, 95, 13
check with your local tire shop, they should have a special socket for removing locks
55 210 Sedan, Primer Black, under construction
68 Coupe, Primer Black, 383 stroker, TH350, 4:11 Posi
79 Coupe, 350, TCI TH350, Custom Interior,
87 Coupe, Blue, 2.8L V6, Auto, 310,000 miles +
95 Z28, Teal, 5.7L, Auto, ex-Daily driver
13 2SS/RS, Blue Ray Metallic, Charcoal Int, L99 (Auto) Pype Bombs axel back, Red LED Rear Bowtie, Gen5DIY DRL Harness, 5000K DRL Bulbs, Stripeman Graphics, Weather Tech Floor Liners
hoz55 is offline   Reply With Quote
Old 01-19-2012, 09:07 PM   #6
Ivas
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS )
That's helpful information, thank-you. Now, how do ya' remove one of them damn "boots" that the parking Nazis attach to one's wheel to immobilize the vehicle until ya' come up with the ransom that they call a "ticket"?
Ivas is offline   Reply With Quote
Old 01-19-2012, 09:08 PM   #7
The Stig
The Stig's Avatar
Originally Posted by simonmcnasty View Post
thanks
Old 01-19-2012, 09:10 PM   #8
STEALTH_MODE
Drives: Top Secret
Two options:
I already called gorilla. They can't give me a key since i don't have the serial number for my set of locks so i need to have a shop remove them somehow.
Old 01-19-2012, 09:11 PM   #9
STEALTH_MODE
Drives: Top Secret
is any of this going to destroy my wheel paint?
Old 01-19-2012, 09:11 PM   #10
hoz55
hoz55's Avatar
Plasma Cutter....
Old 01-19-2012, 09:13 PM   #11
Black1SS
Drives: 2010 Camaro 1SS/RS 6 Speed
Use the socket and hammer idea. Have had to do this before and it works
Black1SS is offline   Reply With Quote
Old 01-19-2012, 09:21 PM   #12
HDRDTD
The shop should be able to simply tack weld another standard lug nut to the locking one and remove it .
Old 01-19-2012, 09:32 PM   #13
The Stig
The Stig's Avatar
It's not pretty, but it works
Old 01-19-2012, 09:45 PM   #14
oldfriend
Drives: Fiat 500 E
Call a crane/flat bed , done
3 Piece Wheel Maintenance & Leak Detection COR Forged Wheels and Tires Talk Sponsored by The Tire Rack 8 05-26-2013 04:10 PM
FS: Gorilla Wheel Lock System Black Acorn Lugs linkwpc Wheels / Tires 2 01-18-2012 07:36 AM
Wheel lock observations...help please faninc Wheels and Tires Talk Sponsored by The Tire Rack 3 10-12-2009 08:06 PM
Lug wrench in SS? + wheel lock question... DDustiNN Wheels and Tires Talk Sponsored by The Tire Rack 8 09-05-2009 01:52 AM
Lug wrench in SS? + Wheel lock question DDustiNN Wheels and Tires Talk Sponsored by The Tire Rack 2 09-04-2009 05:16 PM
