Old 01-20-2012, 12:21 AM   #1
blk5genss
blk5genss's Avatar
Drives: 2010 Camaro 1SS/RS
Plug and wire question?
What plugs and wires are tuners using on cammed LS3 cars? I have about 21K miles on the car so I felt the need to change the plugs, wires, and add a catch can. Any recommendations?
TSP Cam 231/236 112 LSA,TSP UD,Fast 102 w/Ported TB,AirAid CAI,1 7/8 catted Stainless Power LT,3 IN MBRP 3 in Exhaust/180*,Spohn LTA's,Toe Links, Drag Bar,Diff bushings,Hurst shifter,Hendrix/DSS 1400HP Axles,Nitto NT555R's,Lethal Performance Custon Tune 480 RWHP 454 RWTQ!! Best run so far is 11.94@121 LPE 3.91's Coming soon NW 102, and DSS DS, then car should be complete!!!
blk5genss is offline   Reply With Quote
Old 01-20-2012, 02:01 PM   #2
Crime2
Got Boost?
Crime2's Avatar
Drives: 2010 1SS RS
For plugs it all depends on your tune. Personally I run the stock GM plugs based on the recommendation from Ted @ JRE. You are going to get all different answers on this.
Sent from my iPhone using Tapatalk. If is spelllled wrong deal with it.
Crime2 is offline   Reply With Quote
Old 01-20-2012, 10:53 PM   #3
Dznyfn
Dznyfn's Avatar
Drives: 13 1SS Vert, 05 Tahoe Z71, 67 RS/SS
I have the Taylor 10.5 mm race wires, no issues with them. I like the thicker wire for the look and performance.
Crime2 has it right, be prepared for an intense "discussion" on this.
Dznyfn is offline   Reply With Quote
Old 01-21-2012, 11:19 PM   #4
Slowhawk
Drives: 1999 Trans Am
We use stock wires and NGK plugs. Just works for us.
Slowhawk is offline   Reply With Quote
Old 01-22-2012, 01:26 AM   #5
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Performance plug wires are for noobs. I always run stock wires in my cars. My buddy is looking to run 9's on motor in his Camaro and he runs stock wires.
SUX2BU is offline   Reply With Quote
Old 01-22-2012, 01:29 AM   #6
keving2873
keving2873's Avatar
Drives: 2011 Camaro 2SS RS
Got NGK's put in by Tom Wong when I got my headers installed.
keving2873 is offline   Reply With Quote
Old 01-23-2012, 04:42 PM   #7
JANNETTYRACING
JANNETTYRACING's Avatar
We use MSD or Granatelli Wires and OEM Plugs.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 01-23-2012, 08:38 PM   #8
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
ted what evidence do u have that those are the best plugs to use and wireS??
Whipped416 is offline   Reply With Quote
Old 01-24-2012, 08:46 AM   #9
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I recently installed MTI Racing wires on my LS3. The OEM wires all read between 770 to 780 ohms resistance. The MTI wires read between 24 to 30 ohms resistance. My observation with the MTI wires is the cold start ( when in open loop ) is much smoother as well as the transition to closed loop versus the OEM wires, there is quite a noticeable difference. With the OEM wires cold engine drivability was a bit jerky and not real smooth until the engine was well on it's way to being fully warmed up. With the MTI wires the cold engine drivability is 98% as smooth as fully warmed up engine drivability.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
flht99b is offline   Reply With Quote
Old 01-24-2012, 09:15 AM   #10
JANNETTYRACING
31 Years of Tuning and engine building Experience.
You can't Buy Experience it has to be Earned.
Ted.
Old 01-26-2012, 12:12 AM   #11
blk5genss
blk5genss's Avatar
Ted that is exactly the route I went!! Kinda funny you said that you can't buy experience, they worked on the last ten hot rods I've owned!!! Ford or chevy the use of MSD, OEM plugs, and a hurst shifter have been the most consistant combo that works!!! I will be giving you a call tomorrow about the LPE 3.91 gears!! Unless you suggest a set of ported heads?!?!
Old 01-26-2012, 09:03 AM   #12
JANNETTYRACING
Thanks I look forward to hearing from you.
Ted.
Old 01-30-2012, 02:31 AM   #13
blk5genss
blk5genss's Avatar
All three items are on the car and work great!! Ted I'll give you a buzz soon!!
DIY: Halo as DRL on Eagle Eyes MagnumForceGB Camaro DIY & HOW-TO instructions & discussions 15 03-25-2014 06:54 PM
******** wire harness question SoTHavok Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 1 06-14-2010 11:12 PM
We need help with Electronics wiring diagrams 2SSRS@Gen5diy Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 12-13-2009 06:58 PM
SPARK PLUG WIRE TRIGGERED STABILITRAK Ukd73 5th Gen Camaro SS LS LT General Discussions 2 11-21-2009 10:21 PM
