Old 02-09-2012, 11:47 PM   #1
MoCamaro20
MoCamaro20's Avatar
Drives: 2010 Camaro SS RS L99
160 degree thermostat
is it good for a 2010 camaro ss l99? i am ordering an intake and i can get it for free. would it void any warranty and would my camaro benefit from it?
MoCamaro20 is offline   Reply With Quote
Old 02-10-2012, 01:49 AM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Originally Posted by The LSX Dr. View Post
There is a lot of info on this topic. Use the search option.
+Eleventybillion
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 02-10-2012, 10:05 AM   #3
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
http://www.camaro5.com/forums/search...rchid=13276720
most importantly: http://www.camaro5.com/forums/showthread.php?t=48525
...Robin finally commented in post #153 and #156
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 02-10-2012, 10:29 AM   #4
joey0480
Drives: 2013 Evo X
this is a topic you need to read on and make your own decision. Some say yay and some say nay to the 160 t-stat. With that said, I am getting one with my headers and tune when it is done.
2013 Evo X GSR (SSS, leather, exterior package)....stage 2 bro
SOLD:Team L99
ADM Race Intake and Scoop
Vmax Ported TB
Borla-S axlebacks
ARH 1 7/8 Long Tubes and Hi Flo Cats
160 Thermostat
Pfdat front and rear sways and endlinks
Gold Pearl Powdercoated calipers
Gloss black CFD strut covers
GM gill stripes
******** 12" Stealth Kicker Package
joey0480 is offline   Reply With Quote
Old 02-10-2012, 10:42 AM   #5
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Thumbs down
Go with what the experts are saying: NO!
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 02-10-2012, 04:37 PM   #6
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
I got one, but after talking to Ted Jannetty, it's still in the box....
Here's a quote from him regarding this subject
The Question was is a 160 Thermo bad to use....
Originally Posted by JANNETTYRACING View Post
The short answer is yes.
Here is the long answer
Minimum stat I would recommend is 180 and that is pushing it.
This is an aluminum engine and it moves alot more with temp than cast iron does, all the clearances in the engine are set up for 200 degree operating temps.
Running it cold can accelerate wear and actually reduce HP and possible spin a bearing.
Bearing clearances are very tight cold and open up to the correct specs at specified opertating temps.
Cold thermostats and low fan settings is a Crappy way to be able to get real aggressive with the timing to show a number on the dyno.
If it can't make the power at Normal Operating temps then what is the point?
Ted.
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
Old 02-10-2012, 04:44 PM   #7
Jay'SS Ride
Jay'SS Ride's Avatar
Drives: 2012 Infiniti G37S
Interesting, I like Ted's explanation.
Sold but not forgotten
Jay'SS Ride is offline   Reply With Quote
Old 02-10-2012, 05:03 PM   #8
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Old school doesn't always work on new school.
9/26/09 Took delivery!
Old 02-10-2012, 05:11 PM   #9
caverman
caverman's Avatar
Drives: '69 SS Convertible
I have a 160 stat and my car usually runs around 188 during normal street driving. Prior to the stat it was around 199 or so. That's not including runs at the race track.
I'm not sure it's really that big of a deal one way or the other. I already have it so I'm probably not going back. However, I'm not sure I would worry about adding it unless I was going to do a heater hose relocation or swapping the cam. Something that would give you another reason to drain the radiator and/or tune.
You'll need to have the car's tune changed a little to have the fans come on differently.
Build Journal
Old 02-10-2012, 10:15 PM   #10
BLACK10
BLACK10's Avatar
Yes, put it in. You live in the south. With a 160 tstat it will run around 180. Nothing wrong with that
Old 02-11-2012, 05:01 PM   #11
alcal1084
Drives: 2012 45TH AE SS
i live in las vegas and las night i went to the track, while i waited in line for my first run the car was idling around 200 degrees out side temp was 62. car is bone stock except for a catback exhaust... on my second run the car got up to 225 degrees while i waited in the staging lines... i then parked the car and opened the hood to let i cool down while i watched for the next 2 hours. after that i went back started the car to run again and the temp was down to 140 degrees by the time i got through to race the temp had gone up to 195!!! also in the winter time the temp in vegas is in the high 50's low 60's and while driving my cars temp is around 196-202 so in the summer when it 110 outside the cars temp will be even hotter. so my question is should i install the 160 thermostat thats in my trunk?
alcal1084 is offline   Reply With Quote
Old 02-12-2012, 01:12 AM   #12
BLACK10
BLACK10's Avatar
I would
Old 05-17-2012, 12:59 PM   #13
blackflag
blackflag's Avatar
Drives: 2012 2SS 45th
So how will a 160 degree thermostat act when sitting in traffic in the summer idling?
Stock car will continue to get hotter until fans kick on at 219 then cools back down about 10 degrees.
So with a 160, are the coolant temps still going to get that high that fast?
#1 2012 NMCA/LSX Challenge Series
2012 2SS 45th A6
Thanks to our Sponsors:
coldairinductions.com (Cold Air Inductions)
loughengines.com (Mike Lough Race Engines)
granatellimotorsports.com (Granatelli Motorsports)
blackflag is offline   Reply With Quote
Old 05-17-2012, 01:09 PM   #14
axis
Search Ninja
axis's Avatar
Halltech CF 102 fed
intake, thermostat
160 Degree Thermostat and Car Issues.... EAkrish Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 203 05-17-2012 02:34 PM
160 Deg. Thermostat LS3SuperSport Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 12-06-2010 01:54 PM
Benefits of 160 degree thermostat? Kwik 5th Gen Camaro SS LS LT General Discussions 13 03-23-2010 12:43 PM
160 thermostat needed with Supercharger? BlownSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 03-12-2010 06:15 AM
160 degree thermostat rforbes Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 07-07-2009 03:34 AM
