Old 03-22-2010, 04:30 PM   #1
Kwik
Drives: car
Benefits of 160 degree thermostat?
In virtually every high performance engine build, they swap out thermostats. I'm just curious what you gain with the 160 degree unit. Thanks for your input.
"Racing is life. Anything before or after is just waiting." Steve McQueen
Kwik is offline   Reply With Quote
Old 03-22-2010, 04:37 PM   #2
Ghost of Vincent Price
Banned
Drives: 2010 Camaro
Less chance of knock retard, but you need to reprogram your fans to take full advantage of it. I think its a waste of time personally.
Ghost of Vincent Price is offline   Reply With Quote
Old 03-22-2010, 04:39 PM   #3
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
You do need to reprogram teh fans to take full advantage...
But what you do get is a system which will begin to cool your engine at an earlier time. It is very helpful if you have mods whihc increase output dramatically....they can make the engine run much hotter, and you do not want it to run any hotter than it does from the factory!!
ZZcamaro is offline   Reply With Quote
Old 03-22-2010, 04:39 PM   #4
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
Haha, I read that too fast and thought you were calling him a retard.
I'm just going to mosey on out of here...
Old 03-22-2010, 04:42 PM   #5
Banned
Drives: 2010 Camaro
That would of been....less chance of knock, retard.
Old 03-22-2010, 06:33 PM   #6
R6P
R6P's Avatar
Drives: 2010 Camaro
You will likely set a code unless you have it custom tuned.
Code p0128, The purpose of this diagnostic is to analyze the performance of the thermostat by using the ECT sensor to determine if the engine coolant will increase at the correct rate, and also to meet the calibrated target temperatures under various operating conditions.
R6P is offline   Reply With Quote
Old 03-22-2010, 07:11 PM   #7
THE EVIL TW1N
Banned
Drives: 2003 Cobra Convertible
with a 160, you also usually get worse gas mileage, there is more wear on the engine over time, and higher emmissions.
THE EVIL TW1N is offline   Reply With Quote
Old 03-22-2010, 07:40 PM   #8
Mach
Mach's Avatar
Drives: White M6 1LT RS
I concur....
Mach is offline   Reply With Quote
Old 03-22-2010, 10:04 PM   #9
levi1922
levi1922's Avatar
Drives: 2LT RS CGM
hahahaha this made me laughh
levi1922 is offline   Reply With Quote
Old 03-22-2010, 10:06 PM   #10
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
Not good for a computer controlled car, temp sensor will never get reading that engine is to operating temp and therefore still be in warm-up mode.
You could try a 180 thermostat
two_wheel_mayhem is offline   Reply With Quote
Old 03-23-2010, 12:35 AM   #11
treedoc2000
Drives: 2010 camaro SS
That was FUNNY!
treedoc2000 is offline   Reply With Quote
Old 03-23-2010, 12:38 AM   #12
treedoc2000
Would it not be better to just set the cooling fans to come on earlier and leave the thermostat as is ??
Old 03-23-2010, 12:38 AM   #13
wbt
Drives: 2010 Challenger R/T;2011 Mustang GT
Believe Ted mentioned that there is no advantage. Said the best pulls he has seen are with motor up to factory operating temp.
wbt is offline   Reply With Quote
Old 03-23-2010, 12:43 PM   #14
2010 Bumblebee
2010 Bumblebee's Avatar
Drives: Transformers Edition Camaro 2SS/RS
160ºF thermostat
All of the above statements are true. More power, less gas mileage, more engine wear, worse emissions, need to reprogram the fans.
If you don't reprogram the fans you cooling system will circulate sooner. You may get a cooler version of heat quicker, but it will take longer to get to 200º F. No real harm done there.
I put a 160º thermostat in one of my car before it was a TPI 350 V-8 in a Formula 350. I didn't get much from it. I think it shifted a little harder. So you may get harder shifts, but this temp might not be good for the tranny I don't know. Too hot is no good and too cool is no good also for both the engine and tranny.
Todays engines are designed to run at higher temps. But putting that aside. Cooler air going into the cylinders because of a cooler engine will results in a denser fuel and air mixture thus more molecules of air and fuel will enter the conbustion chamber and the result will be more power. This is what a turbo or supercharger does, but they force much more air and fuel into the motor at any temp.. A cooler motor results in the same thing but on a much smaller scale and with no force. It's just one factor in the whole computation on any motor.
If you were to have a heat problem then you might change the thermostat and fan programing for that reason. Years ago the cars used to run 180ºF thermostats. So I'd say , in my opinion, that's a safe temp to run your car with the fans reprogramed. However, changing your thermostat temp might void your warantee or cause you to fail an inspection (not sure).
The Yellow Camaro Club
http://www.camaro5.com/forums/group.php?groupid=128
Northern Massachusetts & Southern New Hampshire Camaro Club
http://www.camaro5.com/forums/group.php?groupid=127
The mother of all supercharger questions thread
http://www.camaro5.com/forums/showthread.php?t=77958
My 2010 Camaro Review
http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442
2010 Transformer Edition Camaro L99 Auto
2010 Bumblebee is offline   Reply With Quote
160 Degree Thermostat and Car Issues.... EAkrish Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 203 05-17-2012 02:34 PM
160 thermostat for LS3/L99 help ??? salohi Camaro DIY & HOW-TO instructions & discussions 10 01-19-2012 09:05 PM
160 Thermostat Harley Kidd Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 03-15-2010 04:51 PM
160 thermostat needed with Supercharger? BlownSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 03-12-2010 06:15 AM
160 degree thermostat rforbes Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 07-07-2009 03:34 AM
