Old 02-10-2012, 08:20 PM   #1
Myyu
Drives: 2012 1LT IBM
Wiring question. NON-BA
I know how to wire an amp, sub and all that, but I've only ever connected the amp to an aftermarket head unit with RCA cables.
My question is, how would I go about wring the amp so it could receive signals from the stock radio? I've heard that I could just tap into the rear deck speakers, but I have never done that before.
Simply put, what would be easiest way to allow the amp to receive signal from the stock radio?
Any videos or links would be VERY helpful. Thanks.
Myyu is offline   Reply With Quote
Old 02-10-2012, 08:52 PM   #2
SoTHavok
Drives: 1
SoTHavok is offline   Reply With Quote
Old 02-10-2012, 09:11 PM   #3
Kevinshawnm
Biggz
Drives: 2010 Camaro 2SS L99 Rally Yellow
********.com, Steves Fark harness.
Kevinshawnm is offline   Reply With Quote
Old 02-10-2012, 09:12 PM   #4
Kevinshawnm
Biggz
Do you have the BA system?
Old 02-10-2012, 09:15 PM   #5
Myyu
No. It's a 1lt without it.
Old 02-10-2012, 09:21 PM   #6
Kevinshawnm
Biggz
I think you could use a line level converter, which i believe Steve also sales.
Old 02-10-2012, 09:24 PM   #7
Kevinshawnm
Biggz
Just checked his site, and he has everything you need.
Old 02-10-2012, 09:29 PM   #8
Myyu
I assume it is this?
http://********.com/Car-Audio-Produc....html?CDpath=1
Old 02-10-2012, 09:38 PM   #9
Kevinshawnm
Biggz
Yes thats one of them.
Old 02-10-2012, 10:05 PM   #10
Myyu
Ok, So do I just splice in to the left and right rear deck speakers, then plug the rca in to the amp?
Old 02-10-2012, 10:30 PM   #11
Kevinshawnm
Biggz
yep, Ive seen some that have a power and ground, I dont believe these do though.
Old 02-10-2012, 10:47 PM   #12
Myyu
Ok. So from what I have seen, read, watched, and heard, I wouldn't have to run a single wire through the front of the car. Is that correct?
I know I seem like a novice at this, but I've only ever wired trucks and suvs with aftermarket head units with rca outputs.
Old 02-10-2012, 11:16 PM   #13
Kevinshawnm
Biggz
Nope, all can be done from the under the rear deck.
Old 02-10-2012, 11:27 PM   #14
Myyu
God. I love this goofy ass car. Battery in the trunk. WHY ARENT ALL CARS LIKE THIS?!
Thanks so much. Honestly, the way its looking, It'll be a 1-2hour install.
BCM wiring HaZe_X 5th Gen Camaro SS LS LT General Discussions 5 09-26-2019 12:28 PM
Dual Color Halos with Flush LED Switch Wiring (AAC) Saint Alban Cosmetics and Lighting Modification Discussions 27 08-07-2014 10:04 PM
DIY AAC Dual Color Halo/Flush LED Switch Wiring Saint Alban Camaro DIY & HOW-TO instructions & discussions 8 01-10-2012 11:27 PM
NON-RS TO RS WIRING DIAGRAM w/RUNNING LIGHTS Bone Cosmetics and Lighting Modification Discussions 7 12-11-2010 08:10 AM
Modifications general question Eric's Blue Cosmetics and Lighting Modification Discussions 1 06-03-2010 01:24 AM
