Old 02-22-2012, 10:53 AM   #1
DuhKoDuh
DuhKoDuh's Avatar
Drives: 2011 Camaro 2SS/RS (Black) L99
l99 burnout
why wont my l99 do a burnout? i have t/c off. and it will spin for a while then just slowly stop... I'm probably making myself sound like a fool, but a quick answer would be appreciated
Follow me on Instagram @C7Corvettes
DuhKoDuh is offline   Reply With Quote
Old 02-22-2012, 11:03 AM   #2
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
Did you shut off all the nannies? You have to hold the button down for like 8 seconds.
Be careful!
Old 02-22-2012, 11:07 AM   #3
DuhKoDuh
DuhKoDuh's Avatar
Be careful!
ya but it wont remain spinning...and yes safety first!
Old 02-22-2012, 11:26 AM   #4
Darth_Emma
Darth_Emma's Avatar
Well some people think hooking up is better anyway!
I see you're in Texas. When it's warm, the tires are not going to spin as well as when the weather is cool.
Old 02-22-2012, 11:28 AM   #5
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Brake stand it for a little bit until it shifts into 2nd or 3rd... That will smoke them up for sure...
Old 02-22-2012, 12:52 PM   #6
mpyle007
mpyle007's Avatar
Drives: 2011 Camaro 2SS L99
will both tires spin when brake standing it?
2011 Camaro 2SS L99 A6
Rotofab CAI w/ race scoop
TSP Long tube headers w/ high flow cats and full x-pipe
GMPP axle back exhaust system
Custom Dyno tune by ARD (Advanced Racing Dynamics)
BMR 1.4" Springs all four corners
"There is no replacement for displacement"
mpyle007 is offline   Reply With Quote
Old 02-22-2012, 01:15 PM   #7
molsonbrador
molsonbrador's Avatar
Drives: 2010 Camaro SS, 2018 Colorado
Both tires will MELT.
molsonbrador is offline   Reply With Quote
Old 02-22-2012, 02:21 PM   #8
DuhKoDuh
DuhKoDuh's Avatar
Can I do it with paddle shifters?
Old 02-22-2012, 02:32 PM   #9
my L99 smoked em' the day I picked it up right out of the dealership lot and no brake stand needed, even from a roll it lit them right up and now with the Jannetty Street Package it will melt the tires right off.
Old 02-22-2012, 02:47 PM   #10
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
maybe, maybe not... at stock HP they will probably both spin but sometimes it will only spin one tire. JRE makes a posi mod for the rear end to fix this.
Noooooo paddle shifters are worthless...
Old 02-22-2012, 02:55 PM   #11
inferno camaro
inferno camaro's Avatar
Drives: 2010 camaro pace car, 2008 cts bl,
Make sure TC an stabilatrac are off, should be 2 seperate lights on your dic lit up. Mine is a real pita to get both off sometimes.
Mods, 2r max cam, ls3 conv,kooks lt w/hf cats,kooks street sleeper cat back with magnaflow res x-pipe, roto fab cai, v-max TB, vigilante 3700 stall, 3.70 LPE, 442hp/392tq, Mike Norris Tune 11.71@116.24 1.63 60' m&h DR's
inferno camaro is offline   Reply With Quote
Old 02-22-2012, 06:35 PM   #12
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
When my car was stock it was not overly impressive with burn outs, especially when the pavement was warm. After some mild add ons and a good tune from JRE, it make a huge difference. Turning the torque management system off with the tune made a world of difference.
With that system turned off you get all the grunt of the 6.2l right off the start which really helps.
The tranny gear ratios are pretty low in the L99 but the rear end gears are very high. In my opinion the weak link of the L99 for street grunt, high speed, GREAT but not the best for street grunt.
I put a complete JRE differential in my car with some other suspension upgrades and the difference was again, night and day. Course, the 3.91 LPE gears and JRE posi upgrade may have had something to do with that!!!
Now, a killer burn out is easy, put the car in manual mode, shift into 2nd gear, turn off all the traction and stabilitack systems, a bit of light pressure on the brake, run the rpms up to around 1500 and then tap on the throttle to break things loose. There is a slight jump and then nothing but white smoke coming out from under the rear end, you can hold it at 5000 to 6000 rpms all day long if you wanted to.
Now with the Maggie installed......... Even with 315s on the rear end...... You could burn them down to rim if you wanted to!!!!
If you want more low end grunt, make sure your torque management system is turned off and consider some new gears. It will make a huge difference all around.
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 02-22-2012, 07:19 PM   #13
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
Practice and learning the pressure points on gas and brake.
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 02-22-2012, 07:23 PM   #14
tony1
tony1's Avatar
Drives: 2SS/RS Vortech/L99
I need to fiqure out how to STOP them from spinning.
tony1 is offline   Reply With Quote
Stock L99 A6 Supercharger options, opinions, & experiences 2010 Bumblebee Forced Induction - V8 110 01-25-2019 05:23 PM
Solo Performance LS3 and L99 High Flow Cats GOINGSOLO2 V8 Bolt-Ons & Tunes 169 04-20-2015 07:15 PM
L99 Donut? Burnout? SSGUNNER 5th Gen Camaro SS LS LT General Discussions 7 11-07-2011 09:16 PM
L99 engine specifications Tran Wiki 0 10-19-2008 12:40 PM
