Old 03-03-2012, 12:22 PM   #1
dmax86
dmax86's Avatar
Drives: 2016 Z06 C7R
Thumbs up Prothane Motor mounts & MTI Tranny mount installed!
2013 ZL1 BONE STOCK! LOL
dmax86 is offline   Reply With Quote
Old 03-03-2012, 12:26 PM   #2
blackonblacksls
Drives: 2011 2ss/rs
Hey man how the car doing? I need to do mount on mine too.
blackonblacksls is offline   Reply With Quote
Old 03-03-2012, 01:01 PM   #3
dmax86
dmax86's Avatar
check my other post!
under forced induction!
btw whats has been up with u man> everything going good!>
we should meet up soon!
Old 03-03-2012, 09:50 PM   #4
Nessal
Drives: Exige, Miata, Ghia
Damn how bad is the vibration? I changed out the motor mounts on my previous car to some urethane ones and boy did it vibrate bad below 2k RPM. Honestly, I liked it but not so much my passengers. They kept saying that it felt like my motor was going to drop out.
Nessal is offline   Reply With Quote
Old 03-04-2012, 10:01 PM   #5
dmax86
dmax86's Avatar
ill find out soon man! my car is almost back together! ill let you know asap
Old 03-05-2012, 10:16 PM   #6
RaiderSS
RaiderSS's Avatar
Drives: 2010 Camaro SS2 DeadBLK
How did you get the drivers side mount out? Mine rufuses ti wiggle out...
RaiderSS is offline   Reply With Quote
Old 03-06-2012, 01:22 AM   #7
dmax86
dmax86's Avatar
Well I'm not sure what all you have got off but with the header out of the way and both motor mounts loose I carefully use a screw jack and a piece of wood to lift the motor just enough to get either side out.
Hope this helps!
Old 03-08-2012, 08:48 PM   #8
RaiderSS
RaiderSS's Avatar
I got them in! The drivers side was a mutha f...
Still finishing the front Pro bushuing kit but the mounts are done after sitting in my garage for 2 months.
Do you like the results of the tranny mount upgrade and is it a lighter mount than stock?
Old 03-09-2012, 11:17 PM   #9
dmax86
dmax86's Avatar
Looks good man! I haven't driven my car yet. It has been down for awhile. I have built a return fuel system along with a ton of other things. The car should be running possibly as early as tomorrow but definitely early next week.
Old 07-20-2012, 11:22 AM   #10
RaiderSS
RaiderSS's Avatar
Hey just an update on these... I had to call the manufacturer about space above lower bushing because the vibration at low speed was so harsh. I thought the mount assemblies had loosened allowing for more movement of the engine block. Turns out they have a recall on the older mount sets because the original designed bushing was to soft.
They sent me the stiffer bushings which were noticeably more firm when squeezing in my hand from the set I just removed. Installed and did a better job of tightening mount bolt to insure the engine block was set in firmly with no gaps between the bushings and washers. Drove in to work today and the vibration was much less harsh and only unpleasantly noticeable at low speeds and low throttle when the AFM kicks the engine into 4 cylinder mode. Will tighten one more time when I get back home but now I know why the stock mounts were so bulky and dense to tune out the reverberation from 4 cylinder mode...
I guess its time to tune....
Old 07-21-2012, 03:59 PM   #11
dmax86
dmax86's Avatar
Cool man. Good to know! Hopefully this can save another member a headache
Old 07-28-2012, 06:47 PM   #12
Nessal
So how much vibration did you get? I did solid mounts on my previous car and it shakes bad. But it firmed up the transmission and makde it easier to shift fast it prevented the transmission and.engine from moving around. Same experience with these?
motor, mounts, mti, prothane, transmission
Camaro Dove Tail Spoilers Compilation daphatgrant Cosmetics and Lighting Modification Discussions 473 07-11-2025 10:07 PM
589RWHP Daily Driver by MTI Racing MTI Racing Kevin 5th Gen Camaro SS LS LT General Discussions 10 04-14-2010 10:08 AM
MTI sway bars flht99b Suspension / Brakes / Chassis 10 03-29-2010 04:33 PM
MTI shifter installed.... great improvement! kelleyperformance V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 01-01-2010 10:22 PM
