Old 03-18-2012, 03:50 PM   #1
JorgeNCrystal
JorgeNCrystal's Avatar
Drives: 2011 Black Camaro SS (LS3)
LED Grill Illumination
I want to know how to place the ACC LED grill illumination kit from oracle as shown below. I would appreciate the help..
JorgeNCrystal is offline   Reply With Quote
Old 03-18-2012, 10:28 PM   #2
LED Crazy
okcamaros.com
LED Crazy's Avatar
Drives: 2016 SS
You can use a Oracle LED strip and mount it upward to give you the look picture above
LED Crazy is offline   Reply With Quote
Old 03-18-2012, 10:38 PM   #3
JorgeNCrystal
Mount it where?
Old 03-20-2012, 07:17 AM   #4
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
Use tape to hold it temporarily in place and experiment till you get the look you want. Then mount it permanently in place. There is no right or wrong answer to your question. It's all about your taste and desires.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 04-07-2012, 07:33 AM   #5
Vann2SS/RS
"NY5THGEN"
Vann2SS/RS's Avatar
Drives: Blk on Blk 2SS/RS M6
I'm looking to do the same thing. Do you have to take the front bumper off.
2011, 2SS/RS, Blk on Blk, M6, CAI cold air intake, MGW shifter, Pfadt sway bars, & lowering springs, AAC led's DRL, dome, trunk, lic plate, Lloyd's custom mat's, Bowtie delete, DRL harness.
Vann2SS/RS is offline   Reply With Quote
Old 04-09-2012, 07:13 PM   #6
LoneStar
LoneStar's Avatar
Drives: 2011 IOM Camaro
I've seen it mounted directly behind the grill, installed with double side tape directly behind and to the top of the grill.
Mine is installed with a couple of zip-ties to some pre-drilled holes that are in front of the radiator (seen when looking through the grill.
With the heritage grill, you may need to remove the front bumper. On the stock grill, I was able to install the light bar by removing the black plate where the hood patch is.
LoneStar is offline   Reply With Quote
Old 05-29-2012, 08:58 PM   #7
Bernard
Bernard's Avatar
Drives: Silver 2LT RS CHEVY CAMARO 2010
Send a message via AIM to Bernard
how do u tie them in
safely
WHERE IT ALL BEGAN
Bernard is offline   Reply With Quote
Old 05-29-2012, 09:58 PM   #8
mycamaro2011
mycamaro2011's Avatar
Drives: 2010 Camaro 2LT Victory Red
Use 3m doubled side attactment tape and some 3m tape primer
mycamaro2011 is offline   Reply With Quote
Old 05-30-2012, 10:19 AM   #9
PIPE
Hating prius's since 1997
PIPE's Avatar
Drives: 2010 Camaro 2SS/RS (JENNA)
Put them on the backside of the metal bumper.
PIPE
PIPE is offline   Reply With Quote
Old 05-30-2012, 06:33 PM   #10
Bernard
Bernard's Avatar
i mean as far as wiring them under the hood to light up my grill
WHERE IT ALL BEGAN
Old 05-30-2012, 06:34 PM   #11
Bernard
Bernard's Avatar
what contacts do i use and where does the switch go
WHERE IT ALL BEGAN
Old 05-30-2012, 06:39 PM   #12
Bernard
Bernard's Avatar
the tape and tie wraps arent my problem the wiring is
anyone help
WHERE IT ALL BEGAN
Old 05-30-2012, 07:33 PM   #13
DPerry
DPerry's Avatar
Drives: 2010 Black LT
I glued mines above the grill facing downward and my bumper was already off once I was installing halos at the same time then wired them to the fuse box because the battery is to far away
DPerry is offline   Reply With Quote
Old 05-30-2012, 08:36 PM   #14
cyberLS
cyberLS's Avatar
Drives: 2010 Cyber Grey LS
that is my car and what i did was 3m in to the front brace of the car so it reflects off the radiator so it shows tho both grills. then ran the wires to the fuse box and and tapped the positive to the front bolt of the fuse box and then grounded the black wire.
cyberLS is offline   Reply With Quote
DIY: LED SIDEMARKERS Mach Camaro DIY & HOW-TO instructions & discussions 233 12-05-2015 11:46 PM
F/S Varad undercar & suspension led lighting kits. urr2slo Local Marketplace 4 05-14-2012 05:16 PM
DIY: LED Strip Sidemarkers Mach Cosmetics and Lighting Modification Discussions 23 11-07-2011 11:17 PM
Heritage Grill Dilemna DevilsReject97 Cosmetics and Lighting Modification Discussions 44 05-20-2011 11:34 AM
