Old 03-22-2012, 01:48 AM   #1
SSawdusty
Crewel Jewel
Drives: RJT-2SS-RS-6M
Started My Whipple Install
Well ordered my Whipple from Jannetty Racing a while ago, had it shipped and it arrived a few weeks back. Its been sitting around for a bit and now finally getting some time to start the install. So I thought I would take some pictures during the install.
SSawdusty is offline   Reply With Quote
Old 03-22-2012, 01:49 AM   #2
ORANGA2D
ORANGA2D's Avatar
Drives: 2011 IOM 2SS/RS M6
First off, you dont bolt it to the floor..
j/k good luck with your install, send lots of pics
ORANGA2D is offline   Reply With Quote
Old 03-22-2012, 01:59 AM   #3
SSawdusty
Crewel Jewel
Well.... jacked up, front wheels off, inner fender wells out and front fascia off.
Old 03-22-2012, 02:24 AM   #4
SSawdusty
Crewel Jewel
Next came mounting the brackets for the heat exchanger and circulating pump. Be careful drilling. Center punch and pilot hole before the final hole are recommended. There's not much room on the bottom side of the hole. So you don't want to be off the mark. Yes the bit slipped on me still
You also have to be careful when drilling to avoid the wire loom behind. But even more careful you don't put the drill bit through the rad. So I used this handy drill stop. Not worth taking a chance.
Old 03-22-2012, 02:55 AM   #5
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Drives: Cyber Bullet
are you installing it yourself i wish i had the skills to instal mine,good luck and post more pics of the installation.
Old 03-22-2012, 10:08 AM   #6
SSawdusty
Crewel Jewel
Yes, installing myself. Will keep the pics coming. Thanks for the luck.
Old 03-22-2012, 10:09 AM   #7
SSawdusty
Crewel Jewel
Makes the floor look good. Thanks for the luck.
Old 03-22-2012, 10:23 AM   #8
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
Dude this is what we need a good diy on a supercharger!! Thanks bro..u should do something like what robertway did for his install of the camshaft that would be awesome..ill be suscribibg to this thread
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 03-22-2012, 11:58 AM   #9
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Subscribed. Love the pictures.
Old 03-22-2012, 12:14 PM   #10
GbrilliantQ
¡ʇuɐıןןıɹq
GbrilliantQ's Avatar
Drives: 2011 Camaro IOM 2SS/RS
This. Nice pictures. So a diy eh? Awesome
Sent from my Galaxy Note
GbrilliantQ is offline   Reply With Quote
Old 03-22-2012, 12:28 PM   #11
SSawdusty
Crewel Jewel
Thanks. At first I was just taking a few pics of the install then I started taking some to show some of the difficuties along the way. robertway did such a great job of showing his project it would be hard to live up to that class act. I am further ahead than my pictures show and have more to post and I will take more pics but there may be some gaps on the things already done.
Old 03-22-2012, 03:36 PM   #12
bigsquirrel
My car runs on acorns....
bigsquirrel's Avatar
Drives: 2010 SS RS Inferno Orange
I've found these installs easier with my old friends, scotch, the squirrel and the lorax. Good luck! Hey make sure you don't use the supercharger oil as drilling oil when you pin the crank.... or so I heard....
My car runs on acorns, the tears of ricers and these other slightly less important things...
2.9 Polished Whipple, Kooks LT 1 7/8 headers, HiFlow Cats, Kooks Sleeper catback, Cooling Mist Methanol Injection, PFADT Sport Sways, PFADT Springs, PFADT rear trailing arms, ADM intake, JDP stainless brake lines, Jegs Catch can, Stock SS wheels widened to 10 3/4, Hawks HPS Pads, Pedders Rear Subframe Bushing Inserts, BMR Center Brace, MSD BAP, AAC side markers, Emblem Pro's Custom Lighted Door Sills, Dash-Floor-Cupholder ABL lighting and other stuff....
bigsquirrel is offline   Reply With Quote
Old 03-22-2012, 11:07 PM   #13
SSawdusty
Crewel Jewel
Here's the cuts made to the lower air deflector. This allows you access to tap the lower rad mounts. This is where the bottom of the heat exchanger bracket mounts to. You can also see the hole drilled for the pump wiring to go through. Directions say one inch hole but you will to make it a little larger in one spot or the plug wont fit through.
You have to make sure your brackets are straight before drilling the top holes. I found it easier to attach the brackets to the bottom holes(rad support) then temporary mount the heat exchanger to the brackets. This allows you to get it in there straight as well you can mark the top holes exactly. Sorry no photo of this, but its pretty easy.
In the directions they tell you to drill a four inch hole to the right of the mounted circulating pump to allow fresh air into the airbox area. If you have an aftermarket cold air intake or plan on getting one I would not drill the hole.
Old 03-22-2012, 11:30 PM   #14
SSawdusty
Crewel Jewel
Now came the wiring for the circulating pump. Pretty well explained in the directions.
A couple of cuts to the fuse box lid to allow the fuse tap and power wire to exit.
Relays mounted
The ground wire was to bolt to the ground on the block. But I hooked up to the other end where it attaches to the body. This just meant one less wire going to the block keeping it neater
Wiring along the front going to the pump.
The Elimination Game: Camaro colors Ant Cosmetics and Lighting Modification Discussions 2739 04-10-2014 10:37 AM
Car is Headed to Vengeance for a Whipple Install HufferSS Forced Induction - V8 77 09-25-2011 03:18 PM
Cincy Speed, another Whipple install and tune. Qwkss Forced Induction - V8 90 06-11-2011 12:48 AM
2010 Camaro 2.9L Whipple Install Jason@RPM-Motorsports Forced Induction - V8 20 02-21-2011 02:42 PM
Whipple Install Questions bigsquirrel Forced Induction - V8 14 10-12-2010 07:51 PM
