Old 04-16-2012, 10:52 AM   #1
SmokingSS
Drives: 2011 2SS L99 RS
L99 with a Maggie
Went to the track finally and it was like driving on ice through 3rd gear without the traction control on.. I am @ 490RWHP and 508tq. I have 315/35/20 Nitto Envos on the rear. I ran a 12.06 and a 12.04 best @ 118.5 and 120 mph with all the traction on and some spinning. Let the air down to 24psi and heated the tires up a little and it seemed to help some.. Left around 1000rpms with a 60' time of 1.887. Any thoughts or suggestions...So close to the 11's..The weather was about 80 degrees and a little humid also.
SmokingSS is offline   Reply With Quote
Old 04-20-2012, 06:15 PM   #2
BumbleBeeSS2009
BumbleBeeSS2009's Avatar
Drives: Rally Yellow 2SS/RS
Drag radials and suspension mods (ties/toes/sways/bushings/springs)....
need a way to get all that power to the pavement!!
#52325 Delivered 11/07/2009
BumbleBeeSS2009 is offline   Reply With Quote
Old 04-20-2012, 06:20 PM   #3
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Get rid of the Invos for the track. Get some drag radials and you'll be deep in the 11s.
Old 04-20-2012, 07:21 PM   #4
Motion427
Drives: 2010 2SS/RS Red Jewel L99
Do what both of the above posted.
Motion427 is offline   Reply With Quote
Old 04-21-2012, 09:22 AM   #5
SmokedSS
Guest
Drives: 2011 2SS / RS A6
Thanks for the advice... I have BMR tie rods, trailing arms and Eibauch Pro 1" lowering springs. Next step is probably stall and drag radials..
SmokedSS is offline   Reply With Quote
Old 04-21-2012, 12:26 PM   #6
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Was this at NPR in Belle Rose, I like that track.
If you want to run your best on street tires, and you can't get it to hook at the track, you can roll into the gas gradually. How I do it is I hold the gas like you are, and then I gradually push down on the gas pedal to a long ONE count.... O N E.
Radials and drag radials like a prepped track. You'll run your best times after they spray and drag it.
I am crew chief for a 7.40@195 ODR LSX car and it's cut a best short time of 1.23 this year which takes some work.
I've gone 1.35 on 325 DR's, I need to try some 17's or 18's on this 5G after I start modding it.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Last edited by Pro Stock John; 04-22-2012 at 12:32 PM. Reason: can't not can edited
Old 04-21-2012, 06:18 PM   #7
SmokedSS
Guest
any thoughts on what stall conv. would work best for my setup? I want it to be very street friendly but help some @ the track,,, 2800..3200...custom built...off the shelf?
Old 04-21-2012, 07:12 PM   #8
Motion427
2600-2800 Protorque.Take a look at Janetty Racing.
Old 04-21-2012, 07:15 PM   #9
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
YOU NEED DRAG RADIALS! Also if you stall to 2800 those Drs are gonna be pushing the limits of traction.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Stock L99 A6 Supercharger options, opinions, & experiences 2010 Bumblebee Forced Induction - V8 110 01-25-2019 05:23 PM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
Maggie with bolt ons L99 500RWHP IS it legit? jsharp Forced Induction - V8 52 05-09-2010 08:37 AM
Maggie install (automatic L99) Easy racer778 Forced Induction - V8 27 04-26-2010 06:04 PM
GM High Tech Performance Magazine's L99 Tune - +81 ft lbs at 3500 rpms! SGOS252382 Tuning / Diagnostics -- engine and transmission 52 10-01-2009 12:31 AM
