Old 08-09-2012, 07:37 PM   #1
infernometallicSS
infernometallicSS's Avatar
Drives: 2012 Camaro SS Best Run - 10.93@125
Cam...
So I am looking at doing a cam on my L99. I have a Circle D 3000 RPM Torque Converter installed already. I called Comp Cams and they recommended this cam (which I have attached cam spec sheet which could be seen below). I am just curious if anybody has ran this and if there is a dyno sheet available. I want to see how this cam looks across the board. I have a goal in mind that I would like to achieve when doing a cam in the L99. I will be doing the LS3 conversion, trunion upgrade, melling oil pump, and heads if they fit the budget. That goal being mid 400 range without losing too much torque down low, the camaro is a fairly heavy car which needs some grunt down low to get it moving. I'm not sure how much drivability is effected with an aftermarket converter either. I understand that this may be a hard goal to achieve once everything is considered (drivetrain loss, crappy fuel in az, high temps, and a strict budget). I am open to suggestions, however all I ask is that if you have a cam that might fit my criteria please post a dyno sheet, and maybe give me some information on how that performs. This car is driven 95% on the streets, though its not driven much at all. I thank everyone for looking at this thread and giving me your thoughts.
infernometallicSS is offline   Reply With Quote
Old 08-09-2012, 08:05 PM   #2
BigBlue2010
BigBlue2010's Avatar
Drives: 2010 Camaro 2SS/RS IBM A6
I am doing the same set up. How is the l99 with just the torque converter install?
BTR N/A Stage IV, LS3 conv. w/ trunion, 3200 Circle D, ZL1 wheels(295/305), 3.91's, Kooks Stepped LTs, SW Retro CB, AirRaid CAI, VMAX TB, SLP UDP, 160 thermo, BMR goodies
BigBlue2010 is offline   Reply With Quote
Old 08-09-2012, 08:11 PM   #3
infernometallicSS
I just did the converter yesterday. I am very pleased with how it drives on the streets. I have the multi disc one and you can tell when it locks. The RPMs drop like it has grabbed another gear. Do a trans cooler when you do the converter. It was 116 yesterday in phoenix and my temps rose to just a hair above 180* in traffic and back down just under 180* on the freeway. I will say that you will need some drag radials to achieve full benefit of the converter on the track.
Are you going with that cam that I posted specs for?
Old 08-09-2012, 08:39 PM   #4
BigBlue2010
I am doing a Circle D multi disk 3200 stall.
I was recommended a 225/235 Comp Cam by the shop i am going through. I have no clue about cams, i just explained what i wanted and they recommended one to me.
Are you installing yourself or having a shop do it?
Old 08-09-2012, 08:41 PM   #5
Higgs Boson
Perpetual Order
Drives: indeed
should be a pretty stout cam.
Higgs Boson is offline   Reply With Quote
Old 08-09-2012, 09:30 PM   #6
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
think this is the cam
Nitroman28 is offline   Reply With Quote
Old 08-09-2012, 09:35 PM   #7
itguy
Drives: CTS-V Wagon
Yes, that's mlee's car....read all about his build here:
http://www.camaro5.com/forums/showthread.php?t=80769
itguy is offline   Reply With Quote
Old 08-09-2012, 09:37 PM   #8
Nitroman28
Nitroman28's Avatar
Thought I had seen that tag before..
Old 08-09-2012, 09:55 PM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
That's a sexy specd cam OP!!
Old 08-09-2012, 11:23 PM   #10
infernometallicSS
I think I would be happy with that.
Old 08-09-2012, 11:25 PM   #11
infernometallicSS
A shop will be doing all of my work.
Old 08-09-2012, 11:40 PM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I'm sure of it bud
Old 08-09-2012, 11:58 PM   #13
infernometallicSS
I'm sure of it bud
I have seen you around on a lot of cam threads. Seem to have some knowledge of cams. Thanks for the input.
Old 08-10-2012, 12:26 AM   #14
Nitroman28
Nitroman28's Avatar
He has to know something about cars, look at all the abbreviated parts in his build list..
54-469-11, comp cam, l99 cam
