Old 08-28-2012, 11:08 PM   #1
Medi0cr3
Untamed Performance EPT
Medi0cr3's Avatar
Drives: 2011 2SS
Average time to install... Headers?
Looking for an average time of install completion of headers. I'm also curious of any issues that arouse during install or anything that you weren't ready for.
I got some borla LTs no cats and I'm tryin to play my days and see how the install goes. Also what do people recommend for tuning with these headers?
tia
Medi0cr3 is offline   Reply With Quote
Old 08-28-2012, 11:18 PM   #2
kevin1106
kevin1106's Avatar
Drives: 2015 ZO6 3LZ Stage 2 A8
Install is 2-3 hours. Be sure to remove your spark plugs...
Tune, I used a diablo sport and had a guy tune it through email for 100 bucks....
kevin1106 is offline   Reply With Quote
Old 08-28-2012, 11:31 PM   #3
The 2010 Sin
Dont H8 Me Cuz U Aint Me
The 2010 Sin's Avatar
Drives: 2016 SS Sedan, 2017 Explorer Sport
If its your first time but you're mechanically inclined 2 hours. I did mine full swap from turn off to start up in 2 hours on race ramps. the second set I time in just about an hour.
lay out your tools before hand tho makes life easy. I didn't remove my plugs I was just careful not to bump them. The recommend you remove them so you dont hit and crack one.
The 2010 Sin is offline   Reply With Quote
Old 08-28-2012, 11:31 PM   #4
The Blue Ox
The Blue Ox's Avatar
Drives: 2010 SS L99 Inferno Orange
Depending if you have a jack and jack stands or access to a car lift,prolly looking at least 4 hrs or give yourself at least a day! Sure want to get it tuned after long tubes!I know there are a lot of good tuners out there but I would strongly recommend Nelson Performance out of San Antonio,they done an excellent job on my 350 vortec sbilverado ! You can also check out LS1.com!
The Blue Ox is offline   Reply With Quote
Old 08-29-2012, 12:12 AM   #5
caverman
caverman's Avatar
Drives: '69 SS Convertible
I would plan for about 4 hours with the help of a friend. That's about what I remember the first time I did a set. Better to plan for 4 and it take 2 than the opposite.
For tuning, if you don't have reputable person to take it to locally you should call Jannetty Racing and do one of their mail order tunes for about $400.
Build Journal
Old 08-29-2012, 12:24 AM   #6
Denis
Denis's Avatar
Drives: 2010 SS
Mine took three. Make sure u remove your plugs!!
Old 08-29-2012, 12:25 AM   #7
TheNewCzar
Drives: 2011 SS Rally Yellow Vert, 2000 WS6
Plan on a little under 4 hours and a 12 pack of beer.
TheNewCzar is offline   Reply With Quote
Old 08-29-2012, 12:33 AM   #8
lynxone
lynxone's Avatar
Drives: 2012 2ss 45th anniversary edition
or 6 hours and a 24 pack
2012 2SS 45th with a few tasteful mods
lynxone is offline   Reply With Quote
Old 08-29-2012, 12:38 AM   #9
11TexaSS
11TexaSS's Avatar
Drives: 2011RedJewel, FI
Mine took 2hrs.
11TexaSS is offline   Reply With Quote
Old 08-29-2012, 12:43 AM   #10
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
I did mine in an hour with a lift and air tools. I didn't remove the plugs, I was just careful not to bump them. I also didn't disconnect the battery, not sure why I needed to really.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 08-29-2012, 01:00 AM   #11
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
Takes us about 2 hours here
MarylandSpeed is offline   Reply With Quote
Old 08-29-2012, 10:44 AM   #12
Eli
Eli's Avatar
Drives: 2011 Convertible SS/RS M6
Took me a little over 4 hours with several interruptions form my 1 and 2 year old. I was in no paticular hurry and did the install with hand tools on jack stands. The passenger manifold bolts were a PITA. Id reccomend getting a decent swivel for your extensions. Other then that not having a second set of hands leads to a lot of up and down that increases the install time exponentially.
Eli is offline   Reply With Quote
Old 08-29-2012, 11:12 AM   #13
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
Hell, it took me all day long. Did it on ramps, it was 100 degrees out and it was my first time installing headers on a vehicle. It really wasn't hard. The one really tricky part was putting the oil dipstick tube back in place. Good luck with that!
E.T. is offline   Reply With Quote
Old 08-29-2012, 11:26 AM   #14
Medi0cr3
Medi0cr3's Avatar
Drives: 2011 2SS
What elae did u have to take out? I assume anything to make the task easier.
