Old 11-01-2012, 10:44 AM   #1
Jnlcamaro
Jnlcamaro's Avatar
Drives: 2012 Camaro
Gas.. What to do..
I am not sure what to do, I was in a pinch and filled my car up.. Now it's sputtering.. I get to a stop light/sign and it sputter's like it wants to die.. Should I continue to drive it till the tank is empty or figure out to drain the gas, or is there something I can add to the gas tank to make it better. I am so worried about adding anything to the tank, (even tho I made a poor choice filling up were I did).. Any help would be great.. I am down to about between 3/4 and 1/2 tank..
Jnlcamaro is offline   Reply With Quote
Old 11-01-2012, 10:58 AM   #2
monstertodd
monstertodd's Avatar
What kind of gas did you put in it?
Old 11-01-2012, 11:00 AM   #3
Jnlcamaro
Jnlcamaro's Avatar
Drives: 2012 Camaro
Arco.. 87% .. I was told when I bought the car at the dealership to only use "the cheap stuff".. was that bad advice?
Old 11-01-2012, 11:02 AM   #4
Silver1SS
Drives: 2010 Silver 1SS
Yes. I run 93 octane in mine...if you're going to keep driving it till it's empty I'd run some fuel additives through the next tank to help clean it out.
Good luck.
2010 Silver 1 SS - Stock for now
Silver1SS is offline   Reply With Quote
Old 11-01-2012, 11:04 AM   #5
angie7
Smoked by a GIRL
angie7's Avatar
Drives: 2014 2SS/RS
The V6 can run on 87 but the V8 needs 93.
2014 2SS/RS Summit White w/ IOM interior "Powder 2.0"
angie7 is offline   Reply With Quote
Old 11-01-2012, 11:05 AM   #6
SabotAndHeat
SabotAndHeat's Avatar
Drives: 2010 Camaro
It pays to read the manual.
SabotAndHeat is offline   Reply With Quote
Old 11-01-2012, 11:10 AM   #7
BowtieBelle
They see me trollin'...
BowtieBelle's Avatar
Drives: 217 ci of fury; Chauffeured by SS
The V8 needs 91, not 93, minimum. Add some Octane Booster, and once the tank is out, do a fuse pull and refill it with 91. I think you'll be OK. If you have the money to burn, sure, drain the tank.
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread
BowtieBelle is offline   Reply With Quote
Old 11-01-2012, 11:11 AM   #8
Birm
Birm's Avatar
Drives: Florida Speed & Power
You can get Torco or STP Octane Booster to finish off that tank, but I would not put cheap shit in my car. For the few extra cents a gallon it runs so much better. Why go cheap on gas when you are talking maybe 2$ a tank when all is said and done?!?
Never got the logic behind it..
Once it runs out it will be fine, but probably wouldn't skimp in that department.
Birm is offline   Reply With Quote
Old 11-01-2012, 11:11 AM   #9
BowtieBelle
Old 11-01-2012, 11:16 AM   #10
Devilstrip12
Devilstrip12's Avatar
Drives: 2011 1LT RS imperial blue camaro
Can a V6 run in 91 as well or is just for the V8?
Devilstrip12 is offline   Reply With Quote
Old 11-01-2012, 11:16 AM   #11
ROD_SS
ROD_SS's Avatar
Drives: 2013 1SS Camaro and a truck
It can but you don't need it. The 87 is just fine!
ADM tuned (465 rwhp / 442 torque) Mods- CAI, kooks long tube headers, & ADM stage 2 cam
ROD_SS is offline   Reply With Quote
Old 11-01-2012, 11:17 AM   #12
BowtieBelle
There are two different schools of thought on this. Plenty of people say that we should run 91. Personally I don't think it makes enough of a difference on our cars, and I don't think we need it-- but there are people who hardcore disagree with that.
Old 11-01-2012, 11:18 AM   #13
Devilstrip12
Oh was just a curious question thanks for the reply
Old 11-01-2012, 11:23 AM   #14
2010SS2SS
2010SS2SS's Avatar
Drives: 2010 Camaro SS 2SS
Always understood the higher the octane the more complete the "burn" in the cylinders.
If that is true than even if your car doesn't "require" it, it could make for longer engine life with less residual left on or in cylinders and valves
2010SS2SS is offline   Reply With Quote
