Old 12-06-2012, 07:53 PM   #1
Rigzo510
Drives: 2012 Camaro Ls3
Santa came early.. jre cam and headers!
Just received my jre rough idle blower cam kit, melling oil pump, new timing chain, and Dynatech LT w/ cats and sct tuner. Can't wait to put em on!! Thinking of going with synergy motorsports or blu808 don't know which yet, but quick question. To data log my car for jannetty's tune do I data log right now when it's stock and send that or wait till they install everything and then datalog? I have no laptop so is it possible to do it with just the sct itself? ThanksName:  image.jpg
Rigzo510 is offline   Reply With Quote
Old 12-06-2012, 07:58 PM   #2
camaro actual
camaro actual's Avatar
Drives: 2010 Camaro 2SS/RS L99
Thats Sweet, wish he had stopped by my house too.
camaro actual is offline   Reply With Quote
Old 12-06-2012, 08:00 PM   #3
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
You upload your stock tune with the sct, send it to Ted then he sends it back, upload that to car, after everything is installed you datalog it and carry on from there.
Sent from my iPad using Tapatalk HD
Caswell239 is offline   Reply With Quote
Old 12-06-2012, 08:03 PM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
You wait till after it's done. All SS's should give roughly the same data when stock. Ted should have sent you a "start up" tune to get you up and running on the new setup. Then you datalog with your SCT to see what your car is doing with the new setup. I think he'll have you do certain things during your test drive to get the data points he needs. You send that datalog file back to Ted and he adjusts the tune based off the data. It may take a few back and forth emails but he should get you dialed in pretty quick. He does this with blower installs as well.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 12-06-2012, 08:04 PM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Did you order all your parts including your tuner thru JRE? If so he most likely sent you a tune for all those mods. After the install is when you'll need to data log and email him the info thru your SCT. Or you can get a custom dyno tune.
Old 12-06-2012, 08:06 PM   #6
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Damn it caswell and AXIS (your an AZZ) for taking my spot on this post!!!
Old 12-06-2012, 08:06 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Lol
Old 12-06-2012, 08:09 PM   #8
axis
Search Ninja
axis's Avatar
See if I ever stick up for you in a CAI debate again.
Halltech CF 102 fed
Old 12-06-2012, 08:10 PM   #9
R8E1D
R8E1D's Avatar
Drives: 2013 Ram 1500
http://www.camaro5.com/forums/showthread.php?t=207728
Here you go. Ted needs your stock file to tune. After the install if you think something could be better or something is amiss then datalog it and email that file to Ted.
Red
R8E1D is offline   Reply With Quote
Old 12-06-2012, 08:22 PM   #10
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Lmao!
Ok I take it back.
OP congrats sir, welcome to modding. It gets better n better lol.
Old 12-06-2012, 09:14 PM   #11
Rigzo510
Thanks guys, ill probly be needing more help later on since this is the first car I've ever modded let alone cammed lol already feels like I'm addicted!!
Old 12-06-2012, 09:28 PM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
So your gonna do it yourself?!?!
Old 12-06-2012, 09:33 PM   #13
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
your gonna love it!
IDEALG is offline   Reply With Quote
Old 12-06-2012, 09:36 PM   #14
Camper
Banned
Drives: 10' 2SS LS3 M6
my only question is to why you purchased a SCT tuner with a cam upgrade?
you will need a dyno tune unless you are installing yourself?
Camper is offline   Reply With Quote
jre rough idle cam, lt headers
