Old 07-18-2013, 09:48 PM   #1
EncoreCamaros
EncoreCamaros's Avatar
Drives: 2010 Victory Red Camaro SS/RS LS3
Lsx engine built
Ive had my fathers '69 camaro laying around for a couple years and ive decided to finally start restoring it. Trying to build it for street/track since thats what it was 20 years ago. Buddy of mine had a 427 lsx block sitting in his garage so i thought it would be bad ass to throw a whipple on it for the car. Forged rotating assembly is obviously a must so i wanted to see what set up you guys are using... And what compression are you running?
ARH 1 7/8 headers catless 3'' long system, Whipple sc 4.00 pulley 9 lbs boost, msd boost-a-pump, CAI intake, Pfadt coilovers, toe links, trailing arms, solid cradle bushings, sway bars, Forgestar CF5 19x9.5/19x11, M/T et street II radials
EncoreCamaros is offline   Reply With Quote
Old 07-18-2013, 09:53 PM   #2
ls7camaro
Drives: 2010 camaro
LSX 427
Procharger F1C
CR 9.7-1
852whp on 12psi
Let me know if theres any more info that would help
ls7camaro is offline   Reply With Quote
Old 07-18-2013, 09:57 PM   #3
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
LSX416
Magnachager (for now)
9:1
621whp on 16psi (for now)
The whipple is a little small for a 427.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 07-18-2013, 10:12 PM   #4
Unreal
Drives: 2006 Z06
Long block or shortblock? You will want to figure out what heads so you order the correct whipple. Ls3 and Ls7 style heads take different blowers because of the different port shapes.
427 LSX with PRC 285CC LS7 heads
ECS Ysi Setup
Made 914rwhp on ~11psi.
Nick
Corvette Z06 -1200ish rwhp
Old 07-19-2013, 04:01 PM   #5
EncoreCamaros
Whos pistons, rods, and crank are you guys using?
Old 07-19-2013, 04:03 PM   #6
Unreal
Drives: 2006 Z06
Livernois pistons, Calles ultra rods, calles dragonslayer crank. Waited 8 months for crank, they are hard to get.
Going back I would have done a lunati pro crank, other than that the ultra rods and livernois pistons are top notch.
If the block doesn't have a rotating assembly then how is it a 427? Stroke of the crank will determine displacement. My 427 is a 4.125x4" but you could do a 4x4.125, or any other combo that comes out to a 427.
Nick
Old 07-19-2013, 04:22 PM   #7
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
HKE built LSX 427 (4" stroke x 4.125" pistons)
23cc dish wiseco blower pistons coated, 9.4 CR
Callies ultra billet I beam rods
Dragon slayer crank
Mast black label 305 LS7 6 bolt heads
Pat Guerra designed blower cam
Procharger D1SC (from OE motor) this blower is too small for the motor. Twin PTE 6766 turbos are in the plans
758rwhp/708rwtq at about 14psi......(Kurt Decker's Mustang dyno)
Tuned by Pat G
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 07-19-2013, 04:30 PM   #8
2SS45th
2SS45th's Avatar
Wiseco pistons, Callie's everything else. I have a Lunati Valvetrain as well.
Old 07-19-2013, 04:35 PM   #9
Chris@Livernois
Chris@Livernois's Avatar
Drives: 2010 Camaro
Originally Posted by ls7camaro View Post
LSX 427
Procharger F1C
CR 9.7-1
852whp on 12psi
Kyle I'm guessing you're LS7 Camaro! How is the car treating you so far?
Chris@Livernois is offline   Reply With Quote
Old 07-19-2013, 04:45 PM   #10
2SS45th
2SS45th's Avatar
I'd guess amazing
Sweet setup guys!
Old 07-19-2013, 05:40 PM   #11
EncoreCamaros
If the whipple is too small of a blower, what should I run? Vortech ysi or procharger f1 series?
Old 07-19-2013, 05:47 PM   #12
Unreal
Drives: 2006 Z06
First of all, different size whipples. If you have the 2.9L it will max out around ~800 or so i believe. You could upgrade to a bigger one but then fitting it becomes an issue.
Ysi/2200R/F1R are all good for 900-1050 or so. Great blowers.
Everyone by now knows I'm going to say go twin turbo. A pair of 61mms will be so much nicer and make more power than a Ysi. No belt issues, just tons of torque and power.
Nick
Old 07-19-2013, 06:09 PM   #13
BullF-16
BullF-16's Avatar
Nick, what makes you say 61s. I was leaning toward the PTE6766 journal bearing turbos from my research. My ultimate goal is between 1000 and 1100rwhp. Although I am having too much fun now with the D1SC. Its already ridiculous and i am finally ready to hit the road course now that my brakes are done. Do you think twins would cause even more heating issues with oil/trans/radiator temps? Im running a pretty stout Earls 16 row wide oil cooler and am concerned the twins would cause issues with heat on the occasional track day.
OP, look into the new F1X from procharger.
Old 07-19-2013, 06:11 PM   #14
Unreal
Drives: 2006 Z06
61s will make 1000, spool up quickly, and run good. 66 would be fine too if you want over 1200.
Then again for a 427 you would probably want the 1.06 a/r housings or something big.
It all depends on what you want.
Nick
