![]() Drives: 2014 Camaro SS/RS BRM Join Date: Dec 2013
TapShift..Any Real Use?
Guessing the Tapshift feature is more of an enjoyment/have to have thing then something to actually use on a daily basis.
Haven't touched it yet, and really see not need to use it. So if you are using it, is it just for fun..or real daily use? Thx |
Camo45th
Drives: 2012 Chevrolet Camaro 2SS 45th Join Date: Aug 2013
When you deactivate completely stabilitrack and pull the shifter all the way back to M, the car behaves differently. I always use it, more fun.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '12SS/2SS/45TH-'06 2500HD/Silverado Join Date: Jul 2012
Definitely for more fun. And let me tell you, it's way more fun than driving in auto mode. I use it when traffic is light and I have some room to move around.
Drives: 2018 ZL1 1LE Join Date: Jun 2012
It is a must at autocross to make the car hold the gear you want
#5 | |
I used to be Dragoneye...
Oh, and it's worth noting that the OE calibration for the automatic in 2012+ cars is improved...quicker responding and a little more performance oriented. |
#6 |
COTW 9/16/13
Drives: 2011 2LT/RS Camaro IOM Join Date: Jan 2012
With my tune my car runs better in sport mode but sometimes when I'm driving the car gets "stuck" in a gear revving high so i sometimes use the paddles to shift up.
#7 |
![]() Drives: 2012 Summit White 2LT/RS Join Date: Sep 2013
I use mine just for the fun of it, though I could see how being able to manually control and override which gear you're in (in most cases...) could be useful from a performance standpoint. I only ever get to use mine when I'm out on more rural roads, though I still don't feel very comfortable driving with it because I still don't really know what I'm doing as far as manual operation is concerned.
I have been driving in 'S' mode ever since I discovered that there WAS an 'S' mode though...
#8 |
dave eckhardt seabees
Drives: 2012 camaro 2 LT convertible Join Date: Jun 2012
I recommend a carter (CFD)shifter.believe me you will not regret it.I have had one for close to two years and appreciate it more every day.It gives you the luxury of an automatic and when you desire a stick shift without searching for the tapshift paddles when making a turn.search this forum for purchase and install details.
#9 |
Drives: Camaro 2SS/RS Join Date: Sep 2013
I love downshifting the car for upcoming stoplights and such, saves the brakes, right...
#10 | ||
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
IOW, if your thinking is that of a pure automatic transmission driver (don't need more than P, R, D) you aren't likely to use it very often, as it will feel like "extra work". But if you've got much of a manual transmission mentality (as you might get from driving other cars with MT, motorcycles, or maybe even "10-speed" bicycles), you'll be more apt to use it because you'd be somewhat accustomed to making shifts happen when you wanted them to happen. Most people do develop a "feel" for which gear is appropriate for the speed they're driving at. P.S. I manually shift most any automatic transmission car most all the time . . . on the rare occasion that I have to drive one in the first place. Norm |
#11 |
Use mine everyday. My ride is a daily driver…. Never driven in full auto, in this ride or ny 2011...
Also in auto you car will shift to 6th, even @ 30…. Lugging the motor IMO….
K&N cai..... WCC underhood lighting.... 1LE strut tower brace.... Custom painted Fuse box/engine covers & strut tower brace.... Pfadt 1.25 lowering springs.....Ghosted side markers..... |
#12 | |
thx |
#13 |
![]() ![]() Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
I get shift denied on the display sometimes but the car still shifts into what ever gear I want it to thanks to my Full tune. Sometimes it will drag the rear wheels for a second if you get carried away on the downshift. I have the larger aluminum paddles so searching for them is not an issue. It will lag on the up-shift if you miss the optimum shift point, but once you get used to when to shift it changes gear seamlessly. Well, not seamlessly as I break traction on shifts through third, fourth if its wet or cold.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
#14 |
I used mine almost daily and itmis very nice to have on the track, in fact i dont think youd be happy at all on a track without unless your drag racing.
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
