Old 04-09-2014, 09:33 PM   #1
oftenimitated
Drives: 2004 Honda Civic+2011 Camaro 2SS
Burning smell
2011 camaro ss with 8k miles. Bought in December. Stored over winter. --when I start it up after sitting overnight or for a day or 2 it smells like something is burning? What could this be?
I know the dealer said they put a synthetic blend oil in it which I will be changing this weekend but that wouldn't be the cause would it?
Any help would be great, thanks.
oftenimitated is offline   Reply With Quote
Old 04-09-2014, 09:36 PM   #2
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
probably due to a 'sloppy' oil change..
Old 04-09-2014, 10:04 PM   #3
Chevy_cowboy
Chevy_cowboy's Avatar
Drives: 2011 IOM 2SS/RS M6 Convertible
what does it smell like is burning? Oil, plastic, coolant? They all have pretty distinct smells, that would help track down where its coming from.
Chevy_cowboy is offline   Reply With Quote
Old 04-09-2014, 10:18 PM   #4
Bulldog3071
Drives: 2010 Camaro 2SS/RS LS3
why would u change from the synthetic oil it unless it's not Mobil one 5w 30
Bulldog3071 is offline   Reply With Quote
Old 04-09-2014, 10:29 PM   #5
LoneStar
LoneStar's Avatar
Drives: 2011 IOM Camaro
They probably spilled a little big of oil during the change. If so, it will smell until it burns off.
Because the dealer said they put synthetic BLEND in (which is a mixture of synthetic and dino oil), he probably wants something that's "full" synthetic.
LoneStar is offline   Reply With Quote
Old 04-10-2014, 12:30 AM   #6
oftenimitated
Smells like oil I would say but I didn't smell it when I got it in December it just started recently
And yes I'm changing the oil to synthetic because the dealer didn't use full synthetic
Old 04-10-2014, 12:40 AM   #7
derklug
derklug's Avatar
Drives: 12 Boss 302
Look over the engine compartment, and especially under the plastic covers. I have seen lots of times where mice drag things up onto the engine while it is stored over the winter. A nest of plastic on the exhaust is no bueno.
The biggest mistakes in life come when you know exactly what you are doing.
derklug is offline   Reply With Quote
Old 04-10-2014, 12:44 AM   #8
one~Bad~SS
one~Bad~SS's Avatar
Drives: 2011 2SS/RS CGM LS3
had this same thing happen in my Audi, try checking the battery, it could be a bad battery overheating..... hope this helps.
one~Bad~SS is offline   Reply With Quote
Old 04-10-2014, 10:51 AM   #9
RubberChicken
RubberChicken's Avatar
Drives: 2011 IBM 1LT w white Rally Stripes
The dealer should know to use only DEXOS oil in the Camaro.
RubberChicken is offline   Reply With Quote
Old 04-10-2014, 12:21 PM   #10
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
^ True but DEXOS is a synthetic blend not full Syn... Same thing happened to me. I just went full Syn this time. They put DEXOS in last time though it is only a Semi-Syn. Still meets the Warranty for the Camaro though. I was surprised the car didn't require Full Syn for warranty...
Cam
qcman is offline   Reply With Quote
Old 04-10-2014, 12:34 PM   #11
RubberChicken
Cam
I didn't know DEXOS wasn't full synthetic. For as much as the local Firestone charges for an oil change ($74.99 because they said DEXOS was expensive synthetic) you would think that was full synthetic. Luckily they have coupons that end up knocking that down to $55.
Old 04-10-2014, 02:05 PM   #12
qcman
qcman's Avatar
Or it might be that the only thing they have is a full syn that meets or exceeds DEXOS but if you get Dexos1 at the dealer it is a Semi for sure. I seem to recall getting full Syn in my company truck at a local oil change joint as thats all they sold that met it. But DEXOS is referred to as a synthetic blend...
Here DEXOS is $60 & full Syn is $89 I believe.
Cam
Old 04-10-2014, 02:31 PM   #13
LoneStar
LoneStar's Avatar
Dexos is just a standard that oils must meet to carry the "dexos" license of approval. There's a long list of oils that are dexos licensed, including both full synthetic and synthetic blend (not sure if any conventional oils have made the list). The brand(s) and type(s) of oil varies with different service departments (especially when they're independent from dealerships).
