Old 06-03-2014, 08:19 AM   #1
stoopid
Drives: 4 wheels
3.6L paper filter options
Any paper filter performance comparisons? I seem to recall someone doing a comparison of the various paper filters and Fram(?) might have come out on top.
Here's my rockauto options (I usually get parts from them):
http://www.rockauto.com/catalog/x,ca...arttype,6192,a
I figure with money dropped into extending my warranty precludes doing any serious modding or tuning, so slightly better air filter and premium gas will be it.
stoopid is offline   Reply With Quote
Old 06-03-2014, 08:37 AM   #2
stoopid
Drives: 4 wheels
Looking online there doesn't seem to be a lot of benefit between paper filters (and only nominal performance benefits with even the oiled/performance filters) .
Old 06-03-2014, 09:11 AM   #3
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Zl1 air filter flows slightly more.
Jason@JacFab is offline   Reply With Quote
Old 06-03-2014, 09:47 AM   #4
stoopid
Drives: 4 wheels
Interchangeable air filters? Interesting...
Cool, I see that now when I look online. K&N has the same part number for all engines/models of Camaro.
http://www.gmpartsdirect.com/results...umber=92229651
^^^ Looks like this is the part. $50 shipped is pretty steep (and the MSRP is a ripoff). Can I assume this is the cheapest option?
Old 06-03-2014, 10:35 AM   #5
BigRed585Lbs
Drives: Sierra and Tahoe
A suggestion:
http://afepower.com/shop/details_new...6L&&brandID=59
Prices vary.
BigRed585Lbs is offline   Reply With Quote
Old 06-03-2014, 10:43 AM   #6
stoopid
Drives: 4 wheels
Originally Posted by BigRed585Lbs View Post
Intentionally avoiding oiled filters.
Old 06-03-2014, 11:12 AM   #7
dmginc
dmginc's Avatar
Drives: In Circles
why avoid oiled filters?
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 06-03-2014, 11:36 AM   #8
BigRed585Lbs
OK on initial installation, but most people over-oil when it's time for them to be serviced and end up with MAF contamination issues. It's really about filtration/flow ratio, anyway. KIS for the average enthusiast.
JMO
Old 06-03-2014, 11:52 AM   #9
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Oiled filters have better filtration and do not have any downsides I can think of... They last forever so if you spend $50 on a K&N filter instead of $10 every, what, 20k miles? You do the math. lol.
Btw, light mods don't void warranty instantly. Particularly if you don't drive it like you stole it. I have the 7/70k, for example.
DSX_Camaro is offline   Reply With Quote
Old 06-03-2014, 11:59 AM   #10
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
That's why you get an air gun and blow off your dry air filters (;
TommyTheCat is offline   Reply With Quote
Old 06-03-2014, 12:03 PM   #11
DSX_Camaro
DSX_Camaro's Avatar
Pretty sure even if you blow them off, when you hold the paper filter up to the sun and can't see through it, you need a new one...
Old 06-03-2014, 12:12 PM   #12
stoopid
Drives: 4 wheels
Incorrect.
Old 06-03-2014, 01:58 PM   #13
BigRed585Lbs
If you can see through it, you've blown a hole in it and you do need a new one.
Oiled or dry, your choice.
Old 06-03-2014, 02:24 PM   #14
stoopid
Drives: 4 wheels
This has peaked my interest but I'd like to find it cheaper if possible. Any ideas/sources?
I found an AC Delco that appears to be the actual part (OE) on ebay:
http://www.ebay.com/itm/Air-Filter-C...-/221440197761
Amazon (I have prime, so $35 shipped is sweet):
http://www.amazon.com/ACDelco-A3177C.../dp/B007QC1CY8
I might splurge for this if I can verify it's the correct part...
Part verified as the ZL1 replacement OE. Ordered!
