Old 07-23-2014, 06:49 PM   #1
EvenPrime
EvenPrime's Avatar
Drives: 2014 ZL1 Convertible
Pulling Fuses 5 and 20 for a long trip ...
I heard resetting the cars brain by pulling fuse 5 and 20 was a good way to get more power out of your car as it tries to relearn your driving ability.
Just wondering, Im taking my ZL1 across western Canada approx. 2500km ~ 1000 miles. If I reset this, do you think this will increase my fuel economy?
Not that I really care a whole lot as I bought the car to enjoy but I will be driving at 110 km/hr for about 20 hours straight so I thought I'd ask the question.
Thanks guys.
ps. Once Im in the next city, I figure I'll pull it again, reset it, then go back to my aggressive driving
EvenPrime is offline   Reply With Quote
Old 07-23-2014, 08:05 PM   #2
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
If you used some cheap gas and the ECM shifted to Low Octane Spark table it would speed up returning to the High Octane Table by pulling the fuses. If you always use premium pulling the fuses is a waste of time.
So unless you got some cheap gas it is no help. It will learn like it's supposed to without any help.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 07-24-2014, 07:15 AM   #3
DRKS1D3
DRKS1D3's Avatar
Drives: '17 Corvette Grand Sport M7
It has nothing to do with the way you drive. As stated above, it is for getting your car back on the high fuel map (more power) after having low octane fuel put in it. If your car has never had low octane fuel in it, then it is worthless.
Read here: http://www.camaro5.com/forums/showthread.php?t=38964
MY RIDE: 2017 CORVETTE GRAND SPORT--TRIPLE BLACK, 7 SPEED MANUAL, VARARAM TCR-7 INTAKE, BORLA CATLESS X-PIPE, CARBON FIBER STAGE 2 AERO, MGW SHORT-THROW SHIFTER
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ
DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE
"Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!".
DRKS1D3 is offline   Reply With Quote
Old 07-24-2014, 12:39 PM   #4
EvenPrime
EvenPrime's Avatar
Ohh, ok thanks guys. I use 91 octane everywhere I go. I can't get 93 up here in Canada. It is really hard to find.
Appreciate the info.
[ The Physicist ]: d^2x(t)/dt^2 addict!
Old 07-24-2014, 01:06 PM   #5
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
Not sure if the fuse pull works on the LSA motor but pulling fuses is a good idea regardless if you run low octane fuel or not. Once the ECM senses knock for any reason it may go the low octane table and remain there.
MMC is offline   Reply With Quote
Old 07-24-2014, 01:42 PM   #6
ricky_ZL1
Drives: 2013 ZL1 Camaro
Will pulling the fuses mess with my new dynotune?
ricky_ZL1 is offline   Reply With Quote
Old 07-24-2014, 01:48 PM   #7
DRKS1D3
DRKS1D3's Avatar
Here, read this: http://www.camaro5.com/forums/showthread.php?t=301963
From what I understand, you should be fine.
Old 07-24-2014, 02:11 PM   #8
ZO6 Bryan
ZO6 Bryan's Avatar
Only if there was excessive amount of knock. Won't happen because of the infrequent few degrees that might be pulled at WOT.
Bryan 2018 ZL1 M6
Old 07-24-2014, 02:12 PM   #9
ZO6 Bryan
ZO6 Bryan's Avatar
No!
Bryan 2018 ZL1 M6
Old 07-24-2014, 02:23 PM   #10
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
If you have HP Tuners you can also go into the VCM scanner and just click reset fuel trims.
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance.
2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14)
jon6.0 is offline   Reply With Quote
Old 07-24-2014, 03:33 PM   #11
ZO6 Bryan
ZO6 Bryan's Avatar
That will reset fuel trims but not sure it will reset the "knock learn factor". Maybe. I might have to try it and see.
Bryan 2018 ZL1 M6
Old 07-24-2014, 08:48 PM   #12
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
Hmm. Good point.
Old 07-25-2014, 09:32 AM   #13
ricky_ZL1
Thanks for all the input! Looks like I'll try pulling the fuses tonight. I know the dealer put cheap shit in it when purchased.
