Old 10-05-2014, 12:17 AM   #1
extraurban
Drives: Junker
Apex catch can install with stock 1LE Oil Separator
Hey all,
Ran into some issues installing my catch can today as the stock 1LE oil separator return line to the stock airbox gets in the way of the front of the catch can.
For those who've run into the problem, did you just run regular rubber hose in place of the stock rigid line from the clean side? If so, how would i go about doing that?
extraurban is offline   Reply With Quote
Old 10-05-2014, 08:21 PM   #2
extraurban
Drives: Junker
Bump - anyone?
Old 10-05-2014, 11:57 PM   #3
xXSicSicSicXx
Drives: 14 1LE
i just installed mine like the directions said.. i just fed the aftermarket hose into the factory clean side hose so i could keep the factory separator as well. works just fine.. still catching oil.. no leaks. good mod.
xXSicSicSicXx is offline   Reply With Quote
Old 10-06-2014, 12:21 AM   #4
extraurban
Drives: Junker
Thanks, do you have the stock intake as well? That's where I'm having real estate issues.. If it's not too much trouble, could you post a picture when you get a chance? (I don't want to mess up the routing)
Old 10-06-2014, 06:31 AM   #5
xXSicSicSicXx
Drives: 14 1LE
at first i did.. now i have a rotofab cai. i've never tried posting pics on here, so we'll see if i can figure it out.
Old 10-06-2014, 10:32 PM   #6
extraurban
Drives: Junker
Thanks again Sic, I saw some pictures floating around and it looks like folks just use regular rubber hosing and clamp it on both ends, simple enough!
Old 10-07-2014, 03:24 AM   #7
yyapishido
Drives: ford
yyapishido is offline   Reply With Quote
Old 10-13-2014, 03:43 PM   #8
MikeAP
MikeAP's Avatar
Drives: 2013 1SS/RS M6
I am having the same issues, wish I would have seen this thread before I posted my own: http://www.camaro5.com/forums/showthread.php?t=380929
I am trying to find a work around for this also. I would guess we can just use rubber hose to make the connection.
Mike
MikeAP is offline   Reply With Quote
Old 10-13-2014, 06:47 PM   #9
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Mike
You nailed it. Just substitute rubber hose for the hard plastic lines.
Old 10-13-2014, 09:17 PM   #10
extraurban
Drives: Junker
Mike, the rubber hose method would work but I was hesitant to cut the existing plastic (paranoia, ocd, first mod, etc lol) but what I found was a good workaround, was to install the catch can first (disconnecting the stock separator lines completely), then reconnecting as there was less bend in the stock separator back to the intake
If you need pictures, let me know and I'll post em up.
Old 10-14-2014, 09:11 AM   #11
MikeAP
MikeAP's Avatar
Thanks APEX, but since I have the stock airbox there is a "snap in" type connector with an o-ring for the stock line. My guess is I should just cut the line and then attach the rubber line to that?
extraurban if you have a pic that would be very helpful. I am not sure I understand what you did. Did you use the stock line, I really don't want to cut mine either in case I ever get rid of the car and want to put it back to stock.
Thanks guys!!!
Mike
Old 10-14-2014, 09:37 AM   #12
Apex Motorsports
Correct.
Old 10-14-2014, 10:53 AM   #13
MikeAP
MikeAP's Avatar
Originally Posted by Apex Motorsports View Post
Correct.
Or maybe I just need to buy a new air-box. Know where I can get one. LOL
Old 10-14-2014, 11:07 AM   #14
Apex Motorsports
That works too.
