Old 01-08-2015, 02:51 PM   #1
370zyzfr1
Drives: 2014 Camaro Zl1 Tripple Black!
Best way to ship tires?
What is the cheapest way to ship tires?
Local shipping office wants nearly $400 to ship 4 tires! No way am I paying that.
Any ideas? Fedex wanted $250 for 4.
370zyzfr1 is offline   Reply With Quote
Old 01-08-2015, 04:51 PM   #2
hawk02
Coupe Newbie
hawk02's Avatar
Drives: '23 CT5-V BW, '21 Corvette HTC
I shipped 4 tires to Michigan via FedEx for just under $200 about a year and half ago. FedEx turned out to be the cheapest carrier of all the ones I contacted.
If you can ship to a business address instead of residence, FedEx will give a slight break on the cost.
hawk02 is offline   Reply With Quote
Old 01-08-2015, 04:54 PM   #3
Shrek
Shrek's Avatar
Drives: 2013 Camaro ZL1
If you can use a box it's usually cheaper. 2 in a box is the best and FedEx is by far the cheapest.
2013 Camaro ZL1 Black M6
Roto-Fab Intake, Apex Catch Can, Stainless Works 2" long tube headers with cat delete, Stainless Works 3" retro chambered catback, ATI Super Damper with 10% overdrive lower pulley, tuned by JRE. Sitting on Black MRR 228's wrapped in MT's.
Shrek is offline   Reply With Quote
Old 01-08-2015, 05:41 PM   #4
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
How far are you shipping? SpeeDee is freakin CHEAP.
Print a label, tape it around the tire, and send it out the door.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 01-08-2015, 05:48 PM   #5
Logan1234
Drives: 2014 ZL1
Another low cost option is Greyhound... they ship from one bus station to another.
Logan1234 is offline   Reply With Quote
Old 01-08-2015, 11:18 PM   #6
370zyzfr1
Shipping from iowa to ny. Sounds like I have some options. Trying to keep it under $100
Old 01-09-2015, 11:23 AM   #7
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Depending on the weight of the tires.. if you tape 2 together and they weigh less than 70 pounds it costs less because it becomes one "package" instead of 2. May want to look into this.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 01-11-2015, 02:47 AM   #8
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Just shipped two Pirelli's to Texas from Southern California for about $67
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 01-13-2015, 10:04 PM   #9
revobasher
revobasher's Avatar
Drives: 2013 ZL1
Yep. I have used them a few times.
2013 ZL1 - Blue Ray Metallic
JDP 850 Package
740hp/700tq @14lbs on E85
Build Thread
revobasher is offline   Reply With Quote
