Old 04-28-2015, 09:57 PM   #1
Grmrpr
Drives: 2013 Camaro SS LS3 2SS/RS.
Stock fuel pump and injectors not enough for E-Force supercharger
I have a E-Force supercharger, Roto-Fab CAI, Kooks 1 7/8th long tube catted headers, Borla ATAK exhaust on a 2013 Camaro 2SS RS. Went to get it dynoed and a tune and on the second pull had to stop due to it running to lean. The injectors and fuel pump was not feeding it enough fuel. The timing was on 7 which was way off and boost was at 11lbs. Still pulled 520 rwhp. Car now is at the shop getting the ZL1 fuel pump, ID 850 injectors and ADM fuel control model installed then back to the dyno and tuned. Was told it will be a completely different running engine once it's done. Anybody have the same problem with the injectors and pump?
Grmrpr is offline   Reply With Quote
Old 04-28-2015, 10:07 PM   #2
LTRS777
LTRS777's Avatar
Drives: 2014 Saleen 620 White Label #14-011
Kinda crazy they even tried running it at 11psi on stock pump and injectors...
'14 Saleen 620 White Label #14-011
ADM LSA Stage 1 Kit, ADM 2.75 Pulley, DEKA 63lb injectors,
ZL1 Fuel Pump, JLT 123MM Big Mouth intake, TSP 2" LTHs,
BW TB, 2.5" Catback, Scott Culbert/GEN3PERF tuned!
573WHP/557WTQ @ 10psi.
Build Thread Here: http://www.camaro5.com/forums/showthread.php?t=390708
LTRS777 is offline   Reply With Quote
Old 04-28-2015, 11:33 PM   #3
43Camaro
43Camaro's Avatar
Drives: [COTW 8/3/15] 2010 Camaro SS L99
I'm getting mine done Tuesday. I'm running shortys, cats, axle back and CAI. I'm guessing ill fair better than you did with the LT and full exhaust. Did you have high flow cats?
A Little bit of power. ALL WORK DONE BY ME!
Just added 2021 ZL1 1LE to the Stable!
https://www.camaro5.com/forums/showthread.php?t=418273
43Camaro is offline   Reply With Quote
Old 04-29-2015, 12:37 AM   #4
Grmrpr
I did have borla shorties, then switched to Long Tubes with high flow cats. My opinion is that the stock manifold is better than the shorties. After removing the shorties they look smaller in circumference than the stock take offs, just my opinion.
Old 04-29-2015, 12:40 AM   #5
Bo White
Bo White's Avatar
Im at 12psi and cam swap and need more than LPE twins.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 04-30-2015, 01:23 PM   #6
Ret Fuzz
Banned
Drives: 2010 Camaro
I have had no fuel issues since upgrading.
Ret Fuzz is offline   Reply With Quote
Old 05-11-2015, 11:38 AM   #7
Reelgrinder
Drives: 2016 SS
Should of posted before the work on fuel system.. by the time you do the ZL1 pump and adm or boosta pump your close enough to the livernois or lingenfelter dual pump price with way less performance.
with that being said i did same route and had to go to the livernois after wasting the money for Zl1..
I now need a squash or fore since I want e85 so if u want to cancel that setup I can sell you my 850s and livernois pump injectors are less than a year and pump is 3 mos old..
pm me
2016 SS with Eforce 2300
Borla Headers
Borla Atak
Reelgrinder is offline   Reply With Quote
Old 05-11-2015, 02:15 PM   #8
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
I had the same problem since I had LT headers on the car before the E-Force. I ran out of fuel at 6500. I added the ZL1 fuel pump and 72# injectors and every thing runs great now.
sscamaro is offline   Reply With Quote
Old 05-11-2015, 02:34 PM   #9
LSXBumblebee
LSX Bumblebee
LSXBumblebee's Avatar
Drives: 2014 LSX Camaro
Nice numbers
LSXBumblebee is offline   Reply With Quote
Old 05-11-2015, 04:25 PM   #10
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
+1
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-12-2015, 01:07 AM   #11
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Don't the 13 camaros come stock with the zl1 pump? Mine did but it's a 14 ss
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 05-14-2015, 06:58 AM   #12
ADM PERFORMANCE
Drives: Anything I want
Nope
Only ZL1 and 1LE
ADM PERFORMANCE is offline   Reply With Quote
Old 05-14-2015, 07:16 AM   #13
2010_camaro
My car is not a 1le or Zl1 and has the Zl1 pump. Guess they just did it in 2014.
Old 05-14-2015, 07:52 PM   #14
Grmrpr
Well the ID 850's, ZL1 fuel pump, and ADM FMC installed and got the tune and dynoed today. Pulled 558 rwhp. I was hoping for around 600 after spending 2k on parts and labor for 30 more horsepower from when it was dynoed with the stock fuel pump, injectors. Was told the E-Force generates so much heat that it was to much of a risk to go any higher on HP.
