Old 06-21-2015, 10:23 PM   #1
Tabloma
Tabloma's Avatar
Drives: Red ZL1
Anyone installed an oil catch can on a Z28?
I have 3 Elite Cans here and have installed them on Corvettes including a ZR1. Just wondering if any of you z/28 guys have done so, and where you mounted them. I know there is a small one like the ZL1's had on the intake tube but those are really small.
Tabloma is offline   Reply With Quote
Old 06-21-2015, 11:27 PM   #2
Z Beast
Z Beast's Avatar
Drives: 2014 Z/28 Ashen Grey Metallic
http://www.camaro5.com/forums/showthread.php?t=358472 ...Here you go
"The walls are white, the track is grey, the grass is green, and the sky is blue... your job is to keep them all where they belong." - Johnny Rutherford
Z Beast is offline   Reply With Quote
Old 06-22-2015, 07:50 PM   #3
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
YES! Elite is the one I used. I also had one on the clean side. removed it, it was not needed. It would be nice if I could mount in the cold air area so it will condense better like I did on my ZL1.
Skylane765 is offline   Reply With Quote
Old 06-24-2015, 10:48 PM   #4
Tabloma
Tabloma's Avatar
Drives: Red ZL1
Thanks, is the bracket mounted to the head? The Hockey stick bracket?
Install looks great!
Old 06-25-2015, 07:24 AM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
yes...you can see bracket is bolted to the head. It also appears to be the hockey stick bracket.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 05-03-2016, 04:11 PM   #6
hollywdv
hollywdv's Avatar
Drives: 2015 Camaro Z/28 - Silver
reviving an old thread..
for those that have a catch can, how much blowby are you getting?
hollywdv is offline   Reply With Quote
Old 05-03-2016, 04:16 PM   #7
DemonZL1
199
DemonZL1's Avatar
Drives: like a granny
My catch can is catching a lot of oil.
2024 Silverado ZR2 LZ0 Duramax
2021 Shock SS 1LE A10
www.youtube.com/@demonworksmotorsports
Anderson composites coupon code : Demon
DemonZL1 is offline   Reply With Quote
Old 05-03-2016, 04:23 PM   #8
D2M
D2M's Avatar
Drives: Z/28
Idk if a can is necessary with a dry sump as the dry sump tank is baffled and would act as sort of a catch can keeping oil vapors to a minimum. At 4k miles and a few track days I removed my throttle body to see how much oil deposits were inside the intake. I found nothing, very very minor black deposit on the back side of the throttle plate near the shaft, barely visible.
D2M is offline   Reply With Quote
Old 05-03-2016, 07:58 PM   #9
JTRATX
Drives: 17 SS 1LE, 14 Yukon Denali
I just drained mine after about 2500 miles and numerous track days. Drained at least 3-4 ounces. I was surprised how much there was.
JTRATX is offline   Reply With Quote
Old 05-03-2016, 10:09 PM   #10
hollywdv
hollywdv's Avatar
3-4 ounces seem a lot but you've had numerous track days. is this with 15w50?
i might pickup the elite can with the hockey stick bracket. I don't think I've seen any other applications for the Z?
Old 05-03-2016, 11:44 PM   #11
JTRATX
Yes to the oil.
Sent from my iPad using Tapatalk
Old 05-07-2016, 11:29 AM   #12
exboss
Drives: 2015 Z/28
need some help. i'm new this chevy thing and understanding what is going on with a blow by can. why is it necessary? where is the oil coiming from and if you don't have a can what happens? what do you see? I just took my car on the track for the firsdt time and had to cut it short because I have oil leaking all down the front of my motor. if I have no can am I seeing the results of it?
many thanks. super concerned and my local chevy dealer is clueless.
exboss is offline   Reply With Quote
Old 05-07-2016, 12:11 PM   #13
Tmick5jr
Todd
Tmick5jr's Avatar
Drives: 2012 Camaro
take it to a different dealer. Also, your question about the catch can will be answered if you just search the forum. its been explained many times. you wouldn't have 10000's of people raving about it and buying it if it didn't do anything.
Tmick5jr is offline   Reply With Quote
Old 05-07-2016, 12:29 PM   #14
Hunt-man
Drives: 2015 Z28 + Piper Comanche
I wonder why we need a catch can. I searched this forum and only found the two threads, this one and the one that is mentioned above.
So why do we need a catch can or do you have a link to the answer?
Hunt-man is offline   Reply With Quote
