Old 06-11-2016, 02:01 PM   #1
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Tach wire at coil pack harness?
Anyone know if there's a tach wire at either of the coil pack harnesses? Trying to install a shift light and would much rather tap the lingenfelter harness rather than my factory harness. Not to mention I could use the wire loom for a cleaner install. Note, wire must NOT be positive and must be negative
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 06-11-2016, 02:07 PM   #2
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
Just trace the pink wire from the factory cool harness to the Lingenfelter harness.
Trob85 is offline   Reply With Quote
Old 06-11-2016, 05:02 PM   #3
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
I read the pink wire was positive, not negative
Sent from my Nexus 6P using Tapatalk
Old 06-15-2016, 12:28 AM   #4
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
no other takers? Guess i can t-tap at the ecu, just was looking to utilize wire looming that I already had in place
Old 06-15-2016, 01:28 PM   #5
williamp78
williamp78's Avatar
Drives: 2011 2ss blk/wht strp
I used the trigger wire that runs to the #1 coil pack for an RPM reference for my trans controller. I'm not sure how it will work for a shift light. The update rate is slightly slower than the actual rev.
2011 2ss black/wht stripes
"CAM only"
https://www.instagram.com/w_j_p_boss/?hl=en
williamp78 is offline   Reply With Quote
Old 06-15-2016, 01:32 PM   #6
williamp78
williamp78's Avatar
http://i40.photobucket.com/albums/e2...chematic-1.gif
I think this is what i used to figure it out. Id have to go look when i get home
"CAM only"
Old 06-15-2016, 09:58 PM   #7
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
So, would pin B be what I'm looking for?
Old 06-16-2016, 07:20 AM   #8
williamp78
williamp78's Avatar
I'm 99% sure that's what I used. But I forgot to look last night at the car.
"CAM only"
Old 06-16-2016, 09:15 PM   #9
williamp78
williamp78's Avatar
Ok so if you pull the connector. Looking at it with the clip up. 2nd pin is where it's at. Brown wire on mine.
"CAM only"
Old 06-17-2016, 12:06 AM   #10
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Perfect. Thanks for checking it out for me!
Old 06-17-2016, 07:29 AM   #11
williamp78
williamp78's Avatar
No. I think it's a 1 pulse for 2 rev signal
"CAM only"
Old 06-28-2016, 08:12 PM   #12
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
I have a bypass module for a remote start that spits out a tach signal to let the remote start know if A: the car is running and B: if the car over-revs. Wonder if this is an adequate signal for a shift light. Wouldn't even have to poke through the firewall
