Old 06-17-2008, 04:55 AM   #1
Bumble Bee '77
AutoBot Scout
Drives: 2002 ZRS Camaro
Extra power
Does anyone know of a product that can be used to run the stereo with the car off for long periods of time that wont drain your battery?
Bumble Bee '77 is offline   Reply With Quote
Old 06-17-2008, 08:53 AM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
an extension cord
I piss excellence
and fart awesomeness
Old 06-17-2008, 09:01 AM   #3
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
Old 06-17-2008, 09:09 AM   #4
Chevyrocker
Weekend Rockstar
Drives: Depends on the day...
Go to Best Buy, I forgot what it's called, but it does exist...
Chevyrocker is offline   Reply With Quote
Old 06-17-2008, 10:57 AM   #5
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
A second battery?
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 06-17-2008, 11:04 AM   #6
AFSNightrod
Back in Black
AFSNightrod's Avatar
Drives: 2005 Cadillac CTS-V
Send a message via AIM to AFSNightrod Send a message via Yahoo to AFSNightrod
LOL on the extention cord. Best bet would be a yellow top optima battery and a capacitor to run between your amp and battery. A capacitor basically holds a charge like a second battery. It basically works to keep your huge amp from having such a drain on your battery so your battery can run the rest of your car. By no means am I a car audio expert(big stereos just add weight), but that's the way it was explained to me in layman's terms.
AFSNightrod is offline   Reply With Quote
Old 06-17-2008, 12:03 PM   #7
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
an extension cord
I was thinking a second battery
A second battery?
And there it is!
The capacitor is, from the way I understand it, only good for when the car is running to prevent the battery from draining and alternator working overtime.
Old 06-17-2008, 01:05 PM   #8
Bumble Bee '77
AutoBot Scout
Will a trickle charger hooked to the bat work in these cases? I only ask cause my bat died when i provided music for the titus will show and had to get jumped by IrocZlover lol
Old 06-17-2008, 01:37 PM   #9
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
AFAIK, the huge capacitors used for automotive stereo systems are mostly worthless (like ricers with big wings). In some cases they are worthwhile; such cases would be the cars whose headlights you see dimming to the beat -- every time the bass plays, the lights dim.
A capacitor is a short-term, low-capacity electric storage device. It holds a little bit of power, and releases it very quickly when needed. That's all. It won't help make a battery last longer after shutting the engine off.
If the charger is putting out as much power as the stereo is using, yes, it will work.
There's also the second battery idea, or just watching the volt meter and starting the car before it runs dead.
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 06-17-2008, 02:23 PM   #10
SKiZZ
Drives: 1998 S-10
It's called a second battery and a battery isolator. They run from about $50-$250 for the isolator alone.
SKiZZ is offline   Reply With Quote
Old 06-17-2008, 02:27 PM   #11
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
If you wanted to make a do-it-yourselfer, couldn't you buy a 12-volt power converter, and just wire the head unit and amps to it? (disconnecting them from the car)
Just a dumb question. I like jury-rigging things, so it crossed my mind. I wondered if it was even possible.
Old 06-17-2008, 02:56 PM   #12
theholycow
theholycow's Avatar
Yes, any source of 12 to 14 volts (with enough current, obviously) will run the stereo fine.
Old 06-17-2008, 07:31 PM   #13
z28camaro2471
C5 Member #227
z28camaro2471's Avatar
Drives: Camaros
If your battery is good and charging system is functioning properly, just start it for 5 minutes every couple of hours. It always worked for me.
Or always buy manual transmission cars and park on a hill facing down!
z28camaro2471 is offline   Reply With Quote
Old 06-18-2008, 01:34 AM   #14
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
Complete and utter truth, with some unvarnished opinion. YES they are used when they are not needed a lot, BUT they do serve a purpose and used properly will improve a systems performance.
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
A little more pricing reassurance. Grape Ape Camaro Price | Ordering | Tracking | Dealers Discussions 34 04-22-2008 09:05 AM
Pricing/optioning guesstimate KILLER74Z28 Camaro Price | Ordering | Tracking | Dealers Discussions 156 02-24-2008 05:33 PM
JD Power survey: Younger Buyers Avoiding Domestics Scotsman General Automotive + Other Cars Discussion 6 12-04-2007 02:31 AM
Yeeha!! 2008 Corvette Gets Big Boosts of Both Power and Torque frodo General Automotive + Other Cars Discussion 24 10-02-2007 03:20 PM
GM working on hybrid power plug-in for Saturn Vue KILLER74Z28 General Automotive + Other Cars Discussion 0 11-29-2006 03:40 PM
