Old 10-29-2009, 01:21 PM   #1
Mike's LazruSS
Drives: 2SS/RS, Black, CGM, Black int.
Bulletin re AFM
GM has release a document regarding the "Droan" (Geez, I wish they at least knew how to SPELL it if they don't know how to FIX it). But I am puzzled. The bulletin tells the dealer to "manually shift the transmission to disable AFM" when most of us who have the problem believe AFM remains active whether we are in "D" OR "M." I know I have the problem either way. I think it is clear after reading many threads and posts on this, that some cars are badly affected, and some have little if any problem at all. Anyone have any insight on the instruction to have the dealer disable the AFM and re-evaluate? If I though my dealer could disable AFM, I'd just have him leave it disabled!!
Mike's LazruSS is offline   Reply With Quote
Old 10-29-2009, 01:51 PM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
the dealer wont permanently disable AFM.
I piss excellence
and fart awesomeness
Old 10-29-2009, 02:07 PM   #3
kelleyperformance
kelleyperformance's Avatar
Drives: DD- 15' Chevy SS Sedan
the dealer CANT disable AFM
kelleyperformance is offline   Reply With Quote
Old 10-29-2009, 02:24 PM   #4
wrek
2G1FK1EJ6-9
wrek's Avatar
Drives: 2010 Camaro 2SS RS Transformer
I have no problem with AFM and I swear I cannot hear it.
wrek is offline   Reply With Quote
Old 10-29-2009, 02:52 PM   #5
Mike's LazruSS
Exactly. So why does the GM bulletin tell him to do so (disable the AFM)?
Old 10-29-2009, 03:43 PM   #6
coolman
Guest
I don't have the l99 but I've had cars with afm and I never seen one that stays active when you switch into manual. I had I chrysler 300c and I would drive in manual just so It wouldn't turn on. Is their an icon that tells you when it's turning on and off. The 300 say fuel saver mode when it's dropping back?
coolman is offline   Reply With Quote
Old 10-29-2009, 04:08 PM   #7
MikeZ28
Drives: '04 GTO, '00 Z28, '95 Z28
Somebody in a different thread said that if you are in S6, and you use the paddles to kick it down to 5th and then back to 6 again, it will disable the AFM. I have no idea if that's true, but it's what at least two members have said.
MikeZ28 is offline   Reply With Quote
Old 10-29-2009, 04:17 PM   #8
Mike's LazruSS
Have tried that repeatedly in my car at multiple speeds, and it does not work in my car. Trust me, in my car, you can tell!
Old 10-29-2009, 04:27 PM   #9
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
I'm with Mike above. On the SST Camaro, the "drone" was almost undetectable with the stock exhaust. The minute I switched to the Stainless Works exhaust, it was a major annoyance when the AFM kicked in. Sounded like a rice-burner with a megaphone pipe. I put in in every mode possible ( I usually manually paddle shifted it anyway) and it would always revert back to AFM in the higher gears and/or at lower engine RPMs with no/low load. :(
Old 10-29-2009, 06:11 PM   #10
camarotoofast
VIN #586 is Home
camarotoofast's Avatar
Drives: 00 Z28 Camaro 69 camaro 81 cam
Send a message via Yahoo to camarotoofast
Mine is the same way with stainless works. When iam in 3rd in manual mode it gets real ricey sounding but S.W. sounds good when AFM is not on
VIN # 586 is home
1ss,blk/blk,poilsh rims,B.A.upgrade,a6,stainless works catback.vararam more-to-come
camarotoofast is offline   Reply With Quote
Old 10-29-2009, 07:48 PM   #11
SleepWarz
Banned
Drives: 1991 New Yorker, 69 Tbird, ABM2SSRS
I'd sell my car if it sounded like a ricer.
SleepWarz is offline   Reply With Quote
Old 10-29-2009, 08:36 PM   #12
Days75
Days75's Avatar
Drives: 2010 VR 2SS A6
I have the muffler delete and don't hear it at all.
Days75 is offline   Reply With Quote
Old 10-29-2009, 09:23 PM   #13
Kamaro4437
Kamaro4437's Avatar
Drives: 2 64 1/2 coupes and 66 fastbac
I have had no issues or noticed anything at all no change in motor at all from cruising to haulin ass i hear no differences.
Kamaro4437 is offline   Reply With Quote
Old 10-30-2009, 11:00 AM   #14
SS-screamer
Drives: SIM RS/SS L99
Mine sounds terrible in 4 cylinder mode and makes a burping noise when it kicks back into 8 cyl mode. Mine stays active in all modes UNLESS I down shift in manual; then it stays off. I bought an auto to drive an auto not feel forced to manually shift b/c of how bad the car sounds.
SS-screamer is offline   Reply With Quote
AFM L99 JoshJ81 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 09-30-2009 05:08 PM
Just got off the phone with Borla! L99 + AFM look here HeavyD Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 09-17-2009 03:05 PM
Competition CAMS nearly ready to release their L99 cams for the VVT AND AFM! PatrickfromMD Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 32 07-30-2009 06:46 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
AFM v8 Engine The80sman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 06-13-2008 11:19 AM
