Old 11-15-2009, 08:27 PM   #1
francone13
francone13's Avatar
Drives: 2010 Camaro 2LT/RS
Winter storing question...
Now iv read all the winter storing threads and they have been a great help to pointing me in the right directions for storing my first car...I got 1 question..Iv read that it is bad to start the car wile being stored due to condensation in the engine... Now we only have a 1 car garage and i will occasionally need to move my car out to bring my dads/sisters/brothers car in the garage to perform maintenance on them....what would be the best solution to avoid condensation...will letting the car run for a good half hour and reaching operating temp help?
francone13 is offline   Reply With Quote
Old 11-15-2009, 09:06 PM   #2
Wikedwil
Co-founder of CDCNY
Wikedwil's Avatar
Drives: 2016 Camaro 2LT Hyper Blue
Try some Marvel Mystery Oil in your gas. Truckers say it works.
Wikedwil is offline   Reply With Quote
Old 11-15-2009, 09:31 PM   #3
FarmallsForever
FarmallsForever's Avatar
Drives: 2000 Silverado, Slightly Modded
For a diesel engine, yea. Not a gasoline one.
Cowboy's Rules
1) Never slap a man who's chewin' tobacco.
2) Never kick a cow chip on a hot day.
3) Always drink upstream from the herd.
4) Don't squat with your spurs on.
Knowledge is power and power corrupts, Therefore study hard and be evil.
One man's "magic" is another man's engineering. Robert A. Heinlein
FarmallsForever is offline   Reply With Quote
Old 11-15-2009, 10:15 PM   #4
garfin
Resident Disciple
garfin's Avatar
Drives: 2010 CTS-V 6MN '98 Camaro SS (Sold)
If you're thinking to fire the car up during the winter, don't bother unless you're gonna get it out on the road for 15-20 min. or so and bring all the fluids up to operating temperature. Starting it up for a minute or so just to back it out of the garage and then doing the same thing a few hours later to put it back in will do the car no favors.
Wait for dry days and take the car out on the highway for a good 30-45 minute boot. I've been doing this almost from the beginning with my '98 SS during the winter. No problems at all.
It's a bit scary though, when you take off the oil filler cap and see all sorts of gray sludge on the inside of it after thinking it's OK to start it up and just let it idle for 10 min., once a a week or so when it's off the road for the season.
The differential fluid also needs to be brought up to operating temp as well. This won't happen if the car is not driven.
... and remember to run the A/C for 5 min. or so in order to keep the seals in the system lubricated.
Last but not least, keep in mind that even if the roads are dry, your summer tires will have only a fraction of their usual grip in the cold weather - so just go easy on throttle, steering and braking inputs.
I really do look forward to getting the car out for a run on those cold, dry days - it definitely rejuvenates the spirit!!
Best regardSS,
Elie
2010 Cadillac CTS-V 6MN Thunder Gray
1998 Camaro SS # C079 SOLD
garfin is offline   Reply With Quote
Old 11-16-2009, 09:37 AM   #5
hollywoodjose
hollywoodjose's Avatar
Drives: 2010 Black 1LT
Does tha ac need to be run if you are not driving? Also I got a battery tender , do I remove the battery or can I hook up the tender under the hood and leave the battery in place?
hollywoodjose is offline   Reply With Quote
Old 11-16-2009, 10:58 AM   #6
garfin
Resident Disciple
garfin's Avatar
The idea of running the A/C is to keep the seals lubricated. It doesn't matter if the car is being driven or not. I believe the compressor comes on, even in the colder weather when the defrost setting is selected.
I've never used a battery tender. I leave the battery in and hooked up while the car is in the garage. No problem starting it, even if left for a couple of weeks.
Best regardSS,
Elie
Manual or Auto?--resale value question armando416 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 33 01-17-2012 09:06 PM
5th gen Winter Tires Tomash Wheels and Tires Talk Sponsored by The Tire Rack 27 03-26-2010 08:28 PM
Question about storing for the winter (my situation) tommygun6644 5th Gen Camaro SS LS LT General Discussions 4 11-08-2009 01:05 PM
Insurance coverage when storing for the winter? armando416 5th Gen Camaro SS LS LT General Discussions 8 11-07-2009 08:33 PM
5th gen and winter driving rray200 5th Gen Camaro SS LS LT General Discussions 28 03-08-2007 02:55 PM
