Old 12-09-2009, 10:29 PM   #1
Heelhook22
Heelhook22's Avatar
Drives: 2010 Black SS
Correct tire pressure
Hello Team,
New to the forum! At any rate I noticed that when I picked up my car that the wheel pressure was different for the front of tha car and the back (front-38psi, back-36psi). Now I do have the RS package so I am aware that the front wheels/tires are smaller in the front than the back (20x8 vs 20x9). The sticker on the inside of the doorjamb says the pressure should be 36psi for all 4 tires.
I'm inclined to go with the sticker pressure for the tires, but wanted to know if anyone noticed the same pressure differences when they got their car. Just curious.
Cheers,
Heelhook
Heelhook22 is offline   Reply With Quote
Old 12-09-2009, 10:41 PM   #2
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
You can't go wrong sticking with the sticker. 36 all around is correct.
Old 12-09-2009, 10:50 PM   #3
Abygale
Abygale's Avatar
Drives: .
Welcome Heelhook
First thing you may want to do is follow the procedure on page 9-60 of the Owner's Manual and have your Driver Information Center (Dic) "learn" the pressure of all four tires. Then you want to also check them with a good gauge, preferably one that goes up to 60 psi.
Once you have an accurate reading of the current pressure in each tire, you want to get them to 36 psi when it's cold, not after you've been driving around for a while! You may know all this already, but I didn't when I first got the car.
Welcome again!
P.S. Another thing that some of us have done is to replace the regular compressed air with nitrogen. That eliminates some of the wide variation in tire pressure due to temperature changes.
Abygale is offline   Reply With Quote
Old 12-10-2009, 04:51 PM   #4
Heelhook22
Heelhook22's Avatar
Thanks for the input. I will pour over my manual as soon as I get home!
Cheers,
Heelhook
Old 12-10-2009, 04:56 PM   #5
At first I thought 36 seemed to be to much, but I guess it must be because of the 20 inch wheels.
Old 12-10-2009, 05:10 PM   #6
2010 2-Tone
Drives: 2010 RY 2SS with Custom Stripes
Originally Posted by Abygale View Post
Welcome Heelhook
Welcome again!
You go Abygale!!!!!
2010 2-Tone is offline   Reply With Quote
Old 12-10-2009, 06:26 PM   #7
med247
Drives: explorer
i notice my seem to be low almost once a month is this normal..anyone else notice this too. seems like i make them 36 then they are 32 or so within a few weeks
med247 is offline   Reply With Quote
Old 12-10-2009, 06:30 PM   #8
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Wow nitrogen!? I've never heard of that. Where do you pump that? Not at any 7-11 around here for sure.
Infern0 is offline   Reply With Quote
Old 12-10-2009, 06:51 PM   #9
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Ultimately you should inflate the tire as per the tire manufacture. There should be a max pressure rating on the side wall of the tire.
HeavyD is offline   Reply With Quote
Old 12-10-2009, 07:33 PM   #10
bigd1276
2017 HyperBlue 2SS
bigd1276's Avatar
Drives: 2017 HyperBlue Camaro 2SS
I was just at Goodyear Tire today and they were offering $5 per tire for nitrogen. Anyone out there do it? Does it mess up the Tire pressure system?
http://www.camaro5.com/forums/showthread.php?t=30755
2010 IBM 2LT RS......Traded for.....
2012 IBM 2SS RS......Traded for.....
2017 HBM 2SS
bigd1276 is offline   Reply With Quote
Old 12-10-2009, 07:47 PM   #11
dagolfguy
dagolfguy's Avatar
Drives: 2010 Camaro 2LT RS
HeavyD
You may be correct, but my information differs.
I've checked with the tire folk for both my car and my motorcycle, and both have said to me that the correct pressure is that which the vehicle manufacturer says is the right spec for the car, truck or MC.
These are my $.02, have a great day.
-Dave
dagolfguy is offline   Reply With Quote
Old 12-10-2009, 08:07 PM   #12
CamaroFemme
CamaroFemme's Avatar
Drives: 2010 Black Camaro 2SS/RS
I'd just like to add that the handsome, intelligent, and sexy Doc has stated that the manual is being cautious with the number and that 38 will give you a smoother ride & more mileage.
My boyfriend don't mind it.
CamaroFemme is offline   Reply With Quote
Old 12-10-2009, 08:14 PM   #13
VT2CA
Drives: 2010 1LT CYBER GREY
Costco have Nitrogen air pumps, many tire places do not recommend Nitro tho as it drys out the tire from the inside out, can cause premature cracking and deterioration of the rubber in a place where you wont see it happening.
VT2CA is offline   Reply With Quote
Old 12-10-2009, 08:36 PM   #14
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Well that doesn't sound good. And the only benefit being air pressure fluctuation is reduced?
Another Issue. Tire Monitor System!!! JewelZ Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 11-11-2009 10:07 AM
Help with tire pressure monitor bigkahuna4444 Wheels and Tires Talk Sponsored by The Tire Rack 0 10-29-2009 01:16 PM
500.00 per perelli tire not a myth! AVman Wheels and Tires Talk Sponsored by The Tire Rack 51 10-20-2009 04:45 PM
Tire Pressure Problems Matster Canada 14 10-03-2009 07:11 AM
WHAT A NIGHTMARE!!! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 110 09-27-2009 12:25 PM
