Old 08-04-2008, 02:03 PM   #1
Silverado
GM Guy For Life
Drives: 2010 GMC Yukon XL
Just a quick comparison.....
I was reading part of Motor Trend earlier today and noticed something. So, I did a few calculations.....
They are currently "flogging" a Lexus IS-F in their long term fleet. They mention that it weighs in at 3806lbs and has 416HP. It also gives them a 0-60 time of 4.3 seconds.
Okay, you all see where I'm going for sure, but follow me.....
That gives the Lexus a 9.15lbs/HP rating.
From the specs document in the other thread...
The SS with the Auto is 3913lbs, 400HP = 9.78lbs/HP
The SS with the Manual is 3860lbs, 422HP = 9.15lbs/HP
Now, I know gearing and such play a big role in performance (the "little" Lexus uses an 8-spd tranny, so it could have a big gearing advantage), but it stands to reason that the Camaro will be able to put up some solid numbers right off the dealer lot.
Silverado is offline   Reply With Quote
Old 08-04-2008, 02:08 PM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I don't think another two gears will necessarily give it an advantage. Remember, everytime you apply power through higher gear ratios, you actually loose a little bit of power. That, and I think everytime the tranny shifts, there is a delay in power, so it would seem to me, the more gears you have, the more time is spent shifting, which means there is a little less time power is being applied to the ground... Not to mention if GM tunes the converter a little looser, it will be in it's powerband more, and there will be less RPM drop between shifts (it's known as shift extension.)
Regardless, I believe an automatic V8 will be pretty close to those times posted.
'20 ZL1 Black "Fury"
Old 08-04-2008, 02:14 PM   #3
Silverado
GM Guy For Life
I was meaning more that the Lexus could have a much shorter first gear giving it a better launch while still having the much taller high gear for top speed.
Also noticed that the Lexus is rated at 16/23 for mpg with the 8 gears. The AFM apparently offsets those extra gears in that aspect, since the Camaro is supposed to get 23mpg highway.
Old 08-04-2008, 02:17 PM   #4
The_Blur
Moderator
The_Blur's Avatar
Those estimates are intended to be conservative, just like horsepower numbers. Expect GM to squeeze another mile per gallon out and maybe a couple horsepower. It will be a very lucrative V8 in comparison to those already out.
warn 145:159 ban
Old 08-04-2008, 02:23 PM   #5
Silverado
GM Guy For Life
I agree, I was just using the Lexus' numbers since they were very current to gage the Camaro's performance. I think we will all be very happy with both the acceleration and mpg numbers.
Old 08-04-2008, 08:39 PM   #6
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I think you are right!
Old 08-04-2008, 08:43 PM   #7
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
But wheres my 13 second turbo six? Thats what I'm really looking forward to.
- Xanthos
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 08-04-2008, 09:40 PM   #8
stovt001
stovt001's Avatar
Drives: 2006 Cobalt, 2004 Taurus wagon
Yup. There are a few cars out there with similar specs (but not similar price!) that you can use to estimate performance (the main variable being aerodynamics). I've said before, I'm pretty sure GM is underpromising/overdelivering on performance.
"It's kind of fun to do the impossible" - Walt Disney
There's a great big beautiful tomorrow
shining at the end of every day
Just a dream away
stovt001 is offline   Reply With Quote
Old 08-04-2008, 10:15 PM   #9
kevin2323
Drives: challenger
camaro will not do 4.3 it at the lowest will do 4.5-4.6. The lexus has an 8speed that is the main advantage.
kevin2323 is offline   Reply With Quote
Old 08-04-2008, 10:16 PM   #10
JEFF2010SSMANUAL
JEFF2010SSMANUAL
JEFF2010SSMANUAL's Avatar
Drives: IOM 2SS/RS LS3
GM is doing what BMW usually does.
But traction is very very important.
The SS manual has launch control. It might help the SS manual 422HP LS3 do 0-60 in 4.5, 1/4 in 12.9. I HOPE SO.
I will be very satisfied if the SS/RS manual 422HP Camaro does 4.6 to 60 and a very low 13 1/4 mile. Thats plenty fast IMO.
JEFF2010SSMANUAL is offline   Reply With Quote
Old 08-05-2008, 08:53 AM   #11
Beelzebubba
cheap plastic member
Beelzebubba's Avatar
Drives: Mazda6s
An eight speed that shifts VERY fast for a slushbox.
Beelzebubba is offline   Reply With Quote
Comparison Test, by Proxy: 2010 Chevrolet Camaro vs. 2009 Dodge Challenger SRT8 AirGoya Chevy Camaro vs... 86 07-24-2008 11:20 AM
Quick question for everyone. AnEvilPenguin 5th Gen Camaro SS LS LT General Discussions 35 07-16-2008 05:48 PM
2009 Camaro / C5 Corvette performance comparison markhoran 5th Gen Camaro SS LS LT General Discussions 12 07-02-2008 09:46 PM
New Member, Quick Question NateZ 5th Gen Camaro SS LS LT General Discussions 10 10-11-2007 10:59 AM
Porsche Turbo/Gallardo/Z06 comparison Mindz General Automotive + Other Cars Discussion 17 08-15-2007 12:47 AM
