Old 01-21-2010, 03:42 PM   #1
Monte
Drives: '88 Monte Carlo SS, '10 Camaro SS
Stock LS3 Dyno
Went to the shop I used to work at and hit the dyno with 550miles on the car. I saw 348Hp, 355 Ft/lbs on two runs back to back (+/- a few ponies). It is a Land and Sea dyno that gives VERY accurate numbers that always match the physics when the car goes to the track.
Monte is offline   Reply With Quote
Old 01-21-2010, 05:34 PM   #2
nhra stocker
nhra stocker's Avatar
Drives: 69,10 camaro 71 chevelle
Im still trying to figure out the whole chassis dyno thing. From the sound of things ive gathered Dyno jet is the most accurate due to less variables and being an inertia type? Others such as the Mustang and Dyna are more for tuning purposes? I wish there was a sticky on the LS-3s for dyno pulls , but thumbing back thru Ive seen anything from 340s up to a 384 rwhp! Im sure weather conditions play a factor too , how the car was broke in and if it was corrected or not. Does anyone have some good info on this?
2010 Camaro SS RS M6 Bone stock 12.58 at 110mph http://www.camaro5.com/forums/showpo...&postcount=263
1971 Chevelle SS 454 365hp NHRA C/SA 10.73 at 122
1969 Camaro (427 ZL-1 clone) M-22 being built
1982 Siverado 4x4 454 Mud truck stock class 3.66 sec in 150' of mud
nhra stocker is offline   Reply With Quote
Old 01-21-2010, 05:59 PM   #3
2SSRSPILOT
Drives: 2010 2 SS RS IMP.BL.MET. GRND.EFCT.
How does GM get away with advertising 426 hp but it never dyno,s at that ???
2SSRSPILOT is offline   Reply With Quote
Old 01-21-2010, 06:02 PM   #4
irvinecamaro
Drives: Used to be 2010 2SS
I believe the advertised 426 hp is at the fly wheel not at the rear wheels.
irvinecamaro is offline   Reply With Quote
Old 01-21-2010, 06:10 PM   #5
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
All manufacturers give hp rating at the crank.
Old 01-21-2010, 06:16 PM   #6
nhra stocker
Thats at the flywheel and theres 15%-18% loss thru the drive train. Thats how you get the rwhp (rear wheel horse power).
Old 01-21-2010, 08:57 PM   #7
Monte
Dynojets usually give the most unrealistically high numbers, and are the easiest to fudge the results. Without going into a long rant that has been gone over 10000x, do some research and you'll find some answers. NO dyno is perfect and they all can read wrong if lyed to or programmed improperly, but some are better than others.
-Chris
'10 Camaro SS
'88 Monte Carlo SS
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
LS3 Camaro Stock Intake Manifold $275 Pope Designs V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 7 12-15-2009 09:40 PM
Took my Stock LS3 to Hennessey for CAI and Tune- Big Difference!!! mslone Tuning / Diagnostics -- engine and transmission 4 10-19-2009 03:38 PM
Stock dyno/rotofab cai dyno/tuned dyno. rodimus prime Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 24 09-20-2009 09:05 PM
