Old 01-21-2010, 08:29 PM   #1
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Made my own CAI (Now with pictures)! I have a question though
Alright so one of my friends who is an engineering major helped me make a custom CAI, he did one on his mini cooper and it looked pretty sweet. So anyways we just finished it and reset the computer by unhooking the postitive end of the battery. We didn't look at the time but I think we only let it set for 10 MAYBE 15mins. When we started back up it had the check engine light come on and then what was weird was the stabiltrak light came on, I have no idea why. I'm hoping it was because the computer was reset? Maybe I didn't let it reset long enough? Anyways we drove it around a little bit and then I dropped him off at his place. Talked for a little bit and then I came back. When I started the car up again all of the "Check lights" were now off. I'm hoping this is ok and all. I've heard about the check engine light coming on when new CAI's are installed so hopefully that's normal.. I have NO idea why the stabiltrak light would come on though. The one thing to note is, when we got the new pipe that had the hole for the air flow sensor, the one in the pipe is circular and the sensor on the Camaro is kind of square-ish. Anyways it sitting slightly at an angle and he said his only concern was that is possible the sensor might not be reading right. It's only at a slight angle and he thought it "shouldn't" be a problem but we all know what can go wrong will go wrong What do yall think of my situation? It sounds normal and I've only put about 5 miles on it so far with the custom intake and I feels a little more responsive.
I'll take pictures tomorrow in the day time, personally I think it looks AWESOME.
***EDIT*** PICTURES!
Last edited by BaylorCamaro; 01-22-2010 at 12:29 AM. Reason: added pictures for forum members to view
BaylorCamaro is offline   Reply With Quote
Old 01-21-2010, 08:34 PM   #2
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Yeah, I can't really comment on the unit until I see pics. It seems very normal
that you got a cel and then it eventually went out. This has happened to many up here.
Old 01-21-2010, 08:37 PM   #3
cam5
War Eagle
cam5's Avatar
Drives: 2010 2ss cyber gray
one i think its awesome u did it urself.. i need someone to toy around on my car and make it bada$$..
cam5 is offline   Reply With Quote
Old 01-21-2010, 09:27 PM   #4
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
All kinds of warning lights are on after a dyno session... they all clear after a some driving and starts... so not surprised you had the stablitrack light and then they went off..
MAF sensors can be very finicky... hats off to you trying to do this but not sure I would want to do this blind without a way to check things...
Did you change the diameter of the MAF sensor housing?
scrming is offline   Reply With Quote
Old 01-21-2010, 09:50 PM   #5
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Do you think I should go back to the original air intake? If it's hurting it, shouldn't some warning lights come on, and STAY on?
Not really it's really close to being the same, the thing is the pipe that had the hole for the MAF wasn't the right shape, but it still fit snug and the very small leaks it might have we sealed with electrical tape to ensure air doesn't escape. The only thing is, the MAF isn't at the exact angle as it was in the stock version, it's slightly tilted.
Old 01-21-2010, 09:53 PM   #6
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM
I can't wait to see pics of this thing.
Formerly owner of:
2007 Acura TSX
1992 Oldsmobile Achieva V6
1992 Mercury Sable
Blade is offline   Reply With Quote
Old 01-21-2010, 11:51 PM   #7
daveprimo
daveprimo's Avatar
Drives: 2010 Camaro 2LT
Should have bought a good one like airaid. You bought a brand new camaro and your gonna rig it? also you know what your getting from the airaid. Those companies test different designs to fit good and to get the maximum air flow (and the correct way for the sensor to fit air tight). I give you credit for doing that but not the smartest choice especially if your asking questions like these...
daveprimo is offline   Reply With Quote
Old 01-22-2010, 12:15 AM   #8
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
I understand that airaid is going to produce better results, but a CAI isn't going to do too much either way. I didn't particularly do it ONLY for performance, I love the way it looks and it sounds good from the front of the car. The only reason I'm asking these questions is to see if anyone else has any professional knowledge in this area, or has done something similar.
Old 01-22-2010, 01:31 PM   #9
MontyCarlo
MontyCarlo's Avatar
Drives: 2010 2LT/RS auto IBM
That's cool that you guys are doing some of your own work, but the relatively sharp angles on your intake tube are going to eat up some of your air pressure. I don't know whether or not you've got the tools to do it, but if you do, you should try making a new tube with a wider bend radius in those corners.
FAQs:
1. No, I do not have any strong opinions about the Monte Carlo.
2. Yes, I know what my name looks like.
3. Yes, but the medication helps immensely.
2LT/RS IBM/gray #21,895 ordered April 21st, delivered July 3rd
MontyCarlo is offline   Reply With Quote
Old 01-22-2010, 01:37 PM   #10
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Unfortunately we don't have the necessary tools to do this, I realize from a performance standpoint I'd be better buying one than making my own, but realistically since CAI's don't do too much for performance anyways, I don't really mind. I just really like how it turned out. The pictures don't really do it justice, the filter kind of looks pink, when it really is a dark red. The dark red with the chrome look SO good together.
It's just a little something that sets mine apart from other Camaro's
Old 01-22-2010, 02:26 PM   #11
Blade
Blade's Avatar
That looks pretty spiffy, but I have 2 questions.....
1) Aren't the sharp angles diminishing some of the airflow?
2) What is the additional mini filter for, right behind the CAI?
Formerly owner of:
2007 Acura TSX
1992 Mercury Sable
Old 01-22-2010, 02:46 PM   #12
Sevn86
Sevn86's Avatar
looks great...o and my car sometimes flashes the stabiltrak sign at start up and i dont know y...my cars stock i havent done anything to it...but in my on star reports it shows everything is fine...
3100 Sequenced:10/12/09
3400 Broadcast:10/22/09
3800 Produced:10/27/09
4200 Shipped:10/29/09
Old 01-22-2010, 02:56 PM   #13
FISHTAIL
FISHTAIL's Avatar
Drives: Sedan & 2SS / RS
What is this?
Drives: 2012 2SS/Black/RS/A6
FISHTAIL is offline   Reply With Quote
Old 01-22-2010, 03:26 PM   #14
scrming
scrming's Avatar
Originally Posted by FISHTAIL View Post
What is this?
it's a PCV breather... instead of having the PCV connected to the intake tube (like the stock on) the crank case is now just vented to the open air...
Roto-fab CAI dyno results Roto-fab 1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 102 07-30-2016 08:21 PM
Warranty Question for Headers, CAI, and Tune Inferno2SSRS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 08-16-2010 02:10 AM
Please recommend a CAI for Maggie 2300 ffrcobra_65 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 24 11-16-2009 10:55 PM
Quick GFX question. What are they made of? Mayhem 5th Gen Camaro SS LS LT General Discussions 3 11-06-2009 02:16 AM
CAI question Chrisrp454 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 10-02-2009 09:15 AM
