Old 01-30-2010, 09:11 PM   #1
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
Header install problem, need help
So I got my ARH headers installed, very nice product by the way. When I was taking the O2 sensors out one of them stripped badly only one thread left. Yes I soaked them in PB Blaster over night didn't help. The only place I can find a replacement is from Chevrolet at $130 and will have to be overnight shipped at another $20. I'm willing to pay and did for quality but another $150 puts these things dam close to grand, WTF. I guess i'll stop whining now.
1977and2010 is offline   Reply With Quote
Old 01-30-2010, 09:19 PM   #2
JJ2010
Drives: 2010 Camaro SS
When I put my headers on everyone of the sensors stripped.....
I used a thread file and fixed the threads...
Mine looked like they couldn't be repaired either....
I hope you can fix the threads......
JJ2010 is offline   Reply With Quote
Old 01-30-2010, 09:33 PM   #3
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
I think they are made to do that on purpose.
Bot you can often clean the threads out, its the sensor side that is made of crap metal.
2ndgenz28 is offline   Reply With Quote
Old 01-30-2010, 10:22 PM   #4
1977and2010
The threads are gone the sensor falls in to the one and only thread just above the gasket/washer.
Old 01-30-2010, 11:10 PM   #5
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
Can always get a Tap and Die kit to redo the threads.
franknbeans is offline   Reply With Quote
Old 01-30-2010, 11:52 PM   #6
flyby
Drives: 2010 Silver SS
agreed try a redoing the threads first
flyby is offline   Reply With Quote
Old 01-31-2010, 12:18 AM   #7
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
I think he's saying there's not enough metal to rethread.
9/26/09 Took delivery!
Old 01-31-2010, 12:24 AM   #8
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
it often looks that way till you try.
Old 01-31-2010, 11:31 AM   #9
LSU/LS3
Drives: Inferno orange
I thought I was the only one that ran into this problem.The one on the driverside stripped I got a new one from the dealer for 120.
LSU/LS3 is offline   Reply With Quote
Old 01-31-2010, 11:39 AM   #10
Russell James
Russell James's Avatar
Wonder if it would help to try to loosen them when the exhaust is still warm. Sometimes exhaust parts are seized pretty tight when cold.
Old 01-31-2010, 11:45 AM   #11
g-townmach
I FARTED
Drives: 2010 2SS/RS
If its the O2 bung that is stripped, go get a Heli-Coil kit and fix it. If its the actual sensor thats stripped, gunna have to buy a new one. Maybe could run a die over it but I doubt you have one.
When you get it fixed and continue with the install, be sure to put some anti-sieze so this won't happen to you again.
g-townmach is offline   Reply With Quote
Old 01-31-2010, 11:52 AM   #12
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
gonna be doing headers soon pics of this would be nice
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 01-31-2010, 11:53 AM   #13
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
If anti sieze was a good idea, I think GM would use it too...............
Ahhh just kiddin, them Ahole didn't never learned to even use locktite on the tilt steering bolts.
Old 01-31-2010, 01:19 PM   #14
1977and2010
I actually went and bought a die for it and tried to save the one last thread and it didn't work. All threads except one were ripped off. Used penetrating lube over night and when it first started sticking used a propane torch to heat it up. Lot of good that did. Just have to suck it up I guess.
INSTALL OF BARTON SHORT THROW SHIFTER BLACK10 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 141 03-20-2017 11:01 PM
Pinging sound while car warms up after header install Jakefeb3 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 12-05-2009 06:48 AM
SLP header install problem kunkelz28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 10-01-2009 10:57 AM
Somewhat Annoying Back Seat Problem! ZNOLMT 5th Gen Camaro SS LS LT General Discussions 5 06-21-2009 10:22 AM
