Rev Couture
Drives: 2010 LS Camaro & 2013 Rav4 Ltd Join Date: Jan 2010
Is this offset acceptable??
Hey folks,
Simple question - Looking at ordering a set of wheels Rear wheels are: 20" x 10" wide 5x120 bolt pattern 35mm offset. Will these fit fine? I thought I saw rear wheels needed 42mm offset, but I cant find where I saw that at... Thank you for any responses! -SA
EBC Brakes| DOT 4|Bigworm| SickSpeed| BMR | IPF | Vararam| MRT |MGW | Nitto | Rx |
Iggee |ZL-1 Sways| Hurst | Apex Racing|Past: Srt-4| 6.0L GTO- RIP | '98 Integra |
Rev Couture
any thoughts? I still cant find the site that recommended the 42mm offset in the rear.
I cant imagine it being a problem for my set-up as I will just be doing 10" wide wheel and only 285/40 tire out back. I would assume if guys are putting 11" wide on 305-315 wide tires on with no problem, i am in the clear...
SoCal C5 Family Member
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M Join Date: Jul 2009
Not sure if they'll fit (I'll let someone else answer - or call Tirerack), but the offset info is on the Wiki page: http://www.camaro5.com/forums/wiki.p...WHEELS___TIRES
You don't indicate what type of model you are ordering, so the 40 mm is correct for RS models, otherwise 38mm is ok.
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers; |
20x10" et35 should fit fine, but as always, tire size matters. Just because a 275/40 fits doesn't mean a 315/35 will.
| Positive Offset/ Backspacing | 2fine69 | Wheels and Tires Talk Sponsored by The Tire Rack | 7 | 05-20-2010 12:40 PM |
| Offset question | Maro99 | Wheels and Tires Talk Sponsored by The Tire Rack | 4 | 12-10-2009 01:08 PM |
| Diffrent Offset | rasby | Wheels and Tires Talk Sponsored by The Tire Rack | 3 | 09-25-2009 05:16 PM |
| Stock Offset???? | BumbleBeeSS2009 | Wheels and Tires Talk Sponsored by The Tire Rack | 1 | 06-14-2009 10:40 PM |
| Wheel offset of stock wheels? | jc211 | Wheels and Tires Talk Sponsored by The Tire Rack | 0 | 03-27-2009 02:54 PM |
