Old 02-20-2010, 11:42 AM   #1
Booneabal
Drives: 2LT RS Rally Yellow
Best tire pressure for fuel economy = 38?
I have an 2LT RS and about a month ago one of the tires had a slow leak and I ended up pumping up all the tires to about 38psi cool. I noticed that I got a slightly stiffer ride (nice) and my fuel economy jumped 2mpg to a solid 22 every time.
Since I got the car serviced they lowered the tires to 36 psi and my fuel economy is now back to 18.9-19.7 range all the time.
I plan to go back to the 38 psi because the tires are rated for 40 so I don't think its an issue.
Anyone have any experience with this?
Booneabal is offline   Reply With Quote
Old 02-20-2010, 12:19 PM   #2
wbdinger
Drives: NSMNJW=2010 CGM 2SS/RS LS3
For fuel milage you should run the tires at the maximum rated pressure. 40-50 what ever the tire says on the sidewall.
wbdinger is offline   Reply With Quote
Old 02-20-2010, 12:55 PM   #3
philipdistefano
Remember, Remember...
philipdistefano's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Send a message via AIM to philipdistefano
My tire pressure is at like 34 for all tires. Is this too low?
philipdistefano is offline   Reply With Quote
Old 02-20-2010, 01:15 PM   #4
Booneabal
I think so, there is a sticker on the inside of the driver side door that gives you the recommended pressure. At 34 your ride is probably really soft and you are wasting alot of power to the tires.
Old 02-20-2010, 03:26 PM   #5
wbdinger
also @ 34psi the tire will wear the inner/outer edges as the contact patch in the middle is not touching the road. especially on these wide tires
Old 02-22-2010, 11:55 PM   #6
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
Same thing, if you inflate over 36 psi you will be wearing the centers of the tires. There is a reason GM states 36psi. It is because they have figured out that with what the car weighs, 36 psi is the perfect pressure to get maximum tread contact to the ground.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 02-23-2010, 12:06 PM   #7
camarowa
camarowa's Avatar
Drives: 2013 SVT Raptor, sold 2010 Camaro
36 psi is recommended by gm, during spirited driving pressure will increase a bit to 38-40psi.
- Pfadt Suspension Package; Springs & Sways
- Brembo Brake Upgrade (Yellow); Courtesy Fesler Built
- Custom Magnaflow Exhaust
- Blacked-Out Bowties & RS Emblems, Front bowtie delete
- Full Dynamat Extreme Trunk Coverage
- Tinted side markers
- Interior DSV Customs Leather Upgrades
- Airaid CAI V2
- Forgestar F14 Gunmetal 20x9, 20x11
- Doug Thorley Shorties
camarowa is offline   Reply With Quote
Old 02-23-2010, 12:44 PM   #8
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
hey guys. This is an interesting topic. I think in order to make fair comparisons, we would be talking about rolling road tire pressure (or HOT), as opposed to cold set pressure. There are MANY factors to take into account for tire pressure rate increase,(ambient temps (kinda), alignment, suspension upgrades, passengers, fuel load, etc)so really, I'd be interested to see what the pressures are HOT. This should give a better baseline.
Maybe there should be a fuel economy thread stating tire pressures (hot), and appropriate supporting factors. This is interesting to see what people find.
Old 02-23-2010, 01:37 PM   #9
ron10
Drives: 2010 2SS IOM L99
36 pounds is what you should put in the tires.that is why the sticker says "cold tire pressure".factory knows the tire presure will increase when the tires get hot.
Old 02-23-2010, 01:47 PM   #10
PfadtRacing
Hi ron10,
I think a consideration needs to be made for GM and the fact that they are supplying Camaros to a wide range of environments with varying ambient temps, among other factors. Final tire pressures always vary from one car's set up to the next (given a different set of variables). Starting with 36 is the recommended setting, for the best average final tire pressure, but isn't necessarily tailored to everyones specific use. Drivers will see different hot results depending on what they are doing (type of driving, average speeds, hard cornering etc.) and the factors listed above. This is why when posting results about fuel economy vs. tire pressure, it is best to talk about it at the hot pressure, since you do not drive on cold tires for very long. Its also important to note that all four tires will not always increase to the same pressures.
Old 02-23-2010, 02:14 PM   #11
bono83
bono83's Avatar
Drives: 1969 Chevelle, 2010 1LT
Run the FACTORY recommended pressure. One of the biggest goals for car manufactures is to get the best MPG possible. There are many reasons (MPG, tire wear, traction, handling, ride quality, etc.) that are factored in and considered during the design and testing of a car and tire to arrive at the recommended pressures. Max pressure on the sidewalls is for major payloads like all seats filled with passengers, the truck full with cargo, and maybe a trailer attached.
Order: 5/23/09 - Deposit given with order at dealer.
1100: 6/26/09 - Order placed by dealer - no allocation
2000: 8/15/09 - Accepted by GM.
2500: 8/18/09 - Preferenced.
3000: 8/18/09 - Accepted by Production Control.
3100: 9/9/09 - Available to Sequence.
3300: 9/9/09 - Scheduled for Production.
3400: 9/19/09 - Broadcast.
3800: 9/29/09 - Produced.
4000: 9/29/09 - Available to Ship.
4150: 9/29/09 - Original Invoice.
4200: 10/6/09 - Shipped.
5000: 10/13/09 - Delivered to Dealer.
6000: 10/13/09 - Delivered to Customer.
bono83 is offline   Reply With Quote
Old 02-23-2010, 02:19 PM   #12
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
If that were so he wouldn't see a MPG increase, the rec psi on the door is for ride comfort first, MPG 2nd.
Hence the stiffer ride but better MPG he see's
why all those ford suv's rolled over, they wanted folks to use 28 for a nice ride, but in a panic manuver you were screwed.
2ndgenz28 is offline   Reply With Quote
Old 02-23-2010, 02:25 PM   #13
rmnc3r
Drives: me up the wall.
This topic comes up frequently in MC forums. Most seem to run at max recommended pressure that is on the sidewall, claiming better handling and tire life. With all due respect to 'recommended' pressures, GM, and by extension, their (tire) suppliers are in the business to SELL stuff. THAT being the case, the sooner something wears out, the better for them. In many cases, the buyer will opt to replace with the same brand/item that came as OE.
I run mine at 41-42, just a little more than recommended and a little less than
Max Rated. No empirical evidence to support or refute, just a little considered reasoning.
rmnc3r is offline   Reply With Quote
Old 02-23-2010, 02:26 PM   #14
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
if the tire says 40 max, it will not be over infalted and wear out the center faster unless your over 40.
Most good performance tires are rated to 40-50 psi with NO deformation.
Only beyond the max can that happen.
Why its call the max, beyond that it will ballon.
Tires loosing pressure joepitt Wheels and Tires Talk Sponsored by The Tire Rack 22 12-11-2010 06:00 PM
Tire Pressure and Winter? Nicholas Wheels and Tires Talk Sponsored by The Tire Rack 36 02-13-2010 02:28 PM
tire pressure kcamarom Wheels and Tires Talk Sponsored by The Tire Rack 5 11-29-2009 02:53 PM
Why RAM Air is a myth!!! Long Read (Wall of text) live2well Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 80 11-02-2009 04:34 PM
Tire Pressure Monitoring System Noah Wheels and Tires Talk Sponsored by The Tire Rack 24 10-13-2009 07:06 PM
