Old 02-28-2010, 10:57 AM   #1
Harley Kidd
Drives: Black 2022, ZL1, Hurst M6 NPP
160 Thermostat
Has anyone put one of these 160 thermostats in their car? I used to do this all the time with my older vintage cars, however, I am wondering if this change will cause problems with the ECM or something else that is factory set to work at the temp they wanted the car to operate at.
Harley Kidd is offline   Reply With Quote
Old 02-28-2010, 11:18 AM   #2
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
I have been running the SLP 160 for 3 months now with no problems. If you are a short trip driver or in an extreme cold environment I would not recommend it. If you are gonna mod and increase the HP levels I would highly recommend it.
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 03-13-2010, 05:14 PM   #3
ProudLS
ProudLS's Avatar
Drives: Camaro SS
I have just installed one in my car, do I need to adjust the fans settings? Should it start earlier than the factory thermostat?
Thanks,
ProudLS is offline   Reply With Quote
Old 03-13-2010, 07:23 PM   #4
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
The fans need to be in sync with the new thermostat's target temp. This is done in the ECM by seting when the fans need to operate. Set the fans temp range a little lower than stock. The last several days here in the DFW area my eng. temp has been about 178 to 180 degrees using a 160 stat with corresponding ECM temp. programing.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 03-13-2010, 08:09 PM   #5
JANNETTYRACING
JANNETTYRACING's Avatar
Guys I hate to rain on your parade but I Don't Recommend this, these are all aluminum engines and the bearing clearances are strongly affected by operating temps.
Running the engine cold makes the Crank Bearing clearances Tight.
I have never seen any additional power by running the engine cold, it also increases the timing needed for a complete burn, and increases emissons, and reduces fuel economy.
Let's not think we know more than GM Engineers.
My Recommendation is Leave the T-Stat Alone.
Everytime I dyno one of these cars they make the most power when FULLY Warmed up.
Usually the 3 runs or more before it stops gaining power, What does that tell you?
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 03-13-2010, 08:22 PM   #6
BlackM6RS/SS
BlackM6RS/SS's Avatar
Drives: 2010 Black M6 RS/2SS
Im going to get mine tuned with a 160*. Texas summer 100* weather and heat soak, yeah i dont want mine running with the stock stat
10 Blk/Blk RS/2SS w/CGM Stripes
ADM H/C/I M6 480rwhp 435rwtq
FE4 LCAs w/Pfadt ZL swaybars Diff bushings Trailing arms Drop springs
BlackM6RS/SS is offline   Reply With Quote
Old 03-13-2010, 08:33 PM   #7
Jetsco
Jetsco's Avatar
Drives: Ordered 2/25/09 -2SS/RS/IOM/M6
Guys, where I take my car, Speed Inc here in Illinois agrees with Ted. According to them there is no reason to change the stat out. However, I do believe they program the fan to turn on a little bit sooner though.
IOM 2SS/RS, M6 (587rwhp) - Chrome Maggie w/3.8 Pulley, Speed Inc Custom Cam Package, Roto-Fab CAI, Stainless Works Headers and Full Exhaust System, SI Custom Tune, Pfadt Drop Springs, Pfadt Front and Rear Sways, Powder Coated Calipers with Stillen Vented/Cross-drilled Rotors and SS Brake Lines, Barton Shifter, Street Scene Scoops, NLP Spoiler, Heritage Grille, Smoked Lenes, Painted XM Antenna, Showstopper Custom Engine Compartment and D2FORGED 22" CV2's.
Jetsco is offline   Reply With Quote
Old 03-14-2010, 06:36 AM   #8
ProudLS
ProudLS's Avatar
Drives: Camaro SS
I live in TX and I think I need to program my fans lower than the stock maybe 175 will be ok with 160 stat.
Old 03-14-2010, 12:08 PM   #9
Wikedwil
Co-founder of CDCNY
Wikedwil's Avatar
Drives: 2016 Camaro 2LT Hyper Blue
Ted.
Is it the same rule for the v6 also?
Wikedwil is offline   Reply With Quote
Old 03-14-2010, 12:45 PM   #10
JANNETTYRACING
Yes we program the fans to come on stronger to keep it at 190-200 consistantly.
Ted.
Old 03-14-2010, 12:45 PM   #11
JANNETTYRACING
Yes. Back in the days of Carburators and Iron engines there was an advantage of running at 160 but not with todays modern aluminum engines.
Old 03-14-2010, 01:28 PM   #12
JR-Vette
JR-Vette's Avatar
Drives: 1999 500 HP Corvette
Aluminum does not transmit heat out as well as steel does.
Car powertrains of today only purpose to be forced to run hotter is for smog purposes to keep exhaust, 02 sensors and CATs hotter and why EPA requires those parts not be moved.
This can be shown as years ago the CATs were mid stream and today they are closer to the heads where exhaust temps are HOTTER.
Cannot override nature, the hotter the engine bay is the more friction there is, the more molecules in air and fuel separate and hence less of them per volume space.
This makes for a worse charge to cylinders, not as good of a burn, leaner AFR which causes PCM to command fuel injectors on longer to the point they can be too small for the performance output.
Look at the front of a C5 Corvette and then the nose of the C6 as GM found they needed more cooler air so they increased the air volume to help cool the radiator more.
Look at the new ZR1 you see it uses a larger radiator then other C6 models and check out the new Z07 and Z06 options just released you'll see they also now come with a larger radiator. Also look at the new Z07 hood or the C6R and you see a nice big hole in it to help pull engine and bay temps down.
Just because a lower Tsat like a 170 degree is used does not mean the temps stay there as the norm, most cases once engine is warmed up due to smaller radiator volume flow the engine will still run hotter then Tstat setting.
If living in cold country during the winter you always could run a tune with fans set higher and another tune for summer or race conditions set with fan settings closed to Tstat opening used.
Consider the engine oil runs hotter then the water/fluids that heat is then transmitted into that water temp so because even if water is 170ish the oil temp is still hotter.
Consider the hotter engine is then means the hotter total engine bay is.
This effects even the temp of fuel in fuel rails, injectors, air in intake, to effects to all other parts in the engine bay.
Many of us not only use cooler Tstats but also better flowing radiators, engine oil coolers and even less anti freeze ratio since water transmits heat out better.
Many of us also use water/methanol injection to force air temps much lower for a end result of a far better cold charge in cylinders which makes more power and reduces engine ping which would force PCM to reduce timing and kill off torque.
Assuring AFR does not lean out allows even more timing to be added via the tune which increases performance across the board.
In 45 years of driving/racing I have never used a stock Tstat and using all of the above and even in northern cold weather the engine temps never go below mid 170s with no harm long term to engine or performance.
Denser (cooler) air and fuel burn better where hotter temps do not and we all know that in why boost of any kind the more condense the air is the more performance is produced.
Bi-product of having a hotter engine bay cause fuel in fuel rail and injectors to dry out when engine is turned off as heat soak increases and leave deposits and allows engine to heat soak worse effecting off the line performance.
JR-Vette is offline   Reply With Quote
Old 03-14-2010, 02:32 PM   #13
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
I would follow what Ted says. he knows what the real deal is.
SSTony is offline   Reply With Quote
Old 03-14-2010, 09:41 PM   #14
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
Operating temperature vs power and longevity!
http://www.carnut.com/ramblin/_cool3.html
2ndgenz28 is offline   Reply With Quote
160 Degree Thermostat and Car Issues.... EAkrish Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 203 05-17-2012 02:34 PM
160 thermostat for LS3/L99 help ??? salohi Camaro DIY & HOW-TO instructions & discussions 10 01-19-2012 09:05 PM
160' t-stat??? JHart Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 11-24-2009 01:28 AM
160 Thermostat My First Camaro! Tuning / Diagnostics -- engine and transmission 18 08-07-2009 11:52 AM
160 degree thermostat rforbes Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 07-07-2009 03:34 AM
