Old 03-10-2010, 09:32 AM   #1
adub
adub's Avatar
Drives: Shopping
Stabilitrak Freakout
Car is 2SS RS Auto with 300 miles on it. Cruising down the highway yesterday and the stabilitrak lights start flashing, info center says service stabilitrak soon. Car is running fine, so I stayed on the highway for another 2 miles or so until my exit came up. Once I slowed down at the exit, the car freaked out, began to idle rough, chug, and lurch. Pulled into parking lot. Tried turning it off/on, and drove around the parking lot. Lights went away, but it wasn't running good. Got back on highway and headed to dealer. Stabilitrak message went on and off again then CEL came on. Dealer pulled a bunch of codes (one was engine misfire, dont know the others) and showed me a TSB. The car was behaving as described per TSB. The TSB said the issue was related to a damaged wiring harness on the pass side hitting the exhaust manifold. My cars harness is well clear of the manifold. Dealer found no issues, clear codes, and sent me on my way. Anyone else had a similar experience?
adub is offline   Reply With Quote
Old 03-10-2010, 09:42 AM   #2
wow, sounds scary
Old 03-10-2010, 11:17 AM   #3
DangerZL1
Drives: 2023 Black ZL1 Auto
The last few cases of the stabilitrac lights coming on and a bunch of codes were related to a faulty computer. If it happens again, the dealer should be more agressive in finding a fix.
DangerZL1 is offline   Reply With Quote
Old 03-10-2010, 02:15 PM   #4
adub
adub's Avatar
Drives: Shopping
If it happens again, I'll be the aggressive one
______________________
2010 2SS RS Auto - Black
1970 Chevelle SS 396
Old 03-10-2010, 02:18 PM   #5
thecamaroguy
thecamaroguy's Avatar
Drives: 2020 ZLE 67 SS350
Check for loose plug wires...one of my friends had this.
Thanks,
thecamaroguy
2010 Camaro 2SS - CGM
1967 Camaro SS350 - Baldwin Motion Tribute
2020 Camaro ZL1 1LE - White
Proud to say I have always owned a Camaro! A Camaro has been my Daily driver since I started driving!
thecamaroguy is offline   Reply With Quote
Old 10-12-2011, 01:38 AM   #6
Awesome_SS
Jeff
Awesome_SS's Avatar
Drives: 2010 Camaro SS/RS
Not sure if this will help, but just keep it mind to have it checked out next time at the dealer. I have been fighting the "Service Stabilitrak" light for about 11K miles or so. Just now starting to get to the bottom of it. One trip to the dealer, they discoverd that the wiring harness was partially unplugged, but the light came back on afterwards. Today, they discovered that the steering wheel angle sensor is bad. Hopefully, this will take care of the light. I have had it serviced numerous other times, but no real reason to the cause. A low voltage reading appeared one time doing the diagnostics, but the light continued to come on. So, I will coninue to take it to the dealer in hopes of finally eliminating all the possible causes. It just makes me wonder how many other things are partially unplugged or bad on the car.
Awesome_SS is offline   Reply With Quote
Old 02-27-2012, 12:58 AM   #7
KodyJoe
KodyJoe's Avatar
Drives: 2010 White Camaro SS
I am so glad to be apart of this site. My car literally just did this. Awesome_SS did you ever solve your problem.
L99 with CAI, LT Headers, Full Exhaust, and Dyno Tune 374.73 rwhp and 397.18 ft-lbs.
KodyJoe is offline   Reply With Quote
Old 02-27-2012, 04:45 PM   #8
Awesome_SS
Jeff
Awesome_SS's Avatar
After many tries by the dealer, they finally located the problem. It was a faulty steering wheel angle sensor. Do a search on this forum for the sensor and you find many threads, some by me, on this topic. The 07/08 Chevy Trial Blazers are notorius for this sensor going bad...they have their own forum and many threads on this topic. It is funny that the dealer does not have this in their database as something to look at.
Old 02-28-2012, 01:39 AM   #9
Nessal
Drives: Exige, Miata, Ghia
Can anyone explain why the engine would run all messed up from a steering wheel position sensor?
Nessal is offline   Reply With Quote
Sevice Stabilitrak Dans2SS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 27 10-26-2011 09:10 AM
Service Stabilitrak? (Launch Control) tommygun6644 5th Gen Camaro SS LS LT General Discussions 7 12-22-2009 12:11 PM
SPARK PLUG WIRE TRIGGERED STABILITRAK Ukd73 5th Gen Camaro SS LS LT General Discussions 2 11-21-2009 10:21 PM
Service Stabilitrak! Davis Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 07-29-2009 02:45 PM
Stabilitrak on 5th gen? rray200 5th Gen Camaro SS LS LT General Discussions 29 12-22-2007 02:29 PM
