Old 03-18-2010, 09:06 AM   #1
xshortd
xshortd's Avatar
Drives: 2010 Camaro 2LT Rally Yellow
Weird noise when idling????
hey guys, got a question,
when i start my car and its idling i get a weird noise comming from it like tik tik tik then as soon as i move it goes away. is this a problem??
i have a 2lt auto
Thanks!
xshortd is offline   Reply With Quote
Old 03-18-2010, 12:48 PM   #2
PtownPendleton
Drives: 2010 Black 1SS w/RS
I had a 2008 Cobalt SS with the Direct Injected 2.0L Turbo, and it made the same "tik tik" noise at idle. It did it from the very moment I owned the car to the day I upgraded to my 2010 1SS. I did some research into the noise, and found that it had something to do with the Direct Injection system. If I do remember right, the tik noise came from an auxillary fuel pump, that is needed to supply the fuel injectors the high pressure required for direct injected motors.
I never had any problems with my Cobalt, and I believe this is the same thing.
So in short, No Worries!
PtownPendleton is offline   Reply With Quote
Old 03-18-2010, 02:30 PM   #3
xshortd
xshortd's Avatar
Thank you man! good to know! you have put my worries to rest.
Old 05-06-2010, 02:51 PM   #4
GreenMonster
Its all about the U
GreenMonster's Avatar
Drives: 2010 SGM
bump
GreenMonster is offline   Reply With Quote
Old 05-06-2010, 02:52 PM   #5
GreenMonster
Its all about the U
Drives: 2010 SGM
I went to the dealer the other day bcuz of that sound and the man said it was due to the "high pressure fuel pump" ... just more info on this matter
Old 05-06-2010, 06:45 PM   #6
ffrcobra_65
normal...actually the dealer told me it was the injectors. Dealer fired up 2 Camaros in their lot and tik tik tik was there as well.
tik tik tik that doesn't go away when you raise the rpm is not normal.
Old 05-06-2010, 06:48 PM   #7
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
It's a mechanical high pressure fuel pump... It's normal...
scrming is offline   Reply With Quote
Weird noise on V8 2ss Camaro Eddie_B USA - Texas 11 05-22-2011 04:16 PM
weird noise from the tranny .... Khrono Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 16 04-12-2011 08:43 PM
Help! Weird Noise While shifting M6 AWS-GTAW Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 16 04-16-2010 09:53 AM
Weird Noise In the Rear On a 2SS camaro2011 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 22 02-22-2010 08:05 AM
Weird Air-Leaking noise... a_Username Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 09-03-2009 10:25 AM
