Old 03-18-2010, 10:45 PM   #1
2Muchmark
2Muchmark's Avatar
Drives: 2013 2SS RS 1LE
Send a message via ICQ to 2Muchmark Send a message via MSN to 2Muchmark Send a message via Skype™ to 2Muchmark
4 Guage pack just died on me :(
Not sure what happened, but the 4-guage cluster (battery, oil, etc) just died. None of the meters move and the lights on it are out. Is this cluster on a separate fuse from the rest of the dashboard?
2Muchmark is offline   Reply With Quote
Old 03-18-2010, 10:51 PM   #2
CynAgain
CynAgain's Avatar
Drives: Chevy
sorry to hear that :(
hopefully it is just a fuse
Old 03-18-2010, 10:55 PM   #3
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Ah, take it in. Let them deal with it.
Old 12-20-2011, 05:54 PM   #4
JCO2185
RIDING ON AIR
JCO2185's Avatar
Drives: 2010 2LT/RS Summit White
Sorry to grave dig a thread, but the same thing just happened to my gauges....anybody know a fix for this? Fuse?
--John--2010 Camaro 2LT/RS, Summit White
Air Ride Suspension, BBK Longtube Headers, Hi-Flo cats, Doug Thorley catback exhaust, Elite Catch-Can, Airraid CAI, Trifecta tune, ZL1 front end with Phantom grille, ZL1 side skirts, MRR228 graphite wheels
JCO2185 is offline   Reply With Quote
Old 12-20-2011, 06:13 PM   #5
Dznts
Anabolic Connoisseur
Dznts's Avatar
Take it to the dealer.
Old 12-20-2011, 06:19 PM   #6
VTXrider
VTXrider's Avatar
Drives: 2010 RY 2SS/RS
Mine did it about a year ago, take it to the dealer and let them deal with it.
VTXrider is offline   Reply With Quote
Old 12-20-2011, 06:24 PM   #7
SSGUNNER
Chu no guat a hasa is?
SSGUNNER's Avatar
Drives: 14 Jeep G Cherokee Overland HEMI
Any pics?
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
SSGUNNER is offline   Reply With Quote
Old 12-20-2011, 06:28 PM   #8
ron10
Drives: 2010 2SS IOM L99
sound like it has to be a fuse issue.only thing is,what would cause the fuse to blow.
Old 12-20-2011, 08:02 PM   #9
Eric Baker
Drives: Black/Black 2SS/RS 6M
Could be the plug behind the gauges came loose somehow.
Eric Baker is offline   Reply With Quote
Old 12-20-2011, 08:05 PM   #10
acowherd
acowherd's Avatar
Drives: 2010 2ss/RS 4l80. 2009 2500 HD
Still have temp gauge?
I lost my temp gauge and trans temp gauge and one other...just driving down the street. I had to rest the computer to get the car to start!!
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379
FNSS Racing!
acowherd is offline   Reply With Quote
Old 12-20-2011, 09:24 PM   #11
SpendyWendy
SpendyWendy's Avatar
Drives: 2011 SW 2SS/RS M6 Delivered 5/20/11
Mine did this about 2 months ago - took it in to the dealer - they found the plug to be faulty - they replaced it - good as new.
SpendyWendy is offline   Reply With Quote
Old 12-20-2011, 09:42 PM   #12
MS3DALE
MS3DALE's Avatar
Drives: 2011 2SS/RS LS3/6M Litho#190
Theres a TSB out for this issue....
Service Information
#PI0327B: Center Console Multifunction Auxiliary Gauges Inoperative - (Dec 15, 2011)
Subject:Center Console Multifunction Auxiliary Gauges Inoperative
Models:2010-2012 Chevrolet Camaro
Equipped with RPO UMQ, UXQ or Auxiliary Gauge Package (Front Floor Console Front Cover Package)
This PI is being revised to add the 2012 model year and update the repair steps. Please discard PI0327A. Condition/Concern
Some customers may comment that the center console multifunction auxiliary gauges do not function or function intermittently.
This condition may be caused by a poor connection between the gauge assembly and the front floor console front cover wiring harness. This connection is located at the rear of the gauge assembly.
Recommendation/Instructions
Use the following steps to remove the gauge assembly and apply a mastic patch that will stabilize the harness to gauge connection.
1. Apply the parking brake.
2. Move the transmission shift assembly to the most rearward position possible.
3. Use a flat-bladed plastic trim tool and release the retainer tabs securing the front floor console front cover to the console assembly (1). Make sure the connector is fully seated. If you hear a click when you push it, that means it wasn't fully seated before. Charge Labor Code N6654.
4. Start the vehicle and wiggle the connector at the gauge pack while observing the gauges. Look for intermittent movement or flickering of the gauge needles while wiggling the harness connector. If there was any needle movement, perform a drag test of all the terminals in the harness connector looking for terminals that may have loose tension. Replace any loose terminals as required. Charge Labor Code N6650.
5. Make sure the connector is fully seated between the gauge pack harness and the floor console harness. If you hear a click when you push it, that means it wasn't fully seated.
Start the vehicle and wiggle the connector at the gauge pack harness to floor console harness while observing the gauges. Look for intermittent movement or flickering of the gauge needles while wiggling the harness connector. If there was any needle movement, perform a drag test of all the terminals in the harness connector looking for terminals that may have loose tension. Replace any loose terminals as required.
6. If the gauge pack is working properly now, apply dielectric grease to the gauge pack harness connectors. Use GM Dielectric Lubricant P/N 12377900 (in Canada, use 10953529) or the equivalent.
7. Reconnect the harness to the gauge assembly.
8. Install a mastic patch, such as *Kent Industries Part # KT13080 Sealing Compound Patch 2 1/8” X 2 1/8” or the equivalent, as shown to reinforce the connection between the wiring harness and the gauge assembly.
9. Reconnect the front cover harness to the vehicle harness.
10. Reinstall the front floor console front cover to the console.
* We believe this source and their products to be reliable. There may be additional manufacturers of such products/materials. General Motors does not endorse, indicate any preference for, or assume any responsibility for the products or material from this firm or for any such items that may be available from other sources.
Parts Information
*This product is currently available from Kent Industries (1-888-YES-KENT).
Part Number
Description
KT13080*
Sealing Compound Patch 21/8” X 21/8”
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
'11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned
Proud Litho owner #190 - Homecoming Litho #120
'15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA
MS3DALE is offline   Reply With Quote
Old 12-20-2011, 10:26 PM   #13
JCO2185
RIDING ON AIR
JCO2185's Avatar
perfect, thanks for that!
Old 12-21-2011, 06:14 AM   #14
HDDAN
HDDAN's Avatar
Drives: 2010 Camaro 1SS 2007 HD FLSTC
This happened to mine. The cure was to unplug it and re-plug it. I took it to the dealer and they told me that they were going to order me a new one but when I got back into the car, they worked after the dealer had unplugged them and plugged them back in. It only happened to two of the gauges, the other two worked.
HDDAN is offline   Reply With Quote
4 guage pack sask-man Canada 30 03-25-2010 03:57 PM
QUESTION ABOUT ADDING A FOUR GUAGE PACK ?? billyspeed 5th Gen Camaro SS LS LT General Discussions 6 11-28-2009 03:39 PM
Four Pack Guage background colors jimsss 5th Gen Camaro SS LS LT General Discussions 5 09-25-2009 01:28 PM
