Old 05-16-2010, 09:16 PM   #1
hansenp
hansenp's Avatar
Drives: 2010 Camaro 2 SS/RS
Nitrogen or Air?
Just wondering who fills there tires with nitrogen and if so why ? Big O tires will do it for around 25 bucks what do u think?
hansenp is offline   Reply With Quote
Old 05-16-2010, 09:18 PM   #2
jeepguy_1980
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
Costco has used nitrogen for years. $25 seems really high.
jeepguy_1980 is offline   Reply With Quote
Old 05-17-2010, 01:04 AM   #3
fixxxer525
Drives: 01S10,01CBR600,05Ducati, 10 2SS/RS
Send a message via ICQ to fixxxer525
stick with air, I have nitrogen and on cold tires reads 31lbs when it get up to temp it reads 35lbs. Its a waste of money.
fixxxer525 is offline   Reply With Quote
Old 05-17-2010, 01:10 AM   #4
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
air....
unless you have money to waste
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 05-17-2010, 08:33 AM   #5
Mungo
Drives: trans am
I have nitrogen and won't go back to air for several reasons
1. Does not expand or contract as much as air.
2. Nitrogen molecules are bigger than air so you will not lose pressure as fast.
3. I and my wife have noticed a smoother ride since switching to nitrogen.
4. Nitrogen contains no moisture so the inside of the tire won't rot like they do with air.
I paid $49.00 for four tires at the dealer and when ever I need a top of at oil change time he does it for free. And by the way nitrogen is lighter than air and my gas milage went up by 4 MPG. Ask a reputable tire shop for their opinion. These are my reasons.
Mungo is offline   Reply With Quote
Old 05-17-2010, 08:35 AM   #6
jeepguy_1980
My came with nitrogen from the dealer. I wouldn't even be close to the advertised mpg if I had air and were getting 4 mpg worse than I am now.
Old 05-17-2010, 09:38 AM   #7
gearhead440
gearhead440's Avatar
Drives: Yellow 2SS, 6 speed manual
Composition of compressed air: 79% Nitrogen, 20% Oxygen.
gearhead440 is offline   Reply With Quote
Old 05-17-2010, 09:47 AM   #8
Berean
Drives: Truck
Helium. Make your car 20% lighter and improve your track times.
Or hydrogen if you want to live dangerously.
Berean is offline   Reply With Quote
Old 05-17-2010, 10:08 AM   #9
danhr
BAMF SS
danhr's Avatar
Stock Longblock
Old 05-17-2010, 12:25 PM   #10
Mungo
Drives: trans am
Originally Posted by danhr View Post
It's not BS. Go to associatedcontent.com and search for your self. Race car drivers use it for a reason such as consistant tire pressure under hot and cold conditions. Commercial and military aircraft have been using it for decades. Why are new car dealers putting it in their new cars? Just for the extra money? I don't talk out of my tailpipe without having done the research before hand.
Old 05-17-2010, 12:51 PM   #11
ajp
50th Anniversary Vert
ajp's Avatar
Drives: Camaro 2017 50th Anniversary
Nitrogen. Paid $14.95 w/coupon at local dealer.
Not sure about all the above posts, but I did it to prevent tire pressure fluctuations between the cold AZ mornings and hot AZ afternoons.
Not convinced about the direct mpg savings but I since Nitrogen is lost slower than Air, you are less likely to drive around with underinflated tires.
ajp is offline   Reply With Quote
Old 05-17-2010, 01:02 PM   #12
jeepguy_1980
The 4mpg gain from nitrogen is
Old 05-17-2010, 01:05 PM   #13
danhr
BAMF SS
danhr's Avatar
You are honestly saying you gained 4 mpg by switching to nitrogen gas alone? are you being serious here?
Either
A)you were driving around with 3 psi in all 4 of your tires before you switched to nitrogen
b)you drastically changed your driving habits, from "having the gas pedal floored at all times" to "grandma driving"
c)you moved from an area of perfectly flat roads to the mountains
d)you are exaggerating
Stock Longblock
Old 05-17-2010, 01:57 PM   #14
hansenp
hansenp's Avatar
Wow that clears it up! lol the tire shop gave me the same pitch of the army , planes and nascar. But airplanes use it for two reasons air expands under heat and oxygen can fuel a fire so if a tire over heats and blows out the oxygen will fuel the fire if started by the blowout not sure about all the rest
Colorado members check in here 2010 SS RS USA - Rockies / Midwest 8853 06-13-2022 08:45 PM
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 09:26 PM
Vortech vs Maggie IPAINTBRIDGES31 Forced Induction - V8 34 03-27-2010 06:48 PM
K&N 2010 Replacement Air Filter GmPartsDirect.com V8 Bolt-Ons & Tunes 2 03-09-2010 05:53 AM
Factory mufflers facts PieNsky Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 14 10-26-2009 11:48 PM
