Old 05-26-2010, 09:30 AM   #1
toehead93
Drives: 2014 2SS/1LE
LT header install
Whats the trick to keeping the exhaust from rattling on the cross brace? I had my LTs installed yesterday and they couldn't adjust them enough to keep a clear gap between the pipes and the barce. I'm taking it back today to see what they can do, any suggestions, any tricks?
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 05-26-2010, 10:20 AM   #2
bbktech2
Drives: 1937 Ford
I stick a 1-1 1/2" tall piece of wood on top of the brace and under the exhaust pipes. Then tighten the system from the collectors, back. Pull the spacer out when done. Works for me. I've also seen the use of 1" long aluminum spacers at the brace to space it down abit for extra clearence.
bbktech2 is offline   Reply With Quote
Old 05-26-2010, 10:20 AM   #3
Russell James
Russell James's Avatar
Do they have the spacers under the brace? My ARH set up came with spacers that are about 1/2" thick.
Then when putting everything together, I got everything lined up, then put a thin piece of wood between the pipes and the cross brace. This pushed the pipes up to give a little clearance. Then tighten all the clamps down. Then remove the piece of wood, and there should be a little clearance left in there.
If it winds up real tight even with spacers and forcing the pipes up before tightening, I believe there is an aftermarket brace with a little more clearance.
Old 05-26-2010, 10:23 AM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
A couple washers on each bolt is the cheap way out. There are a couple aftermarket tunnel braces that were made to combat this issue. They are cut down in the exhaust area about 1/2in. I'm thinking they run about $100 for a nice aluminum piece with a chevy bowtie cut in it. You could also do the washer trick with the BMR piece, which is a tad bit cheaper.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-26-2010, 10:28 AM   #5
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Check out G-townmach's signature...
http://www.camaro5.com/forums/member.php?u=19397
I also believe BMR makes a new brace for this...
Old 05-26-2010, 02:35 PM   #6
toehead93
Thanks for the help. We used spacers and rest it. No rattles at all!!
2010 2SS A6 - sold.
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 02:41 PM
MTI Racing Header Shifter Install MTI Racing Kevin Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 05-20-2010 05:02 PM
Maggie install (automatic L99) Easy racer778 Forced Induction - V8 27 04-26-2010 06:04 PM
Header install in Central Florida found great place. Ltdodge USA - Southeast 0 02-25-2010 02:32 PM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 05:36 PM
