Old 05-28-2010, 10:39 PM   #1
Merlinnnn
Drives: 2011 Mustang GT
Magnaflow Resonated X-Pipe install question
I installed the Magnaflow 16581 axleback today - I already have Kook's LT's so I was trying to quiet down the exhaust but it still not quiet enough for me - yeah, I am super picky about drone. Anyway, I am thinking about ordering the 11386 resonated x-pipe from Magnaflow but was wondering if I could install it with clamps or does it have to be welded in? Just not sure if will slide over my stock pipes or if it will be exact same diameter so I just want to know before I order it. I will get it welded later on probably but just wanted to clamp it in for now if there is enough room. Anyone done this? Thanks - having hell getting the sound I want out of this car with the LT's.
Merlinnnn is offline   Reply With Quote
Old 05-28-2010, 10:52 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
If a muffler shop is going to install it, they have a machine that can widen the pipes to slip over the resonator tubes or vise versa.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-28-2010, 11:22 PM   #3
Merlinnnn
Yeah, I was just thinking about getting out the sawzall and doing it myself but don't know if the xpipe is already flared or not.
Old 05-29-2010, 12:55 AM   #4
JS
JS's Avatar
Drives: 2010 Camaro SS
Its not...
I have one at the shop and will be installing mine next week
SOLD
2010 Camaro 1SS/A6
12.59@111.31
Magnaflow Magnapack Axleback & Resonated X-Pipe/OBX LT Headers/Airaid Cold Air Kit/Injection Connection Tuned
JS is offline   Reply With Quote
Old 05-29-2010, 12:00 PM   #5
Merlinnnn
Thank you, sir!
Old 05-30-2010, 09:04 AM   #6
axis
Search Ninja
axis's Avatar
I'd suggest taking the resonator section to a muffler shop and have them flare the ends. Surely they wouldn't charge you more than $5-$10. Then you could take it home and cut the pipes to fit, then slip it on.
Halltech CF 102 fed
Old 05-30-2010, 10:13 AM   #7
caverman
caverman's Avatar
Drives: '69 SS Convertible
Once you get it done let us know how you like it or even better post some video. I'm wanting headers soon but wonder how loud it's going to be with the resonated x and muffler delete.
Build Journal
Old 05-30-2010, 12:45 PM   #8
JS
JS's Avatar
I'm torn too,I have the edelbrock x at the shop along with this resonated magna x
Cant decide which one to use?
I wanna do hf cats too (never gonna put headers on the car) so I think the resonated x might be better for me.
Once I add the hf cats its gonna get louder and with the edelbrock x it might be too loud since I already have the comp. axleback.
Does anyone have a muffler delete and a true x on a L99?
Is it louder now that u added a true x?
My AFM is turned off so no drone..
SOLD
2010 Camaro 1SS/A6
12.59@111.31
Old 05-31-2010, 01:05 PM   #9
Bumble_Bee
Bumble_Bee's Avatar
Drives: 2SS RS
Originally Posted by JS View Post
Its not...
This is not true. Mine was already flared and slipped right over the stock 2.5" pipes. Perhaps either you or I got an oddball, but seems unlikely.
Bumble_Bee is offline   Reply With Quote
Old 05-31-2010, 11:26 PM   #10
JS
JS's Avatar
My Magna resonated X is all the same pipe, no flare..
I will need to be flared to fit..
My Edelbrock IS FLARED and will go over the stock pipe..
I am going with the Edelbrock and sending back the MAGNA RESONATED ONE
SOLD
2010 Camaro 1SS/A6
12.59@111.31
Old 06-01-2010, 12:19 AM   #11
Bumble_Bee
Bumble_Bee's Avatar
Drives: 2SS RS
That is very very strange. Again, mine slipped right over so it was flared from the factory. Quality control issues?
Old 06-01-2010, 10:26 AM   #12
Scrappy Doo
Scrappy Doo's Avatar
Drives: Callaway Rogue
I cut out my magnaflow resonated x for a true, non resonated x.
Have it sitting in my garage if you want one.
Scrappy Doo is offline   Reply With Quote
Old 06-01-2010, 01:17 PM   #13
JS
JS's Avatar
I just check it, It isnt flare but its od so it does slip over the stock piping..
U r correct..
I just thought since it was flared it would need to be but since its od it doesnt need it
SOLD
2010 Camaro 1SS/A6
12.59@111.31
Spring install and Bumpstop question caverman Suspension / Brakes / Chassis 3 12-30-2009 11:33 PM
Magnaflow Comp axle back 5" question mikeSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 12-29-2009 08:34 AM
SLP side gills...Install question newagemuscle Cosmetics and Lighting Modification Discussions 2 12-26-2009 02:44 PM
x pipe question jordan 572 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 07-21-2009 02:53 PM
question on install: GMPP cat back exhaust detroitboy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 04-04-2009 01:52 PM
