Door ding magnet
My SuperFlow dyno numbers today
I went to EB3 Motorsports in Chantilly, VA today and got a chassis dyno on their SuperFlow dyno. Here are the best 2 pulls:
#3: 267.9 HP @ 5800 RPM #4: 267.2 HP @ 5800 RPM Those numbers seemed low to me even for a SuperFlow dyno. I told the guy doing the pulls (E.V., the owner) about the low octane mapping and how that was an issue for some people. The thing is, I pulled the #5 and #20 fuses last week for a full night. So my questions are, for those of you who have had a stock L99 on a SuperFlow, what were your top HP numbers and is there something wrong with my car? The shop owner said he usually sees a 28-30% drivetrain loss on his dyno so even at 30%, I should be pulling about 280 HP. I'm thinking of getting my ECU flashed by the dealer with the latest software and then going back for another dyno run, but if my numbers seem reasonable, I don't want to waste my money doing that. Thanks everyone! Michael |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS IOM L99 Join Date: Jan 2010
seems to me you should be getting well above 300.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
WOW.....that's the lowest L99 numbers I've seen. Most are in the 320-330 range.
Build Journal ![]() |
Door ding magnet
Even on a SuperFlow? I thought the 320-330 range was for a Dynojet type dyno.
I may have to PM Ted Jannetty on this since that's the dyno he uses. |
![]() ![]() ![]() ![]() Drives: 1SSRS RY L99 Join Date: Aug 2009
What gear was this measured in? My pulls were about the same as your in 2 or 3rd. 4th shows the highest hp. I had 321 with a Mustang dyno. The engine should be at a higher in rpm too, @6000.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 10 SIM 2SS/RS LS3 Join Date: May 2008
something is either wrong with your car, the dyno, the software, or the guy who did it. Those are extremely low numbers.
These are supposed to be RWHP and RWTQ in the 320 or so range. The drivetrain loss is for HP and TQ measured at the crank which should be right around 400 hp. Doesn't matter Superflow or Dynojet. Your #'s won't vary that significantly. I would use another dyno. Does your car feel slow? You should feel that difference. Was is stuck in AFM mode (on 4 cylinders)? I'm thinking it may have something to do with it.
5th Gen Camaros of the Carolinas
SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears.... |
#7 |
Door ding magnet
The pulls were done in 4th gear. I have the print out for 2 of the pulls and they go to 6300 rpm. I listed 5800 rpm because that was peak power for the first good pull. That was his first L99 so I'm not sure if he didn't turn something off, like stability or traction control. He said he turned off traction control.
It's hard to judge how it "feels". That's too subjective. It certainly throws me back into the seat when I floor it. |
#8 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Sounds to me like that dyno needs a calibration. Something is not right, I suggest you find another dyno and check it again, the car would have to be slower than a V6. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 Fifty SS - '18 Traverse Redline Join Date: Jul 2009
Those numbers cant be right.
2017 Camaro SS -"FIFTY"
![]() Mods: "93 Octane" |
#10 |
Door ding magnet
The saga continues. I went to Function Tuned today in Dulles, Va for a second dyno opinion. Even though they are a Nissan performance shop, I picked this place because another forum member had his M6 dyno'ed there in April, so I had some numbers to reference. I even had a printout of his dyno that he posted here.
So, my max HP today was 281.7 rwhp, or ~14 hp more than what I pulled at EB3 Motorsports. This was on a Dyno Dynamics. The other camaro5 member's max HP was 340.2! Granted, I have an automatic but that's a huge difference. So, clearly there is something wrong with my car. I'll be making an appointment shortly to take it to the dealer and have them check to see if I'm in "low octane" mode. Either way, I'm going to have them flash the ECU to the latest software version. Hopefully my dyno research will be enough evidence for them to do the work under warranty. Once I'm done with the dealer, I'm going back to Function Tuned for another dyno. If anyone has any tips for how to deal with the dealer, like a TSB for the low octane issue, it would be greatly appreciated. |
#11 | |
![]() Sorry your car is sour, Hopefully the Dealer can find something out of whack. 340 for an LS3 is 35 shy, but yours it like 50 shy from where it should be. Ted.
#12 |
Door ding magnet
I just spoke with the service manager. They've had my car all day, but since it's Sunday they can't call technical assistance at corporate.
He told me that it's got the latest software version, so they can't even flash it to update it. He's also trying to tell me that since it's the automatic, that may be the normal HP compared to the LS3 dyno I gave him. I'm giving him one more shot to call Corporate tomorrow and maybe figure something out. If that doesn't work, I'm just going to have to get it tuned. If anyone knows of any case numbers or something from GM that I can reference, please let me know. I know some of you with the low octane mapping had GM techs look at your cars. |
#13 |
The Milano
Drives: 2017 Firefly ShipWorks Join Date: Jun 2010
http://www.camaro5.com/forums/showth...=1#post1979308 a thread of many members who are experiencing the same issue. Your dyno data will help that whole group.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter. |
#14 | |||
Booooosted.
It was timing my car that made me realize the 'Slow L99' problem last year. NOT the dyno, OR the way it felt. Time it, and see what you get. I suspect you are on some bad machines. The dealer read mine as 'Within Specs' also. They would have to LOOK at the fuel table to know. And I don't think they even can. |
| BBK Shorty Header Dyno Test Today!!! | Jason 98 TA | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-25-2021 08:58 AM |
| dyno done for today. | 1bacamaro | Forced Induction - V8 | 40 | 06-12-2010 01:20 PM |
| L99 VORTECH SUPERCHARGER DYNO NUMBERS | JANNETTYRACING | Forced Induction - V8 | 15 | 06-05-2010 08:59 AM |
| Did dyno runs today at OCD Customs in Brea | Bowtie Junkman | Vendor and Seller review / feedback / experiences | 37 | 05-28-2010 08:26 PM |
| Help with dyno numbers | seddon | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 12 | 02-23-2010 02:58 AM |
