Old 06-19-2010, 09:50 AM   #1
JohnForeman
Drives: 2010 2SSRS
Possible Problem with Metra Install (door locks)
Hi All,
Was trying to lock my doors the other day without the key fob. Had not tried it since I installed the metra kit. Anyhow, when I pressed the door lock down, both doors locked like they should, but then within a second or two, the drivers side door unlocked. I tried it a couple times and each time the drivers side door would unlock on it's own. So then I tried it by pressing the door lock button on on the metra frame, same thing. Drivers side door would lock, then unlock a second or two later. I eventually had to go back in the house and get the key fob to lock the car. Can you other metra install people check your cars? And even the non metra still factory people?
Let me know
-John
2010 2SSRSA6 - GFX
35% Window Tint
93 Octane Diablo Predator Tune
JohnForeman is offline   Reply With Quote
Old 06-19-2010, 09:54 AM   #2
Mikes SS
Mikes SS's Avatar
Drives: '10 CGM 2SS/RS 6M
was your driver door stil open when you tried this? That is something that is programmed in I think so you can't lock your keys in the car.
Mikes SS is offline   Reply With Quote
Old 06-19-2010, 10:16 AM   #3
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
Yeah was the door open because it wont lock when open.
csjcsj is offline   Reply With Quote
Old 06-19-2010, 08:18 PM   #4
JohnForeman
Drives: 2010 2SSRS
Yes, the door was open. That's my point, how do you lock the car up for the the night if you don't have the key fob?
So it's not something that is from the metra install? Factory works the same way?
2010 2SSRSA6 - GFX
35% Window Tint
Old 06-19-2010, 08:25 PM   #5
ElManny
ElManny's Avatar
yes the factory works the same way. its a factory precaution so you dont lock your keys in the car
Old 06-19-2010, 08:58 PM   #6
Dmundz
Dmundz's Avatar
Drives: 2010 Cyber Gray 2SS/RS
Yep yep help to prevent you from locking In your keys I believe
Dmundz is offline   Reply With Quote
Old 06-19-2010, 10:37 PM   #7
KTMracing09
KTMracing09's Avatar
Drives: 2SS/RS L99 ABM
you can turn it off in ur settings
KTMracing09 is offline   Reply With Quote
Old 11-30-2012, 11:26 PM   #8
Albert15
Banned
Drives: Camaro 2007
There would be a programming setting which doing problem, you need to call expert lock smith who can do that and get rid of this common problem.
Albert15 is offline   Reply With Quote
Old 12-01-2012, 12:53 AM   #9
dragon22
Drives: 2010 Camaro 2SS/RS SIM
Or close the door and lock it from the passenger side. LOL
dragon22 is offline   Reply With Quote
DIY : Install headers on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 70 06-25-2020 07:40 PM
Maggie install (automatic L99) Easy racer778 Forced Induction - V8 27 04-26-2010 06:04 PM
Header install problem, need help 1977and2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 39 02-15-2010 01:02 PM
P0300 Misfire Code Help black-knight 4th Generation Camaros 4 02-08-2010 02:45 PM
DIY: Here it is Dashboard ambient lighting ABL Tecca Camaro DIY & HOW-TO instructions & discussions 356 09-03-2009 11:46 AM
