Old 07-03-2010, 11:05 PM   #1
Brolik10
BLOWN!!!
Brolik10's Avatar
Drives: 2010 RJT 2SS
X-Pipe vs. Straight pipe
Does anybody have any input on what's better for a more aggressive sound?
Brolik10 is offline   Reply With Quote
Old 07-06-2010, 02:09 AM   #2
The 2010 Sin
Dont H8 Me Cuz U Aint Me
The 2010 Sin's Avatar
Drives: 2016 SS Sedan, 2017 Explorer Sport
X pipe or H pipe you mean?
The 2010 Sin is offline   Reply With Quote
Old 07-06-2010, 02:27 AM   #3
Ivan @ Southwest Speed
X for the win!!!
The factory has a menial "H" pipe in it.
Most every performance Catback has an "X" style incorperated.
-Ivan
Old 07-06-2010, 12:29 PM   #4
longbeachss2010
longbeachss2010's Avatar
Drives: black SS
i think straight . x will make less loud.
longbeachss2010 is offline   Reply With Quote
Old 07-06-2010, 12:36 PM   #5
1badtie
1badtie's Avatar
Drives: 2018 Camaro ZL1
i have the muffler delete right now and was thinkin abt gettin an x pipe i think it would add more power than the stock h pipe and idk what you mean by straight pipe ive never heard of that in terms of where the h pipe is..
1badtie is offline   Reply With Quote
Old 07-06-2010, 12:51 PM   #6
Topdown
The wait is over!
Topdown's Avatar
Drives: 2010 Camaro, IOM, L99, Auto
I am certain someone will correct me if I am wrong, but x-pipes increase the scavenging from side to side (left cyl create lower pressure in the right side and thus pull more exhaust and vice versus) so they have better performance characteristics. H-pipes basically just equalize pressure between the two but you dont get the same scavenging effect.
That being said, in my personal experience (about 30 small block chevy's), X-pipes have always seemed to be louder than H-pipes and I dislike the sound of true straight pipes (with no X or H).
I will be going with a high-flow cat, rear cat delete and a resonated X-pipe. If thats still too quiet, I will do a muffler delete... but the X-pipe is a must IMO.
Ordered - 4/17/2010
Delivered - 5/29/2010
AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener
Topdown is offline   Reply With Quote
Old 07-06-2010, 02:20 PM   #7
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
i think the op is actually trying to compare true duals to an x pipe.
That being said, I believe a true duals will be louder, but the x pipe will perform better.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 07-06-2010, 06:43 PM   #8
1badtie
1badtie's Avatar
i also heard that the x pipe will decrease the decel popping that is caused from the muffler delete btw
Old 07-06-2010, 06:55 PM   #9
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
the popping is not caused by a muffler delete, it's just made louder by it...and no an x-pipe will not get rid of it.
POWERFREAK is offline   Reply With Quote
Old 07-06-2010, 09:34 PM   #10
Wilburbeest
Think With Your Dipstick!
Wilburbeest's Avatar
Drives: 1997 Camaro Z28
X pipe is still considered true duals. But yes an X or H pipe will perform better, even if only slightly. Tends to sound better as well. X pipe vs H pipe.....the X will generally flow a bit better up top but its a negligible difference. Seems like h-pipes tend to sound a little deeper and more old-school.
- Willy
1997 Camaro Z28 (LT1/T56): K&N CAI | Kooks 1 3/4" LTs | 3" Custom Duals | UMI LCAs w/ relocation brackets | UMI adj. panhard bar | UMI adj. torque arm | Koni SA shocks | Strano Springs | Ram Powergrip clutch | Pro 5.0 shifter | skip shift eliminator kit | WS6 Store rotors | Hawk HPS pads
Wilburbeest is offline   Reply With Quote
Old 07-07-2010, 06:45 AM   #11
Scott@Bjorn3D
DO NOT GO STRAIGHT PIPE!!. Ok now I got your attention. I ran that for about a week and lots alot of HP and TRQ. She sounded mean as hell but could not spin a tire for shit. Called Ted at Jannetty racing and talked about it and he said I did lose HP and TRQ to the back wheels big time. So went back and had an X-PIPE put in to replace the L99 resonator I had taken out. Now she runs better than she did with the resonator and sounds meaner.
Scott@Bjorn3D is offline   Reply With Quote
Old 07-09-2010, 10:35 AM   #12
Brolik10
BLOWN!!!
Brolik10's Avatar
Any reccomendations on a good X-pipe? I'm running a true dual set up right now and it feels as if i've lost power..
Old 07-09-2010, 10:57 AM   #13
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Magnaflow has a good x-pipe...i'll try to find the part number.
There are other companies that have x-pipes as well, but I don't want to give the wrong information.
EDIT:
Magnaflow Tru-X Pipe part# 10781
Magnaflow Tru-X Crossover part# 10791
The x crossover is the one that many use
Old 07-09-2010, 10:59 AM   #14
Brolik10
BLOWN!!!
Brolik10's Avatar
cool!
Camaro straight pipe, a quick and easy exhaust mod (videos) 2010 SS RS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 234 12-18-2017 11:06 AM
Camaro SS RS Straight Pipe , before and after vid MikeBing Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 120 09-13-2011 11:12 PM
straight pipe? Lss3 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 05-12-2010 02:39 PM
SLP Straight Pipe TaylorRyanSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 19 02-28-2010 05:28 PM
Loudmouth 1 verses straight Pipe Danny Thomas Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 12-15-2009 02:29 PM
