Old 08-06-2010, 07:19 PM   #1
shaner74
Drives: 2010 camaro 2SS/RS
Why so much love for PD blowers??
It seems like a majority of FI cars on this forum are using PD blowers. I'm surprised I don't see more guys going turbo. I don't want to start a huge firefight, but with all things being equal, turbos usually make more power and are easier on the motor, and I don't think turbo lag is even an issue these days. I plan on going FI myself in a few months, so I've been weighing my options. Really, the only reason I had been considering a blower over turbos was ease of installation and the cost is a little less. At this point I'm about 90% sure I'll be going turbo though. Heat is an issue but it's a manageable one - materials used, turbo placement, etc... So what gives? Why so many blowers?
shaner74 is offline   Reply With Quote
Old 08-06-2010, 08:12 PM   #2
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
I too am a big turbo fan, specifically twin turbo. Turbos came later to the Camaro than did PD's. Your point about ease of installation and cost is correct. Top mount or bottom mount is the next question? And, the installation you aluded to is so much more involved with the turbo over super. With dual oil in and out and dual cooling water in and out and single or dual intercoolers in and out and to use air to air or air to liquid intercooling plus the liquid pumping etc. Then you have dual wastegates or BOV's. If bottom mount turbos you have to get cooling oil up above the pan etc. IT CAN BE MORE COMPLICATED. I bring this up for those reading this thread and not familiar with turbo installations. However, once completed and sorted out it is the best, sweetest ride you can imagine. My 2 cents.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 08-06-2010, 08:46 PM   #3
600hp-lpe
Drives: 2010
PD blower is almost maintenance free... let's see you get 100K miles out of a twin turbo setup without having to do anything.
600hp-lpe is offline   Reply With Quote
Old 08-06-2010, 08:53 PM   #4
old motorhead
Drives: Maggie blown LS3 vette
If you want to install, slam the hood, and enjoy....Maggie. If you don't mind tinkering around a bit, and being a little different is important to you, anything else will do.
old motorhead is offline   Reply With Quote
Old 08-06-2010, 09:15 PM   #5
lock
lock's Avatar
Drives: 11 2SS/RS E-Force Supercharged
went turbo on my IROC. Love it but I was looking for an OEM quality boost on my 5th gen and the E-Force was it for me. Cant go wrong with either but for this car I wanted to install and just roll. Im always tinkering with the IROC because its more custom than OEM.
11 IOM 2SS/RS E-Force Supercharged. 616 RWHP/578 RWTQ. Click link for my journal!!!
lock is offline   Reply With Quote
Old 08-06-2010, 09:32 PM   #6
shaner74
Vehicles come equipped with TT's from the factory. 3000gt's for example. Pretty much all diesels use turbos. I can't see how a SC can be that more superior to turbos as far as longevity is concerned.
Old 08-06-2010, 09:35 PM   #7
shaner74
I hear you. Being able to install fast then go fast is a definite plus for the SC's.
Old 08-06-2010, 10:26 PM   #8
2KWIK4U
2KWIK4U's Avatar
Drives: 1969 Camaro and 2014 Camaro vert
You are correct, I am a diesel mechanic and have been for over 20 years. Turbos last a long time with regular oil changes, which also helps engine life. I have seen diesels with over 250,000 miles and only regular maintenance. As was stated they are more complicated in the install and generally are more efficient because of no parasitic loss.
With that said, it is hard to beat the wow factor of a nice supercharger sitting on top of the engine and a much easier install.
Danny
Danny
" I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these things to other people and I require the same from them" -John Wayne "The Shootist"
2KWIK4U is offline   Reply With Quote
Old 08-06-2010, 11:31 PM   #9
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
There's a HUGE difference between a factory turbo car and a converted nonturbo car. CR, beefy driveline, and tuning are the major ones. Look at all the guys that run 300GT's, Eclipse's, Subbies, and Neons. They all run well UNTIL you up the boost. Once you start modding them, they tend to not be so reliable. Cruise over to the nearest drag strip and see that the owners are constantly working on them. Not many people are going to buy a $38k car, spend another $10k on a TT system and not abuse it some. You can run any of the FI options and last a LONG time but as soon as you start abusing it, it gets expensive. I'm a turbo guy too but those are the facts. The same can be said about the SC guys but it's a little harder for them to increase the boost. With a turbo, just hit a button or turn a screw and you're boosting the shit out of it.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 08-06-2010, 11:36 PM   #10
Prochargedchevyi
Drives: 2010 Camaro 2SS/RS
Two different methods to obtain the same objective. It's really a matter of preference. Both types can (and have) been used reliably for over 100k miles if engineered, installed, and maintained correctly. I initially started out with superchargers only because of the availability and price of buying a turbo kit - this was 15 years ago. Now that turbo impeller and housing technology has increased so much, lag is not even an issue if matched correctly. Furthermore, the price for a turbo kit is less than a supercharger kit, considering you have to purchase aftermarket headers to allow the kit to perform optimally.
Like I said, it's all a matter of preference. It's like Coke or Pepsi. But personally, I'm all turbo.
Prochargedchevyi is offline   Reply With Quote
Old 08-07-2010, 02:38 AM   #11
JUISSD
JUISSD's Avatar
Drives: 2010 White/IOM 2SS/RS M6
Nothing beats a turbo for power. PD blowers are just easier to install and easier to tune. Turbo kits and tuning them can be a hassle. I had an 88mm turbo on my Lightning and made 993rwhp/1012rwtq out of a measly 330cid engine with stock ported heads. Turbo is where it's at if you want big power.
2010 White/IOM Camaro 2SS/RS M6
JUISSD is offline   Reply With Quote
Old 08-07-2010, 02:54 PM   #12
HaddadMotorsports
HaddadMotorsports's Avatar
Drives: Camaro
I think its been said already but here it goes again.
Reliabilty, Reliabilty, Reliability.
If you feel that you need to set world records, then i absolutely encourage the use of turbos. When turbos are setup right and you arn't working on the car, they simply can't be beat anywhere.
I will also say this, we are more than capable of putting every stock component of your car on its limits with a PD blower, and they are much more efficient these days than they have been in the past.
Thanks
Mike Haddad
HaddadMotorsports is offline   Reply With Quote
Old 08-07-2010, 08:29 PM   #13
Slowhawk
Drives: 1999 Trans Am
Belt driven blowers are more idiot proof.Meaning less can go wrong ect.
For power,the turbo wins BUT you really need to maintain them and check little things often.Then it can easilly overboost on ya.
I ran a Turbo on my truck for 40k miles(100k now on the stock motor).Stock motor with a small cam.Made 520hp/500tq out of the little 5.3L,was the wifes daily driver and towed my race car around.Had no problems at all/ever. So I'll say turbo's can be very reliable IF installed properly but most people would be better off with a belt drive setup.
Slowhawk is offline   Reply With Quote
Old 08-07-2010, 08:40 PM   #14
Jchaluja
Jchaluja's Avatar
Drives: ZL1 Camaro
I have had a TT setup for a year now, I really enjoy it and no problems so far...I've put 13k miles on it and drive it daily.....I sure hope it is as reliable (based on everyone's opinions on blowers)....I have my turbos setup to 8 psi boost and I don't use a boost controller by design so I'm not tempted to mess with my good combo....
Jchaluja is offline   Reply With Quote
What song are you listening to right now Muscle Master Off-topic Discussions 6760 11-08-2025 02:54 AM
L99 Love Mod4SS 5th Gen Camaro SS LS LT General Discussions 95 02-14-2015 08:51 PM
First car. First love. First heartbreak. elcamino85 General Automotive + Other Cars Discussion 16 12-10-2009 04:35 PM
Ragbrai riders LOVE the Camaro Brokinarrow 5th Gen Camaro SS LS LT General Discussions 3 07-23-2009 04:26 PM
Love my car! 13899 Rogue Leader 5th Gen Camaro SS LS LT General Discussions 12 06-20-2009 05:32 PM
