Old 08-09-2010, 02:47 PM   #1
ZuluKilla8
ZuluKilla8's Avatar
Drives: 2010 Camaro 1SS/RS RJT
Jack Stands
Quick question for you fine 5th gen boys and girls...Im gonna be having my rims powder coated black this comming week, and of course the car will be with out its sneakers for a few days. Looking for the best and SAFEST way to keep the car off the ground with out having it crashing down. Unfortunatly I do not have access to any type of high-end hydraulic car lift. Which i feel would be the best way to go.
Thanks
2010 Camaro SS LS3 Holley Hi-Ram Manifold,Custom grind boost cam,Vortech V-3,10Rib 3.47 Pully Airfilter Pipe Delete, 10 PSI, TSP LT Headers, Flowmaster Outlaws, Alky Control Meth Kit, PFADT 1.25, ZL1 Fuel Pump, DSS 1000HP axles, Mantic ER2 Clutch, Full BMR rear suspension drag pack upgrade. C6 Vette 18 rims with M/T 305 out back. COPO Hood
Race Proven Motorsports tuned
ZuluKilla8 is offline   Reply With Quote
Old 08-09-2010, 02:54 PM   #2
Big Brunsy
Drives: 2010 supercharged LS3
I'd say your title answers your question quite well
Big Brunsy is offline   Reply With Quote
Old 08-09-2010, 03:20 PM   #3
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
+1
jagan323 is offline   Reply With Quote
Old 08-09-2010, 03:33 PM   #4
EagleKeeper
EagleKeeper's Avatar
Drives: 2010 Cyber Grey 2SS
I just put mine on jack stands yesterday in my garage. I am also getting the rims powder coated flat black to match the stripes. Hopefully she does not have to stay on the stands too long.
EagleKeeper is offline   Reply With Quote
Old 08-09-2010, 03:57 PM   #5
The Stig
knows 2 facts about ducks
The Stig's Avatar
Yep. Jack stands. You can get a set of 4 that are rated for 3 tons at autozone for like .... $30, $35 bucks if I'm remembering correctly. Once you have them set up the car won't be going anywhere. Literally. Though do make sure you have them positioned correctly so as not to hurt the mounts.
Click to view my build thread
Old 08-09-2010, 04:06 PM   #6
SSLarry
Drives: 2SS LS3
Make sure those cheap jackstands at autozone will support the car at the height you want. Also, if you get a cheap jack at autozone, make sure it too lifts the car high enough to height you need. Otherwise you end up jacking up the car in stages using blocks under the jack and that is a pain.
SSLarry is offline   Reply With Quote
Old 08-09-2010, 04:09 PM   #7
The Stig
The Stig's Avatar
+1
I just threw the autozone ones out there as the easiest and cheapest. Like for me I have 4 jack stands that are 5 ton rated and can raise up to 18 inches, totals almost 3 feet off the ground (which I'll never need but its nice to have), and then 2 of the mechanic jacks (gaint ones that have the big handle and everything).
Old 08-09-2010, 04:29 PM   #8
ZuluKilla8
ZuluKilla8's Avatar
Yeah I have the mechanic jacks and good jack stands...just wanted to make sure it would be alright jacked up on them in my garage for a week or so.
Old 08-09-2010, 04:30 PM   #9
The Stig
The Stig's Avatar
O yea the 'maro will be perfectly fine. While it's up there you should paint the calipers
Old 08-10-2010, 03:23 PM   #10
RSHugger
Drives: 1969 RS Camaro
Also make sure you are lifting the car in the right places so you don't cause damage... there is a thread out there somewhere on this topic.
RSHugger is offline   Reply With Quote
Old 08-10-2010, 03:30 PM   #11
Ronn
Ronn's Avatar
Drives: 2010 Camaro
I like the fact that they say chevrolet and brembo.... wouldn't paint em myself.
1SS / RS / M6 / IOM / Black rally stripes / Polished wheels
It's a high school prom, it's a Springsteen song, it's a ride in a Chevrolet...
Ronn is offline   Reply With Quote
Old 08-10-2010, 03:33 PM   #12
Freezy
Synergy Green Lantern
Freezy's Avatar
Drives: to win.
http://www.camaro5.com/forums/showthread.php?t=33938
Booya
Freezy is offline   Reply With Quote
Old 08-10-2010, 03:42 PM   #13
IROCTPI
IROCTPI's Avatar
Drives: 1987 IROC-Z 305 TPI 700R4
so are you asking on what type of jack stands you should use? there all pretty much the same but iv always like craftsman so i use the 3ton high lift jack stands, they should be under 25bucks for an pair.
What is a Camaro? A small, vicious animal that eats Mustangs.
Me -14! year old guy -- My Girl -1987 IROC-Z 305TPI 700R4 modded
IROCTPI is offline   Reply With Quote
Old 08-10-2010, 03:47 PM   #14
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
+1
I don't think I'd want my car 3 feet off the ground on stands... but that's just me...
What floor jack do you use on your lowered Camaro kga10734 Suspension / Brakes / Chassis 14 03-19-2010 12:20 AM
were to put jack stands? presholt33 5th Gen Camaro SS LS LT General Discussions 4 02-24-2010 10:49 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
Whats the best place for Jack stands for winter storage? esperman Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 2 10-26-2009 12:05 PM
Jack stands ROD1 5th Gen Camaro SS LS LT General Discussions 14 10-24-2009 10:03 AM
