![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
Pedders Radius Rod Inserts installed
Since there isn’t much posted about these inserts I figured I would share.
I bought the Pedders Stage 1 Street kit from Rob @ Wretched Motorsports. The kit includes the Cradle Bushing Inserts and the Radius Rod Inserts. This kit is definitely the way to go to start off your suspension mods. Pedders is not the cheapest brand out there but IMO they are worth it.....especially for bushings. Actually, I think they are the only ones that make the inserts. I'll keep this thread to the Radius Rod Inserts and will post another thread for the cradle inserts. The Radius Rod inserts are super easy to install. You shouldn’t have to even take the wheels off. However, if you’re like me and have the ADM scoop you’ll have to loosen it so you can get the driver’s side radius rod bolt out. For me that meant taking the wheel and fender well off. That’s actually an easy thing to do though….and extra 10 min to take off and 10 min to put back on. Just make sure to locate the correct part because at first I was taking off the wrong arm and then realized that and found the correct one. I think it took a 7/8” socket and a 13/16” wrench to hold the nut (don’t quote me on those….I can’t remember for sure but I think that’s right). Hold the nut on one end and take the bolt off the other. The radius rod drops right out of its mounting point. Then take a screwdriver or pick and get the OEM rubber out. The Pedders inserts then just push back into place. There is a small insert guide that will keep you from installing it incorrectly. Once both sides of the radius rod have the new inserts then just bolt it back into place. It will take you as long to get the car in the air and pull the tools out as it will to install these. The OEM rubber is super soft and the Pedders inserts are not. You can see in the pics the difference between the two. The Pedders inserts are extremley firm. It’s a major difference and there is no way it won’t make a difference.
Build Journal ![]() |
![]() Drives: '11 2SS/RS RJT M6 Join Date: Oct 2010
Thanks Caverman!
Vararam CAI, Elite Engineering Catch Can, Separate Clutch Fluid Reservoir, Ghost Armor Full Protection Package, Chromed Turn Signal Bulbs, RPI Stealth Splash Guards, Skip Shift Eliminator, Defenderworx Chrome Bowtie Inserts, Pfadt Trailing Arms, Camaro Decal Store CGM Hood Spears with "376ci" custom text, Billet Depot/Drake Underhood Polished Caps, CGM Lug Nut Decals, Pedders Front Radius Rod Inserts, JacFab Front License Plate Bracket![]() |
Drives: Camaro Justice Join Date: Jun 2007
This is one of the best hot to posts I have seen on Camaro5.
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro LS M6 Inferno Orange Join Date: May 2010
Yep, I used 13/16.
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers Find me on Facebook: http://www.facebook.com/gahammerle |
#5 | |
Unfortunatley I wasn't smart enough to notice it until after I had losened it. I probably should look at getting it re-aligned just in case. I might do that anyway before my next AutoX event.
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
#7 |
#8 |
I had a bit of a difficult time with the install because I think the air ratchet that the operator in the plant used on mine was way out of calibration!
![]() Anyway, I notice that the steering seems tighter and the Camaro doesn't wander through corners. I also noticed that the front doesn't dive as much under braking (although that could be in my head). Nice improvements for such a small part.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
Great pics! Very helpful! What do you torque the bolts back to? Thanks-
#10 |
Some said 45 lbs....others say as tight as you can get them. I just did them as tight as I could.
#11 |
![]() Drives: 2007 Dodge Charger SXT, 2010 2SS Join Date: Feb 2010
Thanks for posting this, it looks like this will be my next MOD looking foward to seeing what the craddle inserts did for you.
#12 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Nice DIY caverman! I did the inserts and had no problem loosening the bolts! It was an easy mod and it did make a difference in steering feel! JusticePete once told me to just "use the German 'goodintite' spec", if you don't know the torque spec, lol!
#13 |
![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS/RS LS3 Join Date: Aug 2010
dang you, I thought I was done with mods...
Yeah, I'll get around to it...
#14 |
LOL....me too
You're never "done". They might slow down but not done. I've had my '69 back on the road since '99 and it's still not "done". The mods on that car have slowed way done but I still have plans for more. It's just taking twice as long now that the '10 is sucking up all my mod money.
| Do I really need sway bars? | Inuyashas_Brother | Suspension / Brakes / Chassis | 58 | 06-07-2011 03:26 PM |
| street review of pedders bushing inserts | camaro4mybday | Suspension / Brakes / Chassis | 8 | 05-12-2011 08:19 PM |
| Where are Pedders coilovers made? | g-townmach | Suspension / Brakes / Chassis | 69 | 05-03-2010 12:44 PM |
| Zeta (Camaro/Commodore/G8) suspension details | Gatecrasher | Wheels and Tires Talk Sponsored by The Tire Rack | 66 | 04-16-2009 01:11 PM |
| Pedders partnering with GM Racing on Camaro suspension | Info@PeddersUSA.com | Wheels and Tires Talk Sponsored by The Tire Rack | 6 | 09-30-2008 12:14 PM |
