#267 | |
Petro-sexual
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
#268 |
THE CAMARO KING
Drives: 2012 Camaro ZL1 on order #PZSD7S Join Date: Aug 2006
why was this thread moved? its not anything new. Put it back up top where it belongs.
2012 Camaro ZL1 Car Name: Bruce
ZL1, LSA, MN6/MG9, DSX, RTQ, VR, Current Status: 2030 1000 Initial Order 11/11/2011 Chevyland 1100 Order accepted at dealer: 11/11/2011 - PZSD7S 2000 Order accepted by GM: 12/14/2011 3000 Accepted By Production Control: 00/00/2011 - TPW 00/00/2011 3100 Sequenced: 00/00/2011 3300 Scheduled For Production:0/0/2012 3400 Broadcast: 0/0/2012 3800 Produced: 0/0/2012 4000 Available To Ship: 0/0/2012 4200 Shipped: 0/0/2012 5000 Delivered To The Dealer: 0/0/2012 6000 Delivered To Customer:0/0/2012 |
#269 |
Cooter
Drives: my wife crazy Join Date: Oct 2011
Is the MRC going to be capable of softening the rear suspension and stiffening the front for drag racing??
I didn't see it in the 5 modes of PTM but wishful thinking. I don't intend on doing much drag racing with this car but would like to take at least once to see what she has.
#1451 - 2012 ZL1 - White, Black Wheels, Manual, Suede Package, and Exposed Hood Insert. Delivered on 6/20/12. Thanks to Jason from Symdon Motors in Evansville, WI.
#270 | ||
Petro-sexual
![]() Quote:
#271 |
Cooter
Thanks for your response. I hope they do and wouldn't think it would be that hard to incorporate into the system. More wishful thinking.
#272 | |
THE CAMARO KING
#273 |
Use the Force
Thanks for bringing this back Radz.
Walk softly, carry a light saber and drive a ZL1!
#274 | |
I used to be Dragoneye...
#275 | |
No Fear-No Limits- Camaro
Drives: '13 ZL1 or Suzuki Hayabusa Join Date: Jul 2009
Does anyone know the sample rate of the Gen 3 MR system? How many times a second does it measure & adjust? .
__________________________________ ................................................The Faithful are Watching. |
#276 | |
Will sense and adjust once every INCH, when traveling @ 60 mph. And, if memory serves, it's lighter than the outgoing systems, uses two coils instead of one and can achieve both softer, and stiffer settings than the previous generations.
#277 |
Use the Force
Radz, I hope this helps you.
These are the option codes for the 2012 ZL1. There are still a couple missing but they are standard items available with every Camaro. If any are incorrect, let me know, the list is based on information gathered from forum members, GM Staff, Chevy RPO lists and the quick order guide. The Most Requested/Questioned Codes are in Bold. RTQ - Bright 5 Spoke Polished Wheels (Optional ZL1 Wheels) WBP - Microfiber Suede Interior Package (Steering Wheel, Gear Shift Knob & Boot)(Optional) B92 - Exposed Carbon Fiber Hood Insert (Optional) MXO - Automatic Transmission (Optional) CF5 - Power Sunroof (Optional) DSX - Decal Package Low Gloss - Black Vinyl Stripe For BLACK PAINTED HOOD INSERT (Optional) DSW - Decal Package - Carbon Fiber Appearance - Gray Vinyl Stripe For EXPOSED CARBON FIBER HOOD INSERT (Opt.) VYW - Premium Carpet Floor Mats (Optional) BTV - Remote Engine Start (Optional) W2D - Cargo Net - Dealer Installed (Optional) VAS - Accessory Grill Body Colored - Dealer Installed Heritage Grill (Optional) VQL - Fuel Door Satin Nickel - Dealer Installed (Optional) ================================================== ==== LSA - Supercharged 6.2 Engine (Standard ZL1) MN6 - HD (MG9) 6 Speed Manual Transmission (Standard ZL1 ) AE4 - Sport Bucket Seats Black with Suede Inserts (Standard ZL1) F55 - Magnetic Ride Control (Standard ZL1) ANF - Black Trim (Standard ZL1) RSK - Black 10 Spoke Rims (Standard ZL1 Wheels) RPG - 285/35Zr20 305/35zr20 tires (Standard ZL1) UVC - Rear View Camera (Standard ZL1) DRG - Mirror Inside, auto dimming with camera display (Standard ZL1) AYO - Air Bags & side Curtains (Standard ZL1) B34 - Carpeted Floor Mats, Front Only (Standard ZL1) D52 - Spoiler, Unique Sport (Standard ZL1) G80 - Limited Slip Differential (Standard ZL1) SGC - Spare Tire and Wheel Not Desired (Standard ZL1) SRU - Rear Vision Package, includes UD7, UVC and DRG (Standard ZL1) UV6 - Heads Up Display (Standard ZL1) T4F - HID Lighting (Standard ZL1) AMM - Power Front Driver Seat (Standard ZL1) AKQ - Power Front Passenger Seat (Standard ZL1) O5N - Seat Trim, MIcrofiber Suede Inserts (Standard ZL1) BD8 - Body Color Roof Ditch (Standard ZL1) AYO - Airbag System (Standard ZL1) DD1 - Heated Outside Mirrors (Standard ZL1) GT4 - 3.73 Differential Gear-Manual Transmission (Standard ZL1) GU5 - 3.23 Differential Gear-Automatic Transmission (Opt. ZL1) JF5 - Alloy Foot Pedals (Standard ZL1) KA1 - Heated Seats (Standard ZL1) NPP - Performance Dual Mode Exhaust (Standard ZL1) T3U - Fog Lights, Separate (Standard ZL1) T3N - Daylight Running Lamps Separate (Standard ZL1) UQA - 9 Speaker Boston Acoustics Premium Sound System (Standard ZL1) SRJ - Convenience and Connectivity Package (Standard ZL1) FE9 - Standard Federal Emissions (Standard ZL1) ROO - Standard Invoice Bailment Hold (Standard ZL1) VY7 - Standard Leather Shift Knob (Standard ZL1) DCP - Standard Directions and Connections OnStar Service (Standard ZL1) VK3 - Standard Front License Plate Bracket (Standard ZL1) UMZ - Aux. Gauges with boost, console mounted forward of shifter (Standard ZL1) UJM - Tire Pressure Monitor System (Standard ZL1) KW8 - Alternator, 155amps (Standard ZL1) J56 - Brakes, Brembo Performance, 6 Piston Front, 4 Piston Rear, Anti-Lock (Standard ZL1) NV9 - Steering, Power Electric (Standard ZL1) FE5 - Suspension, Performance Ride and Handling (Standard ZL1) NZL - Steering Wheel Mounted Audio Controls (Standard ZL1)
#278 | |
Petro-sexual
KUDOS to you, sir The Force is strong with ![]() ![]() you ![]() ![]() ![]() ![]()
#279 |
Use the Force
Hey, it is the least I could do considering everything that you have done for me. Are you going to make this a Sticky again?
#280 |
![]() Drives: 2013 WRX Sedan Join Date: Aug 2009
Not sure if this has been asked/answered: are we expecting the auto version to be heavier like the SS is?
| Thread Tools | |
| ZL1 Sub-Stickies (Hyperlinks Inside!) | Mr. Wyndham | Camaro ZL1 Forum - ZL1 Specific Topics | 0 | 07-25-2011 01:28 AM |
| Tire Monitoring System | monevz28 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 11-22-2009 04:42 PM |
